Greetings!
On manjaro github DEs show 2 iso files: iso.z01 + iso.zip. Simple question: how do I merge these 2 files into 1 .iso file? Thanks for your help.
Should be able to extract it (from the .zip
file), as long as both files are in the same directory, as is normally the case for multipart archives.
EDIT:
7z x manjaro-unity7-22.0.r202212021811-221202-linux60.iso.zip
.iso
files are an immutable format, by which I mean that they are read-only filesystem images that cannot be modified once the .iso
file has been created.
Therefore, you will need to mount the .iso
via a loopback device, copy all of its contents over to a different working directory, make your modifications to those contents, and then create a new .iso
file from them.
A valiant effort at answering their question… but they did not word the thread title properly.
Indeed not. At second glance, the OP is not even talking about .iso
files.
@snowdust: Download those two files and use the file
command to tell you what type of files they are. The .zip
file should be obvious already, but I for one do not know what the other file is, and I am willing to wager a fairly educated guess that you don’t either.
Here’s a golden piece of advice…: Never begin doing something without knowing and understanding what you are doing.
It’s a multipart archive.
As long as all files (.z01
, .z02
, .z03
, etc) are present in the same folder as the main .zip
file, you can simply extract the main .zip
file and it will automatically detect the other parts of the archive to decompress the contents within.
Im, also just like @winnie, fairly certain that unzipping the zip
file will “pull-in” the other part, and result in one single .iso
file…
So @Aragorn if you ask me go ahead and mark reply 2 as the solution after renaming the topic title
Done.
First I will reference this link
Now, the correct answer is to use the cat command in terminal to merge the 2 iso files, in other words …iso.z01 + …iso.zip
cat manjaro-unity7-…linux60.iso.z01 manjaro-unity7-…linux60.iso.zip >> mergedmanjaro-unity7.iso.zip
The following step is to unzip the merged file. In a terminal window, simply type:
unzip mergedmanjaro-unity7.iso.zip
Now you have the complete file.iso ready for transfer to a USB key with the dd command.
Also noteworthy, all community iso’s have 2 zip files. Have a look: Releases · manjaro/community-editions · GitHub
Why? Github rule states that files are limited to 2Gs.
As the original OP, I now declare this topic closed and SOLVED.
Why cat
the two files together first?
Multipart archives are designed to work like normal as long as all parts are present in the same directory.
You don’t need to do anything special, nor use extra steps (like cat
) to create a new .zip
file to then later extract.
It’s as simple as this:
Done.
You just need to make sure all parts are present in the same folder.
Here’s proof:
All files of the multipart archive in the same folder:
ls -1
manjaro-unity7-22.0.r202212021811-221202-linux60.iso.z01
Extract the .zip
file:
Now the .iso
is fully extracted.
ls -1
And it even passes the checksum, using the SHA256 hash to confirm its integrity.
Using cat
to create yet another huge extraneous .zip
file, and then extracting that new large .zip
file is a complex method when you can just do it in a single command:
At least edit your post and use preformatted text for your commands so it doesn’t look like garbage.
You couldn’t have solved this topic in a more worse case as you have done now.
YOUR SOLUTION IS COMPLETLY WRONG !
Thanks for filling this forum with false info.
