Estoy tratando de instalar el bluetooth usb dongle pero no logro hacerlo funcionar.
En la pagina del del fabricante no hay driver para linux. Intalé blueman.
Ejecuté algunos comandos y me dio lo siguiente:
indent preformatted text by 4 spaces
[mans@mans-pc ~]$ sudo systemctl status bluetooth
[sudo] password for mans:
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2020-12-06 18:38:37 EST; 47min ago
Docs: man:bluetoothd(8)
Main PID: 2238 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 4539)
Memory: 1.9M
CGroup: /system.slice/bluetooth.service
└─2238 /usr/lib/bluetooth/bluetoothd
Dec 06 18:38:37 mans-pc bluetoothd[2238]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
Dec 06 18:38:37 mans-pc bluetoothd[2238]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
Dec 06 18:38:37 mans-pc bluetoothd[2238]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
Dec 06 18:38:37 mans-pc bluetoothd[2238]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
Dec 06 18:38:37 mans-pc bluetoothd[2238]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
Dec 06 18:38:37 mans-pc bluetoothd[2238]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Contro>
Dec 06 18:38:37 mans-pc bluetoothd[2238]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
Dec 06 18:38:37 mans-pc bluetoothd[2238]: Starting SDP server
Dec 06 18:38:37 mans-pc systemd[1]: Started Bluetooth service.
Dec 06 18:38:37 mans-pc bluetoothd[2238]: Bluetooth management interface 1.18 initialized
