mnjaro
9 November 2021 15:32
1
I was trying to see if I could update a package I installed from the community repository in Pamac, only to realize all of the community repo packages were completely missing from Pamac. Only flatpak packages are available for me to install and update (because I enabled that feature), and just today I got an update for a flatpak package (so that shows at least that’s working). This might have something to do with me switching to a bleeding-edge kernel (don’t remember which one) that I noticed isn’t supported for the 10-16 update. That might be why, because I’ve noticed that I haven’t gotten a full update since then.
I’m a bit of a Linux noob, so I could really use some help on this one.
No
No
Refresh your mirrors and run a full system update - from the terminal
sudo pacman-mirrors --continent && sudo pacman -Syyu
The above command is probably the most used reply to such topics as this.
mnjaro
9 November 2021 15:42
3
I tried to update, but there was a bit of an error.
sudo pacman-mirrors --continent && sudo pacman -Syyu ✔ 6s
::INFO => Mirror status: http://repo.manjaro.org/status.json
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
1.811 Canada : https://mirror.csclub.uwaterloo.ca/manjaro/
0.623 Canada : https://muug.ca/mirror/manjaro/
0.792 Canada : http://muug.ca/mirror/manjaro/
0.827 Canada : https://mirror.0xem.ma/manjaro/
1.072 Canada : http://mirror.0xem.ma/manjaro/
0.510 Canada : https://osmirror.org/manjaro/
1.163 Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/
0.629 United_States : https://repo.ialab.dsu.edu/manjaro/
1.129 United_States : http://repo.ialab.dsu.edu/manjaro/
0.808 United_States : http://distro.ibiblio.org/manjaro/
0.601 United_States : https://mirrors.ocf.berkeley.edu/manjaro/
0.481 United_States : https://mirror.math.princeton.edu/pub/manjaro/
0.722 United_States : https://mirror.clarkson.edu/manjaro/
0.427 United_States : https://mirrors.gigenet.com/manjaro/
0.731 United_States : http://mirrors.gigenet.com/manjaro/
0.512 United_States : https://mirrors.sonic.net/manjaro/
::INFO Writing mirror list
::United_States : https://mirror.math.princeton.edu/pub/manjaro/stable
::Canada : https://osmirror.org/manjaro/stable
::United_States : https://mirrors.sonic.net/manjaro/stable
::United_States : https://mirrors.ocf.berkeley.edu/manjaro/stable
::United_States : https://mirror.clarkson.edu/manjaro/stable
::United_States : https://mirrors.gigenet.com/manjaro/stable
::Canada : https://muug.ca/mirror/manjaro/stable
::United_States : http://distro.ibiblio.org/manjaro/stable
::Canada : https://mirror.0xem.ma/manjaro/stable
::United_States : https://repo.ialab.dsu.edu/manjaro/stable
::Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/stable
::Canada : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
error: GPGME error: No data
core 170.3 KiB 355 KiB/s 00:00 [####################] 100%
extra 1900.2 KiB 1606 KiB/s 00:01 [####################] 100%
community 6.8 MiB 1560 KiB/s 00:04 [####################] 100%
multilib 175.2 KiB 876 KiB/s 00:00 [####################] 100%
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
Is there a way to fix this without a complete reinstall?
The forum has a search function - did you notice the in the nav-bar?
mnjaro
9 November 2021 16:08
5
Thanks for the help! I can see all the community repo packages in Pamac again. (In addition to that, all my packages from the community repo finally updated.)
system
Closed
12 November 2021 06:08
6
