Hello dear community!
I want to compile glibc from source to apply optimizations -march=native -mtune=native -O3
. I know it’s not safe but the failure doesn’t go away even when compiling without any optimizations! And so I am not able to compile myself glibc which is very bad situation to find myself in as a Linux newbie (joke attempted).
Specifically:
FAIL: misc/tst-mount-compile.
So, what I did (and please do ask for more relevant information if necessary) on freshly installed desktop from Manjaro i3 Community Edition with only minor updates/changes (such as linux66, but the failure I remember back at linux61 and is probably older than that):
yay -G glibc
to obtain the package.
makepkg -s
(even when I don’t change the PKGBUILD to apply the above mentioned optimizations, the result is the same)
I’ve done this both on my desktop and laptop and across many installs, albeit mostly the same, i.e.,
- Kernel: 6.6.8-2-MANJARO
- Shell: zsh 5.9
- WM: i3
Package Versions:
- glibc 2.38-7
- linux-api-headers 6.4-1
- pacman 6.0.2-14
- yay 12.2.0-1
- linux66 6.6.8-2
- linux66-nvidia 545.29.06-27
Test output (last bit of makepkg -s
XPASS: conform/UNIX98/ndbm.h/linknamespace
XPASS: conform/XOPEN2K/ndbm.h/linknamespace
XPASS: conform/XOPEN2K8/ndbm.h/linknamespace
XPASS: conform/XPG42/ndbm.h/linknamespace
UNSUPPORTED: elf/tst-audit10
UNSUPPORTED: elf/tst-avx512
UNSUPPORTED: elf/tst-cet-legacy-8
UNSUPPORTED: elf/tst-cet-property-2
XPASS: elf/tst-ifunc-isa-1
XPASS: elf/tst-ifunc-isa-1-static
XPASS: elf/tst-ifunc-isa-2
XPASS: elf/tst-ifunc-isa-2-static
UNSUPPORTED: elf/tst-valgrind-smoke
UNSUPPORTED: math/test-double-libmvec-acos-avx512f
UNSUPPORTED: math/test-double-libmvec-acosh-avx512f
UNSUPPORTED: math/test-double-libmvec-asin-avx512f
UNSUPPORTED: math/test-double-libmvec-asinh-avx512f
UNSUPPORTED: math/test-double-libmvec-atan-avx512f
UNSUPPORTED: math/test-double-libmvec-atan2-avx512f
UNSUPPORTED: math/test-double-libmvec-atanh-avx512f
UNSUPPORTED: math/test-double-libmvec-cbrt-avx512f
UNSUPPORTED: math/test-double-libmvec-cos-avx512f
UNSUPPORTED: math/test-double-libmvec-cosh-avx512f
UNSUPPORTED: math/test-double-libmvec-erf-avx512f
UNSUPPORTED: math/test-double-libmvec-erfc-avx512f
UNSUPPORTED: math/test-double-libmvec-exp-avx512f
UNSUPPORTED: math/test-double-libmvec-exp10-avx512f
UNSUPPORTED: math/test-double-libmvec-exp2-avx512f
UNSUPPORTED: math/test-double-libmvec-expm1-avx512f
UNSUPPORTED: math/test-double-libmvec-hypot-avx512f
UNSUPPORTED: math/test-double-libmvec-log-avx512f
UNSUPPORTED: math/test-double-libmvec-log10-avx512f
UNSUPPORTED: math/test-double-libmvec-log1p-avx512f
UNSUPPORTED: math/test-double-libmvec-log2-avx512f
UNSUPPORTED: math/test-double-libmvec-pow-avx512f
UNSUPPORTED: math/test-double-libmvec-sin-avx512f
UNSUPPORTED: math/test-double-libmvec-sincos-avx512f
UNSUPPORTED: math/test-double-libmvec-sinh-avx512f
UNSUPPORTED: math/test-double-libmvec-tan-avx512f
UNSUPPORTED: math/test-double-libmvec-tanh-avx512f
UNSUPPORTED: math/test-float-libmvec-acosf-avx512f
UNSUPPORTED: math/test-float-libmvec-acoshf-avx512f
UNSUPPORTED: math/test-float-libmvec-asinf-avx512f
UNSUPPORTED: math/test-float-libmvec-asinhf-avx512f
UNSUPPORTED: math/test-float-libmvec-atan2f-avx512f
UNSUPPORTED: math/test-float-libmvec-atanf-avx512f
UNSUPPORTED: math/test-float-libmvec-atanhf-avx512f
UNSUPPORTED: math/test-float-libmvec-cbrtf-avx512f
UNSUPPORTED: math/test-float-libmvec-cosf-avx512f
UNSUPPORTED: math/test-float-libmvec-coshf-avx512f
UNSUPPORTED: math/test-float-libmvec-erfcf-avx512f
UNSUPPORTED: math/test-float-libmvec-erff-avx512f
UNSUPPORTED: math/test-float-libmvec-exp10f-avx512f
UNSUPPORTED: math/test-float-libmvec-exp2f-avx512f
UNSUPPORTED: math/test-float-libmvec-expf-avx512f
UNSUPPORTED: math/test-float-libmvec-expm1f-avx512f
UNSUPPORTED: math/test-float-libmvec-hypotf-avx512f
UNSUPPORTED: math/test-float-libmvec-log10f-avx512f
UNSUPPORTED: math/test-float-libmvec-log1pf-avx512f
UNSUPPORTED: math/test-float-libmvec-log2f-avx512f
UNSUPPORTED: math/test-float-libmvec-logf-avx512f
UNSUPPORTED: math/test-float-libmvec-powf-avx512f
UNSUPPORTED: math/test-float-libmvec-sincosf-avx512f
UNSUPPORTED: math/test-float-libmvec-sinf-avx512f
UNSUPPORTED: math/test-float-libmvec-sinhf-avx512f
UNSUPPORTED: math/test-float-libmvec-tanf-avx512f
UNSUPPORTED: math/test-float-libmvec-tanhf-avx512f
UNSUPPORTED: misc/tst-adjtimex
UNSUPPORTED: misc/tst-clock_adjtime
UNSUPPORTED: misc/tst-ntp_adjtime
UNSUPPORTED: nptl/test-cond-printers
UNSUPPORTED: nptl/test-condattr-printers
UNSUPPORTED: nptl/test-mutex-printers
UNSUPPORTED: nptl/test-mutexattr-printers
UNSUPPORTED: nptl/test-rwlock-printers
UNSUPPORTED: nptl/test-rwlockattr-printers
UNSUPPORTED: nptl/tst-pthread-gdb-attach
UNSUPPORTED: nptl/tst-pthread-gdb-attach-static
UNSUPPORTED: posix/tst-cet-vfork-1
UNSUPPORTED: string/tst-memchr-rtm
UNSUPPORTED: string/tst-memcmp-rtm
UNSUPPORTED: string/tst-memmove-rtm
UNSUPPORTED: string/tst-memrchr-rtm
UNSUPPORTED: string/tst-memset-rtm
UNSUPPORTED: string/tst-strcasecmp-rtm
UNSUPPORTED: string/tst-strchr-rtm
UNSUPPORTED: string/tst-strcmp-rtm
UNSUPPORTED: string/tst-strcpy-rtm
UNSUPPORTED: string/tst-strlen-rtm
UNSUPPORTED: string/tst-strncasecmp-rtm
UNSUPPORTED: string/tst-strncmp-rtm
UNSUPPORTED: string/tst-strrchr-rtm
UNSUPPORTED: string/tst-wcscmp-rtm
UNSUPPORTED: string/tst-wcsncmp-rtm
UNSUPPORTED: time/tst-settimeofday
Summary of test results:
1 FAIL
5154 PASS
87 UNSUPPORTED
12 XFAIL
8 XPASS
make[1]: *** [Makefile:660: tests] Error 1
make[1]: Leaving directory '/home/bitwise/Downloads/glibc/src/glibc'
make: *** [Makefile:9: check] Error 2
==> ERROR: A failure occurred in check().
Aborting...
Lastly, Happy New Year:-)
Hopefully, you can help me compile glibc on Manjaro, I feel like I am just overlooking something obvious, however I feel like this should work out of the box as it’s quite common thing to do I’d assume.
