Cmake error installing rstudio-desktop
I am getting the following error while installing rstudio-desktop with the command:
yay -S rstudio-desktop
Building SOCI...
CMake Error at CMakeLists.txt:13 (cmake_minimum_required):
  Compatibility with CMake < 3.5 has been removed from CMake.
  Update the VERSION argument <min> value.  Or, use the <min>...<max> syntax
  to tell CMake that the project requires at least <min> but has been updated
  to work with policies introduced by <max> or earlier.
  Or, add -DCMAKE_POLICY_VERSION_MINIMUM=3.5 to try configuring anyway.
It seems SOCI package is not aware of CMake 4.0
Common issue since CMake 4.0 which can be avoided with the flag -DCMAKE_POLICY_VERSION_MINIMUM=3.5 (same error in another package How to fix cmake < 3.5 compatibility error - #7 by Yochanan)
I have commented on the AURweb page AUR (en) - rstudio-desktop
but is not the only issue AUR (en) - rstudio-desktop
btw the issue is that it have cmake minimum required version too low, with cmake 4.0 it want at least 3.5
Thanks @Lolix , for me it works now. I am not sure what other issues are you talking about?
https://aur.archlinux.org/packages/rstudio-desktop#comment-1022044
/build/rstudio-desktop/src/build/_deps/yaml-cpp-src/src/emitterutils.cpp:221:11: error: ‘uint16_t’ was not declared in this scope
  221 | std::pair<uint16_t, uint16_t> EncodeUTF16SurrogatePair(int codePoint) {
/build/rstudio-desktop/src/build/_deps/yaml-cpp-src/src/emitterutils.cpp:13:1: note: ‘uint16_t’ is defined in header ‘<cstdint>’; this is probably fixable by adding ‘#include <cstdint>’
   12 | #include "yaml-cpp/null.h"
  +++ |+#include <cstdint>
   13 | #include "yaml-cpp/ostream_wrapper.h"
Xiota updated with update depends - aur.git - AUR Package Repositories,
adding also -DRSTUDIO_USE_SYSTEM_YAML_CPP=ON
Is possible that you didn’t encounter it because you’re still on GCC 14 (I’m an Arh and already on GCC 15)
