This is the first time I’m having such an issue.
Whenever I resume my system from suspend, the clock is behind by 5-10 minutes.
Issuing this command: sudo systemctl restart openntpd.service temporarily fixes the issue, but then comes back up when resuming next time.
Could someone guide me to check if this is a software issue?
You must be the only one that uses that, and installed openntpd separately, as most people will use the default systemd-timesyncd.service … and not both at the same time either …
