Hi, I’m trying to compile a program to convert CK3 save files to EU4 save files. But I’m getting an error, because it looks like CMake is looking for packages called “gcc-11” and “g+±11”.
Now, I have gcc and g++ installed. I even double checked manually in my /usr/bin folder to make sure they were there in case something weird had happened. The issue seems to be that the packages I have installed are called “gcc” and “g++”, not “gcc-11” or “g+±11”.
Part of this was specified directly in one of the build scripts, so I edited it to fix that, but CMake itself still seems to be looking for gcc-11 and g+±11 after the initial point of looking at the compiler. I’m not even sure what could be causing this directly and I can’t seem to find any leads online (every similar error seems to just be people completely not having gcc or g++ installed), the errors are pretty arcane to me. Hopefully y’all can decipher them and help me figure out what the problem is. Thanks for y’all’s help!
~/Manual Apps/CK3toEU4: sudo ./build_linux.sh
-- The C compiler identification is GNU 11.1.0
-- The CXX compiler identification is GNU 11.1.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found CURL: -lcurl (found version "7.80.0")
-- Found wxWidgets: -pthread;;;-lwx_baseu_net-3.0;-lwx_gtk2u_core-3.0;-lwx_baseu-3.0 (found version "3.0.5")
-- Configuring done
-- Generating done
-- Build files have been written to: /home/amberabit/Manual Apps/CK3toEU4/Fronter/Fronter/build
[ 3%] Building CXX object CMakeFiles/Fronter.dir/Source/Configuration/Mod.cpp.o
[ 6%] Building CXX object CMakeFiles/Fronter.dir/Source/Configuration/Configuration.cpp.o
[ 9%] Building CXX object CMakeFiles/Fronter.dir/Source/Configuration/RequiredFile.cpp.o
[ 15%] Building CXX object CMakeFiles/Fronter.dir/Source/Frontend.cpp.o
[ 12%] Building CXX object CMakeFiles/Fronter.dir/Source/Configuration/RequiredFolder.cpp.o
/bin/sh: line 1: g++-11: command not found
make[2]: *** [CMakeFiles/Fronter.dir/build.make:104: CMakeFiles/Fronter.dir/Source/Configuration/Mod.cpp.o] Error 127
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [CMakeFiles/Fronter.dir/build.make:90: CMakeFiles/Fronter.dir/Source/Configuration/Configuration.cpp.o] Error 127
make[2]: *** [CMakeFiles/Fronter.dir/build.make:118: CMakeFiles/Fronter.dir/Source/Configuration/RequiredFile.cpp.o] Error 127
make[2]: *** [CMakeFiles/Fronter.dir/build.make:76: CMakeFiles/Fronter.dir/Source/Frontend.cpp.o] Error 127
make[2]: *** [CMakeFiles/Fronter.dir/build.make:132: CMakeFiles/Fronter.dir/Source/Configuration/RequiredFolder.cpp.o] Error 127
[ 18%] Building CXX object CMakeFiles/Fronter.dir/Source/Configuration/Options/CheckBoxOption.cpp.o
make[2]: *** [CMakeFiles/Fronter.dir/build.make:146: CMakeFiles/Fronter.dir/Source/Configuration/Options/CheckBoxOption.cpp.o] Error 127
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/Fronter.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
