Clipboard Manager loses what was copied after source-application was closed
Strange behaviour of copyq or xfce4-clipman:
How to reproduce:
In Manjaro-stable XFCE open a browser, copy some text, close(!!) browser and try immediatly to paste somewhere. The clipboard history loses the activated item.
Long ago but still true for my XFCE: Same issue
What is most confusing me. This issue does not occur on a Debian XFCE 4.16 in VirtualBox or a HD install of Deepin. All with copyq as clipboard-manager
So i think there is something special with Manjaro XFCE
Generated on 2022-04-18 20:28:1650306489
#################### inxi -Fxzc0 ########################
  Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0 Desktop: Xfce v: 4.16.0
  Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: <superuser required>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO
    v: BYCN39WW date: 05/28/2021
  ID-1: BAT0 charge: 62.0 Wh (94.9%) condition: 65.3/62.0 Wh (105.3%) volts: 17.0 min: 15.4
    model: LGC L19L4PD2 status: full
  Info: quad core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5 cache:
    L1: 320 KiB L2: 2 MiB L3: 8 MiB
  Speed (MHz): avg: 1172 high: 1202 min/max: 400/3900 cores: 1: 1200 2: 1201 3: 1200 4: 1190
    5: 1100 6: 1140 7: 1202 8: 1150 bogomips: 23968
  Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia v: 510.60.02
    bus-ID: 2b:00.0
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 3-5:5
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting,nvidia unloaded: nouveau
    gpu: i915 resolution: 1: 1920x1080~60Hz 2: N/A
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci-intel-icl
    bus-ID: 00:1f.3
  Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.49 running: yes
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 2-1.4:4
  IF: enp0s13f0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: pan1 state: down mac: <filter>
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:8
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 1.86 TiB used: 310.99 GiB (16.4%)
  ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB temp: 54.9 C
  ID-2: /dev/sda type: USB vendor: Western Digital model: WD10EARX-00N0YB0 size: 931.51 GiB
  ID-3: /dev/sdb type: USB vendor: Kingston model: DataTraveler 2.0 size: 14.54 GiB
  ID-1: / size: 57.9 GiB used: 32.84 GiB (56.7%) fs: ext4 dev: /dev/nvme0n1p8
  ID-2: /boot/efi size: 259.5 MiB used: 113.6 MiB (43.8%) fs: vfat dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 16.67 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p9
  System Temperatures: cpu: 45.0 C mobo: N/A
  Processes: 260 Uptime: 11m Memory: 15.2 GiB used: 1.91 GiB (12.6%) Init: systemd Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: 1749 Client: Unknown Client: wrapper-2.0 inxi: 3.3.15
Compare options for the xfce4-clipman-plugin.
Did you test it on XFCE 4.16?
I just used the default settings. Which setting should i change?
Just bootup manjaro-xfce-21.2.1-220103-linux515.iso and there xfce-clipman works as aspected!
No idea what todo next :frowning:
only google-chrome-stable does clear clipboard on exit. Firefox does NOT do that.
Its not unusual on Linux to do that, but where can i change that?
… giving up :frowning:
