sigen
1
I’d like to clear up my AUR library.
I apologize for the very basic questions that are about to follow, but I need to ask.
If I were to uninstall all AUR packages, could that affect Manjaro’s functionality and Manjaro’s official packages in any way?
If an AUR package is
Required By: None
and
Install Reason: Installed as a dependency for another package
Can I assume that in all likelihood it can be removed without affecting anything?
Thank you.
It shouldn’t, but it might, if a package that used to be in the repositories was moved out to the AUR.
If it was installed as a dependency for another package, then removing it will break that other package, unless it’s an optional dependency.
sigen
4
If pacman also says about it:
Optional for: None
Conflicts with: None
Replaces: None
then, is it an orphan and unnecessary?
To list custom packages using pacman
pacman -Qqem
The result can be piped into a file
sudo pacman -Qqem > pkglist.txt
Feed the list to pacman
sudo pacman -Rns - < pkglist.txt
