Everything is ok – in first case it uses your locale, in second it uses byte comparison (so < is first, because it’s 60 in ASCII, while >=62). You can add –debug flag to sort to see what rules was used
$ echo "< a\n< z\n> d" | LC_ALL='' sort --debug
sort: tekst uporządkowany przez użycie reguł sortowania `pl_PL.UTF-8'
< a
___
> d
___
< z
___
$ echo "< a\n< z\n> d" | LC_ALL='C' sort --debug
sort: text ordering performed using simple byte comparison
< a
___
< z
___
> d
___
*** WARNING *** The locale specified by the environment affects
sort order. Set LC_ALL=C to get the traditional sort order that
uses native byte values.
And there is more detail here about the possibility of a locale sort-order ignoring, for instance, punctuation (and I suppose < and > can maybe be thought of as punctuation):
