Hi there just wanted to report that qt6-base:cmake-gui should be installed with cmake by default and not optional dependency othewrwise cmake-gui does not work and missing qt6-widgets
[corey@corey-pi4 ~]$ cmake-gui %f
cmake-gui: error while loading shared libraries: libQt6Widgets.so.6: cannot open shared object file: No such file or directory
After installing the “optional dependency” it fixes the issue and cmake-gui now runs.
But the PKGBUILD does say that you need qt6-base if you want to use cmake-gui.
Cmake-GUI is not a required part of cmake. So I think that’s why it’s an optional dependency.
