So today I installed Code Blocks to check it out and got an error after trying to run an hello world c project. In the end it turned out, that Code Blocks tried to run “xterm -T …” to run the compiled program, but xterm was not installed on my machine. After installing xterm everything was fine.
Since I still have much to learn linux wise, is this simply a missing package dependency in the codeblocks pagacke, or is the error on my end, because I somehow uninstalled xterm and applications assume that xterm is always there, or something entirely different?
And if it is indeed a missing package dependency, where can I fix or report it?
The first thing I do for any application is go through all “Settings” or “Preferences” depending on what they call them
I opened up pamac, searched for codeblock, and selected it. In the details is the home address for the package, http://codeblocks.org. You can also get this information from the commandline: pacman -Si codeblocks.
In firefox I do a site search. In the firefox address bar (I use duckduckgo search engine), I typed xterm site:https://www.codeblocks.org and the first entry was “How do you use Gnome Terminal instead of Xterm”.
