Today I configured the Compose key for the English (US, euro on 5) keyboard layout. I have an issue with the compose key: Half the time it does not register. This is not very useful when writing text, because then you constantly make mistakes when for example "e is typed instead of ë. Is there another better solution for this except for using a layout with death keys?
inxi --full --admin --verbosity=7 --filter --no-host
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=b3996e9d-c408-4bd5-8a4e-54d10769c325 rw
resume=UUID=95e3f7ea-da51-4d38-91df-ec0a6e2b5ae1
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: Z87 Extreme4 serial: <filter>
UEFI [Legacy]: American Megatrends v: P3.50 date: 03/11/2018
RAM: total: 7.7 GiB used: 2.59 GiB (33.6%)
RAM Report:
Info: Quad Core model: Intel Core i5-4570S bits: 64 type: MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 6 MiB bogomips: 23156
Speed: 1098 MHz min/max: 1100/3600 MHz Core speeds (MHz): 1: 1098 2: 1097
3: 1098 4: 1097
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c82
Display: x11 server: X.Org 1.20.10 driver: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 953x286mm (37.5x11.3")
s-diag: 995mm (39.2")
Monitor-1: DVI-D-0 res: 1680x1050 hz: 60 dpi: 90
size: 474x297mm (18.7x11.7") diag: 559mm (22")
Monitor-2: DP-0 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel Ethernet I217-V vendor: ASRock driver: e1000e v: kernel
port: f040 bus ID: 00:19.0 chip ID: 8086:153b
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.47 TiB used: 1.14 TiB (25.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX4 size: 119.24 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1.5
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT525MX300SSD1
size: 489.05 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: R021
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: M4-CT256M4SSD2
size: 238.47 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 040H
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0001
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS55 rev: 1.02
dev-links: cdrom
ID-1: / raw size: 115.23 GiB size: 112.93 GiB (98.00%)
used: 86.6 GiB (76.7%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: b3996e9d-c408-4bd5-8a4e-54d10769c325
ID-2: /run/media/datiswous/Gamez raw size: 362.09 GiB
size: 355.41 GiB (98.15%) used: 334.35 GiB (94.1%) fs: ext4 dev: /dev/sdb3
maj-min: 8:19 label: Gamez uuid: 2d458847-3f60-4770-a7b8-8e05511a59ae
ID-3: /run/media/datiswous/Gamez2 raw size: 238.47 GiB
size: 233.73 GiB (98.01%) used: 220.66 GiB (94.4%) fs: ext4 dev: /dev/sdc1
maj-min: 8:33 label: Gamez2 uuid: 3574211e-187d-4839-937d-0c887485b381
ID-4: /run/timeshift/backup raw size: 796.21 GiB size: 782.72 GiB (98.31%)
used: 524.04 GiB (67.0%) fs: ext4 dev: /dev/sdd5 maj-min: 8:53
label: Filez4 uuid: 6bc317c5-ead9-48cf-9265-45ba01a2eee3
ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 95e3f7ea-da51-4d38-91df-ec0a6e2b5ae1
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs
label: Door systeem gereserveerd uuid: 3658C89F58C85EED
ID-2: /dev/sda2 maj-min: 8:2 size: 119.14 GiB fs: ntfs label: N/A
uuid: 743CE3B93CE37510
ID-3: /dev/sdd1 maj-min: 8:49 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdd2 maj-min: 8:50 size: 976.56 GiB fs: ntfs label: Files1
uuid: 0094ADCB94ADC38E
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8008
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8000
Hub: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 3-3:2 info: Brother Industries HL-1430 Laser Printer
type: Printer driver: usblp interfaces: 1 rev: 1.0 speed: 12 Mb/s
chip ID: 04f9:001a
Device-2: 3-4:3 info: SteelSeries ApS Sensei Raw Gaming Mouse
type: HID,Mouse,Keyboard driver: hid-generic,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s chip ID: 1038:1369
Hub: 3-9:4 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s chip ID: 174c:2074
Device-1: 3-13:5 info: Logitech M90/M100 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 046d:c05a
Hub: 3-14:7 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 05e3:0608
Device-1: 3-14.2:8 info: Trust Silent Wireless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
chip ID: 145f:0256
Hub: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Hub: 4-5:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s chip ID: 174c:3074
Device-1: 4-5.2:3 info: Genesys Logic Card reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
chip ID: 05e3:0738 serial: <filter>
System Temperatures: cpu: 26.0 C mobo: 32.0 C gpu: nvidia temp: 48 C
Fan Speeds (RPM): fan-1: 558 fan-2: 408 fan-3: 0 fan-4: 0 fan-5: 301
gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.30
Processes: 221 Uptime: 2h 31m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1707 lib: 476 flatpak: 0 Shell: Bash
v: 5.1.0 running in: xfce4-terminal inxi: 3.2.01
