i wanted to use cmake to buil torrent client software on 5.8.18-1-MANJARO
1st installed this: sudo pacman -S base-devel cmake ninja libtorrent-rasterbar openssl boost geoip qt5-base qt5-svg qt5-tools zlib
then download the files: git clone https://github.com/qbittorrent/qBittorrent
then cmake build: cd qBittorrent;cmake -G "Ninja" -B build -DCMAKE_BUILD_TYPE=Debug;cmake --build build
Result is that it does not have newest libtorrent-rasterbar package:
– Package dependency requirement ‘libtorrent-rasterbar >= 1.2.11’ could not be satisfied.
Package ‘libtorrent-rasterbar’ has version ‘1.2.10’, required version is ‘>= 1.2.11’
CMake Error at src/CMakeLists.txt:7 (message):
Package LibtorrentRasterbar >= 1.2.11 not found with CMake or pkg-config.
Set LibtorrentRasterbar_DIR to a directory containing a
LibtorrentRasterbarConfig.cmake file or add the installation prefix of
LibtorrentRasterbar to CMAKE_PREFIX_PATH.
Alternatively, make sure there is a valid libtorrent-rasterbar.pc file in
your system’s pkg-config search paths (use the system environment variable
PKG_CONFIG_PATH to specify additional search paths if needed).
Neither any Manjaro branch nor even Arch provide such a version.
You have to get it from, for example, the aur package libtorrent-rasterbar-git.
Ex:
$ yay libtorrent-rasterbar
5 aur/libtorrent-rasterbar-git 2.0.0.RC.r584.ge0d9d7791-1 (+5 0.14)
A C++ BitTorrent library that aims to be a good alternative to all the other implementations around (git version)
(though the Arch package has been flagged out-of-date so there might be an update sometime … oops scratch that, Arch-Testing is on 1.2.10-6, so 1.2.11 probably isnt coming very soon)
Thank you @cscs . I had no “yay” utility, so i ran “pamac search -a libtorrent-rasterbar”
libtorrent-rasterbar-git 2.0.0.RC.r584.ge0d9d7791-1 AUR
libtorrent-rasterbar-2_0-git r16764.gf726d1089-1 AUR
A feature complete C++ bittorrent library (git branch RC_2_0) libtorrent-rasterbar-1_2-git r16764.g0ad0f29ab-1 AUR
A feature complete C++ bittorrent library (git branch RC_1_2)
libtorrent-rasterbar-1_1-git 1.1.14.r4.g760f94862-1 AUR
A feature complete C++ bittorrent library (git branch RC_1_1)
libtorrent-rasterbar-1_0-git 1.0.11.r9.g62c96797a-1 AUR
A C++ BitTorrent library that aims to be a good alternative to all the other implementations around (git branch RC_1_0)
libtorrent-rasterbar [Installed] 1:1.2.10-2 extra
i installed first one: $ pamac build libtorrent-rasterbar-1_2-git
(it removed libtorrent-rasterbar 1:1.2.10-2 extra)
and cmake now appears to completed without any fatal error.
After i finish debugging that software i am building, i guess i should remove the just installed git version (pamac remove libtorrent-rasterbar-1_2-git) so normal version is used.
