Clearing pacman's cache
Everytime I try to clear pacman’s cache I get the following error message even if I delete the database lock with the rm -rf /var/lib/pacman/db.lck command
sudo pacman -Scc
error: failed to init transaction (unable to lock database)
error: could not lock database: File exists
if you’re sure a package manager is not already
running, you can remove /var/lib/pacman/db.lck
AFAIK that requires root permissions:
sudo rm -rf /var/lib/pacman/db.lck
Yes of course I do it with sudo …
Problem solved on it’s own without doing anything different. Last 2 days I did the same thing
Didn’t look like it:
Provide the output you get when you run:
And if it didn’t work, there’s got to be some output with the reason as to why…
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Check man paccache
Well … it says something is running.
Are you sure nothing was/is? Like … pamac in the tray?
