i installed android studio and sdk and exported the path but “sdkmanager” command is not known in terminal
so executing cd /Android/Sdk/tools/bin/ ./sdkmanager is showing this error :
Exception in thread "main" java.lang.NoClassDefFoundError: javax/xml/bind/annotation/XmlSchema
at com.android.repository.api.SchemaModule$SchemaModuleVersion.<init>(SchemaModule.java:156)
at com.android.repository.api.SchemaModule.<init>(SchemaModule.java:75)
at com.android.sdklib.repository.AndroidSdkHandler.<clinit>(AndroidSdkHandler.java:81)
at com.android.sdklib.tool.sdkmanager.SdkManagerCli.main(SdkManagerCli.java:73)
at com.android.sdklib.tool.sdkmanager.SdkManagerCli.main(SdkManagerCli.java:48)
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.annotation.XmlSchema
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:641)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:188)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:520)
... 5 more
i tried setting jre path in sdkmanager config but still did not work.
can u guys guid me to solve this ? thank you for the effort of reading this.
pretty sure you did not install either of the two via standard methods
(Manjaro repository or AUR)
because, if you do that android-sdk is installed in /opt
and so is android-studio
both android studio and sdk are in the AUR and
if installed from there
are in /opt/...
If you did it any other way then I’m pretty certain that I can’t assist without asking for a lot of more information on how you did it.
The first of which would be: why?
@anon33601770 haha i did almost the same steps 3 months ago and it worked, i installed android studio from AUR and sdk from the android studio.
Now i tried reinstalling sdk, but still nothing
im exporting : export ANDROID_HOME="$HOME/Android/Sdk" in file .bashrc
when i do : echo $ANDROID_HOME
it returns /home which it is weird.
Any idea why ?
Also should i delete sdk from android studio and install sdk manager from repository ?
echo $ANDROID_HOME now works properly and sdkmanager command works.
But when i execute sdkmanager i get the same error message :
... 5 more
I did sudo chmod -R 777 /home/hamdi-alaa/Desktop/Shipzzer/shipzzer-react-native/ for the folder android and node_modules then for the whole projet, and still nothing changed.
