Commands missing after update
Upgrading seems to be fine, but some of commands do not exist any more.
I have used followings but these have been removed from this update.
Which command should I use now?
mhwd-tui is a little bit different.
Removed command.
## to comfirm  installed kernels.
mhwd-kernel -li
## GPU
mhwd-gpu --check
I have never seen or used the command, and it doesn’t exist on my machine.
So if you’ve used it, it must have been some external application, perhaps this one:
In which case you should probably contact the developer.
mwhd is fine and installed here:
$ mhwd-kernel -li
Currently running: 6.18.9-1-MANJARO (linux618)
* linux612
* linux618
Also
$ sudo mhwd-gpu --check
xorg configuration symlink valid...
So double-check it’s installed for you, that you haven’t removed it, even by accident:
pamac search --installed mhwd
These are all mine:
$ pamac search --installed mhwd
mhwd-nvidia-575xx  575.64.05-3                                             extra
    MHWD module-ids for nvidia 575.64.05
mhwd-nvidia-570xx  570.211.01-1                                            extra
    MHWD module-ids for nvidia 570.211.01
mhwd-nvidia-470xx  470.256.02-15                                           extra
    MHWD module-ids for nvidia 470.256.02
mhwd-nvidia-390xx  390.157-21                                              extra
    MHWD module-ids for nvidia 390.157
mhwd-nvidia  590.48.01-3                                                   extra
    MHWD module-ids for nvidia 590.48.01
mhwd-db  20260107-1                                                        extra
    Manjaro Linux Hardware Detection Database
mhwd-ati  19.1.0-1                                                         extra
    MHWD module-ids for ati 19.1.0
mhwd-amdgpu  19.1.0-1                                                      extra
    MHWD module-ids for amdgpu
mhwd  0.6.6-6                                                              extra
    Manjaro Linux Hardware Detection library and application
What is it that you wanted to do, but cannot do anymore because of “missing commands”?
I have never heard of
mhwd-tui
That has never been a valid command.
There is
nmtui
a menu driven console interface for NetworkManager …
for example
Thank you.
I remmeber that I have stopped upgarding nvidia-dirvers for my old nvidia-GPU(1080).
And add followings to IgnorPKG and removed mhwd, mhwd-db at last upgrade.
cuda cudnn  mhwd mhwd-db
linux515 linux515-headers linux515-nvidia
nvidia-utils lib32-nvidia-utils  nvidia-container-toolkit  mhwd-nvidia mhwd-nvidia-470xx
mhwd-nvidia-570xx mhwd-nvidia-575xx opencl-nvidia  linux510-nvidia
Then I can not install mhwd, mhwd-db now.
Do you have any idea to install and use mhwd for my old nvidia-GPU.
yay -S mhwd-db
Sync Explicit (1): mhwd-db-20260107-1
:: mhwd-db is in IgnorePkg/IgnoreGroup. Install anyway? [Y/n]
resolving dependencies...
warning: ignoring package mhwd-nvidia-590.48.01-2
warning: cannot resolve "mhwd-nvidia>=455", a dependency of "mhwd-db"
warning: ignoring package mhwd-0.6.6-6
warning: cannot resolve "mhwd", a dependency of "mhwd-nvidia-390xx"
warning: cannot resolve "mhwd-nvidia-390xx", a dependency of "mhwd-db"
warning: ignoring package mhwd-nvidia-470xx-470.256.02-15
warning: cannot resolve "mhwd-nvidia-470xx", a dependency of "mhwd-db"
warning: ignoring package mhwd-nvidia-570xx-570.211.01-1
warning: cannot resolve "mhwd-nvidia-570xx", a dependency of "mhwd-db"
warning: ignoring package mhwd-nvidia-575xx-575.64.05-3
warning: cannot resolve "mhwd-nvidia-575xx", a dependency of "mhwd-db"
:: The following package cannot be upgraded due to unresolvable dependencies:
      mhwd-db
:: Do you want to skip the above package for this upgrade? [y/N]
:: unable to satisfy dependency 'mhwd-nvidia>=455' required by mhwd-db
:: unable to satisfy dependency 'mhwd' required by mhwd-nvidia-390xx
:: unable to satisfy dependency 'mhwd-nvidia-390xx' required by mhwd-db
:: unable to satisfy dependency 'mhwd-nvidia-470xx' required by mhwd-db
:: unable to satisfy dependency 'mhwd-nvidia-570xx' required by mhwd-db
:: unable to satisfy dependency 'mhwd-nvidia-575xx' required by mhwd-db
 -> error installing repo packages
Sadly I do not.
That IgnorePkg list was a very irresponsible thing to do.
If your RTX 3060, as shown on your profile, is OLD, then my GTX 960 is ancient!
But my guess would be to explicitly install everything mhwd-related, and not cherry-pick anything:
pamac install mhwd-nvidia-575xx mhwd-nvidia-570xx mhwd-nvidia-470xx mhwd-nvidia-390xx mhwd-nvidia mhwd-db mhwd-ati mhwd-amdgpu mhwd
But it’s just a guess and I don’t know for sure.
First, I’d remove mhwd and mhwd-db from the ignore list. :wink:
… since you DO apparently want the program …
Then reinstall it - preferably using pacman instead of yay.
sudo pacman-mirrors -f
sudo pacman -Syu
if that doesn’t pull in mhwd:
sudo pacman -Syu mhwd
Your system is now in an unsupported partial-upgrade state. Remove the IgnorePkg entries and reinstall mhwd.
