I am trying to install virtual desktop bar widget and I am getting this error.
CMake Error: CMake was unable to find a build program corresponding to "Unix Makefiles". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
-- Configuring incomplete, errors occurred!
Any solution??
Iām not sure that whatever you here showed a part of
is how widgets are installed in KDE.
What did you do (to get these messages)?
You are trying to compile something.
What?
How?
⦠why? ā¦
ah thanks for help
sudo pacman -S base-devel
solved the issue
