Hi, Ive joined bc i have seen some posts about the subject, having joined, cant find those posts. d’oh. In a nut shell I’ve been having some real issues with LO, calc freezing when using mouse to scroll, it generally hanging up. it refuses to copy-paste whereas another machine it’s fine.. It sort of works but nothing like a fresh install which is what I was contemplating, just reinstall Manjaro and restore my backup.
Then I googled instructions to purge LO and any associated files, forget website but its definitely gone. Then I tried reinstalling it and I get this:-
sudo pacman -S libreoffice-still
resolving dependencies...
Packages (31) argon2-20190702-6 boost-libs-1.89.0-4 clucene-2.3.3.4-16 libabw-0.1.3-5 libatomic_ops-7.8.2-1 libcdr-0.1.8-3 libcmis-0.6.2-6 libe-book-0.1.3-19
libepubgen-0.1.1-5 libetonyek-0.1.13-1 libexttextcat-3.4.7-1 libfreehand-0.1.2-5 libixion-0.20.0-4 liblangtag-0.6.8-1 libmspub-0.1.4-18
libmwaw-0.3.22-3 libnumbertext-1.0.11-2 libodfgen-0.1.8-5 liborcus-0.21.0-3 libpagemaker-0.0.4-4 libqxp-0.0.2-14 librevenge-0.0.5-3
libstaroffice-0.0.7-4 libvisio-0.1.10-2 libwpd-0.10.3-5 libwps-0.4.14-3 libzmf-0.0.2-19 lpsolve-5.5.2.11-3 rasqal-1:0.9.33-7 redland-1:1.0.17-9
libreoffice-still-25.2.7-6
Total Download Size: 0.07 MiB
Total Installed Size: 537.25 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
libatomic_ops-7.8.2-1-x86_64 66.9 KiB 496 KiB/s 00:00 [############################################################] 100%
(31/31) checking keys in keyring [############################################################] 100%
(31/31) checking package integrity [############################################################] 100%
error: libatomic_ops: signature from "Anatol Pomozov (Arch Linux developer account) <anatolik@archlinux.org>" is marginal trust
:: File /var/cache/pacman/pkg/libatomic_ops-7.8.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] Y
error: failed to commit transaction (invalid or corrupted package)
** it seems I have an issue with zst files, I’ve tried reloading keyrings and doing a refresh (sudo pacman -Sy archlinux-keyring | sudo pacman -Syu) that all works, no updates but try reinstalling LO and it fails. Can any of you wizards guide me through this please.
Mod edit: Added code formatting. Please see this quick guide:
How to post Terminal output
We normally ask for System Information. Example:
inxi -zv8
… with such output, please use the code formatting (the </> button at the top of the Reply window or the three backticks ``` on lines above and below the pasted output).
Note: This output is privacy-filtered using the above command.
