bh4eh
9 January 2025 18:43
1
I came across a gnome-shell-extension-battery-health-charging on pamac / AUR AUR (en) - gnome-shell-extension-battery-health-charging-git . This is what I have been looking for for the past 2 months. Imagine my disappointment when I was told the extension is not compatible with my machine I am using Manjaro Gnome, Ver 47, on a Clevo, Notebook NS5x_NS7xPU, Intel i7120-1260P x 16, Kernel 6.6.65. Tried TLP, doesn’t work. Tried Upower, doesn’t work. Anybody got any Ideas? The objective is either; a) automatically limit charging to between 20% and 80% when plugged into AC
OR
b) give me flags / notifications when 20% or 80% are reached when unplugged or plugged in respectively
with the basic plan to limit the battery charging cycles and thus extend the lifespan of the battery. I have something similar on my Android phone that does the job - GitHub - vbresan/HealthyBatteryCharging: Prolong the battery life of your android phone by keeping it charged between 40% and 80%
Any help, suggestions, from anyone, especially from @maniacx or @yochananmarqos would be great.
Thanks
Teo
9 January 2025 18:59
2
Warning, popup and flags can be scripted regardless of desktop or hardware. But it will not help much. You will still make a cycle if you unplug. Wearing the battery just in a different way.
The real solution is to cut the charging at 80% and that is entirely dependend on the hardware in the motherboard and bios. You cannot make it with purely software tools.
banjo
9 January 2025 19:21
3
I don’t use gnome and don’t have a clevo.
What is the output of
ls /sys/class/power_supply/BAT0 | grep charge
BG405
9 January 2025 20:32
4
Indeed.
This machine (Lenovo T440 ThinkPad) supports it — and I have set charge thresholds — but the other (the IdeaPad) does not; neither do several old scraptops. I think the Dell 1525 does but the battery for that was barely serviceable anyway when I acquired it. Always used on AC with the battery used like a UPS.
You are more likely to find this feature on business-grade machines (like the T440) than on consumer-grade ones (like the IdeaPad).
Teo
9 January 2025 20:44
5
Nowadays it is more and more common, 10 years ago it was pretty much thinkpad exclusive, now it has trickled down to many ideapads, some asus, acers, dells. No idea about hp. But the smaller companies like clevo, one has to do his own research. Probably not, because it is one more controller and makes the motherboard more expensive with maybe a dollar or so and that matters in the emerging smaller brands like clevo - they have to be cheaper lacking a very recognizable brandname.
A good starting point is to see if the laptop is sold with winboze oem and what oem software suite comes with it. If it is available in the proprietary soft there it is hardware supported and the only question is can it be exposed in acpi on linux, it is a matter of drivers and reverse engineering.
dhs
9 January 2025 21:24
6
Have you looked into the laptop’s BIOS settings? Two of my laptops (Toshiba, HP) have 80% charging limit settings in BIOS.
BG405
9 January 2025 21:30
7
An example of what I see in Plasma:
I don’t use Gnome, but there should be something similar?
bh4eh
9 January 2025 22:44
12
Thanks @Teo
You’ve pretty much summarised what I understand needs to be done. Particularly to cut charging at ~ 80%. My next step is to try and establish whether my motherboard / BIOS can handle the power management. Presumably through the Intel ACPI.
charge_full
charge_full_design
charge_now
Thanks @dhs
I looked at the BIOS but couldn’t find any battery management settings. Hence, I’ve been wondering if I can get an updated / extended BIOS from Insyde. dmidecode tells me:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
There is mention of “winboze” in the BIOS though I bought it ‘bare bones’ from Clevo in Germany (who appears to have disappeared) and requested a Manjaro installation done by them. Seems like I should have done more research before buying.
@BG405 Perhaps I should try Plasma. If I could get that, I’d be a happy man.
Mod note : I’ve concatenated (merged) your posts to keep things tidy on the Forum. Please let us know if you would like things done differently!
Typically it would be better to request that help and/or suggestions on the respective GitHub sites.
However, we may have the next best thing: @Yochanan
Plus, some useful System information could be helpful.
inxi --admin --verbosity=8 --filter --no-host --width
Only a few vendors have support for charging within specific parameters to avoid deep discharge or overcharge.
This has been known for years and one of the reasons I created a utility script for such systems.
A recent topic caused me to add the following script to my toolbox.
Battery Charge Notifier | root.nix.dk
The script is configurable and uses an interval and lower/upper threshold for battery.
The script utilizes libnotify to send a system message when outside the limits - thus ensuring you don’t forget to plug or unplug your laptop charger.
Script
Create the local bin folder
mkdir ~/.local/bin
Create a new file and make it executable
touch ~/.local/bin/charge-notify.sh && chmod +x ~/.…
bh4eh
10 January 2025 17:36
16
@soundofthunder
a) concatenated posts are fine with me. thanks
b) thanks for your post and help. I am intrigued to know what the next best thing is. I hope @Yochanan can solve my challenges
Here’s info on
Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=79b2c671-4620-4b24-a55f-7dfc0a208453 rw quiet splash apparmor=1
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: Notebook product: NS5x_NS7xPU v: N/A
serial: <superuser required> Chassis: No Enclosure type: 10
Mobo: Notebook model: NS5x_NS7xPU serial: <superuser required>
uuid: <superuser required> UEFI: INSYDE v: 1.07.09 date: 09/06/2022
ID-1: BAT0 charge: 38.0 Wh (71.8%) condition: 52.9/73.9 Wh (71.6%) volts: 7.8
min: 7.7 model: Notebook BAT type: Li-ion serial: <filter>
status: discharging
System RAM: total: 16 GiB available: 15.33 GiB used: 4.87 GiB (31.8%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 16 GiB speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Patriot Memory (PDP Systems) part-no: PSD416G320081S
serial: <filter>
Device-2: Controller1-ChannelA-DIMM0 type: no module installed
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x435
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 552 min/max: 400/4700:3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 552 2: 552 3: 552 4: 552 5: 552 6: 552 7: 552
8: 552 9: 552 10: 552 11: 552 12: 552 13: 552 14: 552 15: 552 16: 552
bogomips: 79888
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-P Integrated Graphics vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Xe process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:4626 class-ID: 0300
Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 04f2:b6f9
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x07d8 built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 chroma: red: x: 0.651 y: 0.345 green: x: 0.333 y: 0.620
blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:4626 memory: 7.49 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 2c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp44s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 1.4 TiB used: 273.85 GiB (19.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Patriot model: M.2 P400 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V1.1A temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Patriot model: M.2 P300 1024GB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 400fAA13 temp: 35.9 C
scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 183.7 GiB (39.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:5
label: N/A uuid: 79b2c671-4620-4b24-a55f-7dfc0a208453
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4 label: N/A
uuid: 3ED5-682C
ID-3: /mnt/8316404c-66de-4c32-bdcf-0674f10e231f raw-size: 297.46 GiB
size: 292.7 GiB (98.40%) used: 90.15 GiB (30.8%) fs: ext4 dev: /dev/nvme1n1p1
maj-min: 259:1 label: Patriot 1T_backu
uuid: 8316404c-66de-4c32-bdcf-0674f10e231f
ID-4: /mnt/e6f42593-dce4-4cb6-b768-1ba239a168d9 raw-size: 656.41 GiB
size: 645.04 GiB (98.27%) used: 2 MiB (0.0%) fs: ext4 dev: /dev/nvme1n1p2
maj-min: 259:2 label: BH Extra uuid: e6f42593-dce4-4cb6-b768-1ba239a168d9
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-7:2 info: Chicony USB2.0 Camera type: video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b6f9 class-ID: 0e02 serial: <filter>
Device-2: 3-10:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1506 libs: 407 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://manjaro.kurdy.org/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
4: https://mirrors2.manjaro.org/stable/$repo/$arch
5: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.easyname.at/manjaro/stable/$repo/$arch
7: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 374
1: cpu: 50.0% command: ps pid: 20495 mem: 3.62 MiB (0.0%)
2: cpu: 4.1% command: gnome-shell pid: 1232 mem: 319.7 MiB (2.0%)
3: cpu: 4.0% command: firefox pid: 3662 mem: 561.5 MiB (3.5%)
4: cpu: 3.8% command: portmaster-core_v1-6-10 pid: 984
mem: 167.0 MiB (1.0%)
5: cpu: 1.1% command: nautilus pid: 14418 mem: 215.2 MiB (1.3%)
Memory top: 5 of 374
1: mem: 561.5 MiB (3.5%) command: firefox pid: 3662 cpu: 4.0%
2: mem: 473.8 MiB (3.0%) command: soffice.bin pid: 4696 cpu: 0.0%
3: mem: 319.7 MiB (2.0%) command: gnome-shell pid: 1232 cpu: 4.1%
4: mem: 286.4 MiB (1.8%) command: dmidecode started-by: masterpdfeditor5
pid: 7018 cpu: 0.0%
5: mem: 248.1 MiB (1.5%) command: firefox pid: 4889 cpu: 0.1%
Processes: 374 Power: uptime: 2h 53m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.12 GiB services: gsd-power,upowerd Init: systemd
v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: terminator inxi: 3.3.37
If any of that is helpful to suggest a solution, I’d be happy to hear it.
Thanks
bh4eh
10 January 2025 17:44
17
Thanks @linux-aarhus
a) yes, it seems a limited number of vendors provide the parameters out of the box
b) Charger Notifier script looks likely to give me my second option. Thanks. I’ll look into that soon
Thanks for your help
Well, as it turns out, our @Yochanan happens to be the very same:
that you linked to at GitHub.
So, no doubt he will see this topic in due course; especially now that we both have pinged him.
bh4eh
10 January 2025 17:48
19
Thanks for the clarification @soundofthunder Here’s hoping
He did and has already communicated with the developer of the Battery Health Charging extension, not sure why it wasn’t linked here thus far.
opened 10:18PM - 06 Jan 25 UTC
This is what I have been looking for for the past 2 months. Imagine my disappoin… tment when I was told the extension is not compatible with my machine :-( I am using Manjaro Gnome, Ver 47, on a Clevo, Notebook NS5x_NS7xPU, Intel i7120-1260P x 16, Kernel 6.6.65. Tried TLP, doesn't work. Tried Upower, doesn't work. Anybody got any Ideas? The objective is either; a) automatically limit charging to between 20% and 80% when plugged into AC
OR
with the basic plan to limit the battery charging cycles and thus extend the lifespan of the battery. I have something similar on my Android phone that does the job - https://github.com/vbresan/HealthyBatteryCharging
Any help, suggestions, especially from @maniacx or @yochananmarqos would be great.
Thanks
Indeed. The TLP documentation lists various hardware vendors that do: Battery Care Vendor Specifics — TLP 1.8.0 documentation
Either Clevo added support in their proprietary BIOS or they didn’t.
It appears the NS5x_NS7xPU may be the same or very close to the Tuxedo InfinityBook S 15 Gen 7 .
As maniax mentioned in the above issue, you might try Tuxedo’s drivers. They’re in the repo as tuxedo-drivers-dkms
. You can also install the GUI tool, tuxedo-control-center
bh4eh
6 February 2025 18:45
21
Hi @linux-aarhus
Thanks for your script. I’ve not yet had time (or courage, being pretty unfamiliar with this sort of thing) but wanted to let you know I will try it soon. Thanks again
Pippin
6 February 2025 20:06
22
The battery has a built-in BMS that protects against overcharge and deep-discharge (per cell!).
It also takes care of balancing the individual cells (called top balancing).
Typically per cell (Li-ion/LiPo) minimum voltage is set at 3V and maximum voltage at 4.2V.
Charging to 80% capacity makes you miss out on usage time per charge.
It can prolong usable lifespan but capacity will diminish after time (anyway) while not using 20% of that capacity.
It’s a trade-off depending on how one uses the laptop.
If the bios has this setting it communicates with the built-in BMS (inside the battery) which will adjust it’s settings accordingly.
It’s avoided anyway by the BMS.
I have not seen a laptop battery without BMS since like the Nicad/NiMH days.
bh4eh
6 February 2025 21:38
23
Thanks for that info. That’s useful to know. How can I check a) if the battery I bout has BMS and b) if it’s working?
BG405
6 February 2025 22:41
24
I’m wondering if this resource:
… will be of any help?
bh4eh
7 February 2025 12:26
25
Thanks @BG405 , I’ll have a read and see.
