Recently I tried one of Live CDs and realized that the manjaro-live -h manjaro-live --help
commands are immediately executes and modifying system state.
I think it is unexpected and sort of malware behavior, please review and fix.
I didn’t get details of package version and ISO image. If you want that additional pointers, let me know, I will collect that info and post it.
Again, I report the issue while tried to figure out what is this: instead of expected manual output (or it absence) got an execution with modifications.
If it is not right learning method, than could I ask another comfortable and fast method?
What about a such fastest method during live cd session, where all stuff are by default?
If it is not right method to learn what command is and it’s settings, than all --help are wrong also.
If that learn method is right, than the manjaro-live have the pointed issue. Enter your choice:
Not every executable in the system has a man page or a built-in help option.
man pages are for tools that can be executed via the command line without needing a GUI, and help options are at the discretion of the developer of each executable ─ it is up to them whether or not the executable will support it.
The --help option did not cause any “modifications” ─ whatever you mean by that. It is simply not a supported command line option on the manjaro-live executable, because said executable is ─ as @Strit said ─ intended to be run when the live USB/CD/DVD boots; it is not intended to be invoked manually.
I thought that both @Strit and I had been clear; the executable manjaro-livedoes not have a help option, because it is not intended to be run by a user.
In other words, what you are complaining about is completely irrelevant and stems from your lack of understanding the system.
