After this update, when I open a new terminal window, I get the following message printed:
complete is not a known entry point. Choices are: icat, list-fonts, hold, runpy, launch, open, kitten, edit-config, shebang, edit
I’ve tried to search in the .config
directory to see where this could come from but I couldn’t find anything.
Any ideas how to fix it?
Check your ~/.bashrc
or ~/.zshrc
, apparently there’s a syntax error.
Expanding on @Yochanan ’s comment…
@narimiran if you have anything like this (it was in my .bashrc, don’t know what it may be in other shells):
source <(kitty + complete setup bash)
Comment out/delete the line.
Upstream issue
I didn’t have that line, but I had:
complete -cf sudo
I’ve commented it, restarted the computer, and — there was no change, still the same problem.
I’ve investigated some more and noticed that in the .fzf/shell/completion.bash
there are some instances of using the complete
command.
But I don’t want to touch those as I’m afraid I might break something.
This problem has been fixed in the latest update (Feb 12th).
system
Closed
15 February 2023 21:41
6
