vrms
1
I want to use command substitution with a mv operation
mv $(locate filename) /path/to/destination/
however the result from the locate command contains spaces: /path/to/name of file.pdf
which has the entire operation fail. How can you make this work?
vrms
2
put the entire substitution inside quotation marks will do this for you
mv "$(locate filename)" /path/to/destination/
system
Closed
3
