Hi,
Clonezilla, wich was working perfectly until recently, has stopped working for me after recent updates, on 2 machines :
- An Intel Machine running Manjaro KDE x86_64 (stable branch) with Clonezilla 3.35.2-4
- A Pinebook Pro running Manjaro KDE ARM (arm-testing branch) with Clonezilla 3.35.2-5
I assume the issue is not due to Clonezilla itself as Clonezilla 3.35.2-4 was working previously, but to updates to other pieces of software.
The issue shows as :
- Open a terminal
- su as root
- start “clonezilla”
- You get the 1st choice screen
- Select any option
- You get :
❯ clonezilla
grep: warning: stray \ before /
/usr/bin/clonezilla: line 46: 20459 Aborted (core dumped) $DIA --backtitle “$msg_nchc_free_software_labs” --title “$msg_nchc_clonezilla” --menu “$msg_clonezilla_is_free_and_no_warranty \n$msg_hint_multiple_choice_select_by_space \n$msg_device_image_device_clone. \n$msg_lite_server_and_client_are_provided \n$msg_choose_mode:” 0 0 0 $DIA_ESC “device-image” “$msg_device_image_clone” “device-device” “$msg_device_device_clone” “remote-source” “$msg_remote_clone_source” “remote-dest” “$msg_remote_clone_destination” $lite_server_msg_1 $lite_server_msg_2 $lite_client_msg_1 $lite_client_msg_2 2> $TMP
Clonezilla mode is free(): invalid pointer
“free(): invalid pointer” is an unknown or unsupported type! You have to specify a correct ocs_live_type (device-image or device-device)!
Program terminated!!
This is extremely bad for me as it is a tool I use quite a lot and badly need…
