Combination keys with right Alt key not working
Recently I discovered right ALT + F4 is not working but left ALT + F4 is working. Not only that, any combination key with right ALT is not working. I have configured ALT + T is for konsole, it only works left ALT key.
Here is the system information
Output of inxi -Ga
$ inxi -Ga
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
    chip-ID: 10de:1f91 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:2
    chip-ID: 13d3:56a2 class-ID: 0e02 serial: 0x0001
  Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: Najing CEC Panda 0x0036 built: 2018 res: 1920x1080
    hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e9b memory: 15.11 GiB unified: yes
  API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1650 driver: nvidia v: 545.29.06
    device-ID: 10de:1f91 surfaces: xcb,xlib
xev logs from Right ALT + A
 FocusIn event, serial 36, synthetic NO, window 0x3e00001,
    mode NotifyNormal, detail NotifyNonlinear
KeymapNotify event, serial 36, synthetic NO, window 0x0,
    keys:  100 0   0   0   0   0   0   0   0   0   0   0   0   0   0   0
PropertyNotify event, serial 36, synthetic NO, window 0x3e00001,
    atom 0x197 (_NET_WM_STATE), time 34319680, state PropertyNewValue
KeyPress event, serial 36, synthetic NO, window 0x3e00001,
    root 0x964, subw 0x0, time 34323163, (-692,648), root:(169,1079),
    state 0x10, keycode 108 (keysym 0xfe03, ISO_Level3_Shift), same_screen YES,
    XKeysymToKeycode returns keycode: 92
    XLookupString gives 0 bytes:
    XFilterEvent returns: False
KeyRelease event, serial 36, synthetic NO, window 0x3e00001,
    root 0x964, subw 0x0, time 34323264, (-692,648), root:(169,1079),
    state 0x90, keycode 108 (keysym 0xfe03, ISO_Level3_Shift), same_screen YES,
    root 0x964, subw 0x0, time 34323630, (-692,648), root:(169,1079),
    root 0x964, subw 0x0, time 34323751, (-692,648), root:(169,1079),
    root 0x964, subw 0x0, time 34327066, (-692,648), root:(169,1079),
    root 0x964, subw 0x0, time 34329022, (-692,648), root:(169,1079),
    state 0x90, keycode 38 (keysym 0x61, a), same_screen YES,
    XLookupString gives 1 bytes: (61) "a"
    root 0x964, subw 0x0, time 34329188, (-692,648), root:(169,1079),
    root 0x964, subw 0x0, time 34333582, (-692,648), root:(169,1079),
FocusOut event, serial 36, synthetic NO, window 0x3e00001,
    atom 0x197 (_NET_WM_STATE), time 34336495, state PropertyNewValue
xev logs from Left ALT + A
    keys:  0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0
    atom 0x197 (_NET_WM_STATE), time 34556257, state PropertyNewValue
    root 0x964, subw 0x0, time 34558006, (-431,332), root:(430,763),
    state 0x10, keycode 64 (keysym 0xffe9, Alt_L), same_screen YES,
    root 0x964, subw 0x0, time 34558157, (-431,332), root:(430,763),
    state 0x18, keycode 64 (keysym 0xffe9, Alt_L), same_screen YES,
    root 0x964, subw 0x0, time 34558431, (-431,332), root:(430,763),
    root 0x964, subw 0x0, time 34558560, (-431,332), root:(430,763),
    root 0x964, subw 0x0, time 34558789, (-431,332), root:(430,763),
    root 0x964, subw 0x0, time 34559239, (-431,332), root:(430,763),
    state 0x18, keycode 38 (keysym 0x61, a), same_screen YES,
    root 0x964, subw 0x0, time 34559369, (-431,332), root:(430,763),
    root 0x964, subw 0x0, time 34560010, (-431,332), root:(430,763),
    root 0x964, subw 0x0, time 34560122, (-431,332), root:(430,763),
    root 0x964, subw 0x0, time 34560508, (-431,332), root:(430,763),
    atom 0x197 (_NET_WM_STATE), time 34561116, state PropertyNewValue
Aren’t “Alt” and “Alt Gr” different keys?
Hi @tbhaxor,
AFAIK in Plasma, you have to configure both. So probably Konsole as well.
Hope this helps!
Edit:
They are, but not all keyboards have the AltGr key. For example, mine doesn’t…
You have Alt Gr or right Alt set to third level shift. You can change this in System Settings.
System Settings → Input Devices → Keyboard → Advanced → Key to choose the 3rd level
You may need to set it to “Right Alt never chooses 3rd level”.
