Clean install, dual monitors won't work with Thinkpad dock
I’ve been using Manjaro for several years, and finally got around to wiping my laptop clean and starting with a fresh install. I did this because I originally used Gnome for years and around the beginning of the year, I switched to KDE by installing it within the existing install. It’s been working fine, but every once in a while, I’d have odd errors or app crash and startup would show problems with the disk / ext4 corruption. Figured, let’s just start clean, restore my files, and start anew.
I’m running a Thinkpad P52s connected to a Thinkpad dock (Thunderbolt 3 Dock Gen 2; DK1841). The dock supports 2 HDMI or 2 DisplayPort connections - I’m using the two HDMI ports.
Previously, this worked flawlessly. I connected the laptop to the dock, closed the lid, and I would get two monitors working correctly. Open the lid, only the laptop’s built-in display would work.
After the fresh install, I can’t get more than one monitor working. With both plugged into the dock, laptop’s built-in screen freezes and only one monitor works. The message at the top of the display configuration says that all monitors are disabled; enable at least one. If I move my mouse to the far upper-left, it will show the contents of all the windows for a brief moment, then the mouse freezes. Keep wiggling it, it will stutter.
Here’s what I’ve found through troubleshooting it:
  • Connected to the dock, two HDMI monitors connected:
    First monitor activates.
    Second monitor is off.
    Built-in display is frozen.
  • Connected to the dock, one HDMI monitor connected:
    External monitor activates.
    Built-in display operates normally. All is well.
  • Connected to the dock, one HDMI monitor connected to the HDMI output on laptop, only.
    Built-in display operates normally. All is wel.
  • Connected to the dock, one HDMI monitor connected to the HDMI output of laptop, other HDMI connected to Dock:
    (Same as the first entry above)
    First monitor activates (one connected to the HDMI output on side of laptop).
I’ve tried different versions of the Linux Kernal, and a few trial and errors with the Nvidia driver, to no avail.
  Info: quad core model: Intel Core i7-8650U bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 2601 min/max: 400/4200 cores: 1: 2601 2: 2601 3: 2601
    4: 2601 5: 2601 6: 2601 7: 2601 8: 2601
  Device-1: Intel Kaby Lake-R GT2 [UHD Graphics 620] driver: i915 v: kernel
  Device-2: NVIDIA GP108GLM [Quadro P500 Mobile] driver: nouveau v: kernel
  Device-3: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
    type: USB
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: modesetting dri: iris,nouveau
    gpu: i915 resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: iris,nouveau,swrast
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 26.1.4-arch1.1
    renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
  API: Vulkan v: 1.4.350 drivers: intel,nvk surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
The dock has a 135W power supply. Again, this worked before and has for at least the last six years.
Anyone have any suggestions? This screams to me that it’s a video driver issue, but not sure where to look to continue troubleshooting.
@Bad_Dog
Your inxi output is incomplete.
Please provide your system information according to forum guidelines: :point_down:
inxi -zv8 (short-form)
Your privacy is respected
Thank you. Here’s the full output, while connected to the dock (with only one external monitor connected).
  Kernel: 7.1.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.1-x86_64
    root=UUID=9f94d19d-88bd-4953-b15d-9fc1bb635da7 rw quiet
    cryptdevice=UUID=c0bc1b51-913d-4c05-a55d-3185f4bf3aa1:luks-c0bc1b51-913d-4c05-a55d-3185f4bf3aa1
    root=/dev/mapper/luks-c0bc1b51-913d-4c05-a55d-3185f4bf3aa1 quiet
    resume=/dev/mapper/luks-a65ea0da-0084-4678-82cd-41bf057ca2c9
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.6.6 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Laptop System: LENOVO product: 20LCS0UD00 v: ThinkPad P52s
    serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20LCS0UD00 v: SDK0J40697 WIN serial: <filter>
    part-nu: LENOVO_MT_20LC_BU_Think_FM_ThinkPad P52s
    uuid: 5de6594c-2551-11b2-a85c-95453dcaa6c7 Firmware: UEFI vendor: LENOVO
    v: N27ET54W (1.40 ) date: 08/21/2024
  ID-1: BAT0 charge: 28.5 Wh (89.3%) condition: 31.9/31.9 Wh (100%)
    volts: 16.35 min: 15.2 model: LGC 01AV493 type: Li-poly serial: N/A
    charging: status: not charging control: start: 75% end: 90% cycles: 3
  ID-2: BAT1 charge: 21.5 Wh (89.5%) condition: 24.1/24.1 Wh (100%)
    volts: 12.43 min: 11.4 model: SANYO 01AV424 type: Li-ion serial: <filter>
  System RAM: total: 32 GiB available: 31.06 GiB used: 5.79 GiB (18.6%)
    igpu: 64 MiB
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 2400 MT/s volts: curr: 1.2
    width (bits): data: 64 total: 64 manufacturer: SK Hynix
    part-no: HMA82GS6CJR8N-VK serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
    width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: CT16G4SFD824A.M16FRS serial: <filter>
  Slot: N/A type: MediaCard status: available length: other bus-ID: 00:00.0
  Slot: N/A type: N/A status: available length: other bus-ID: 00:00.0
  Info: model: Intel Core i7-8650U socket: BGA1356 (U3E1) note: check bits: 64
    type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
    microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 400 min/max: 400/4200 base/boost: 1900/2100 scaling:
    driver: intel_pstate governor: powersave volts: 1.2 V ext-clock: 100 MHz
    cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400
    bogomips: 33599
    sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
    vulnerable
  Device-1: Intel Kaby Lake-R GT2 [UHD Graphics 620] vendor: Lenovo
    ports: active: DP-3,eDP-1 empty: DP-1, DP-2, DP-4, DP-5, HDMI-A-1,
    HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: NVIDIA GP108GLM [Quadro P500 Mobile] vendor: Lenovo
    driver: nouveau v: kernel non-free: 550-580.xx+
    status: legacy-active (EOL~2028-09-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:1d33
    class-ID: 0302
  Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.1.4.2:85
    chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
  Device-4: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3
    chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
  Display: unspecified server: X.Org v: 24.1.13 with: Xwayland v: 24.1.13
    alternate: fbdev,vesa dri: iris,nouveau gpu: i915 display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: DP-3 pos: right model: Acer XV271U M3 serial: <filter>
    built: 2024 res: mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 82 gamma: 1.2
    chroma: red: x: 0.675 y: 0.314 green: x: 0.275 y: 0.671 blue: x: 0.149
    y: 0.047 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 2560x1440, 1920x1080, 1280x1024,
    1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 96 2: parse_edid:
    unhandled CEA mode 97
  Monitor-2: eDP-1 pos: primary,left model: Lenovo 0x40ba built: 2018 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
    x: 0.592 y: 0.369 green: x: 0.349 y: 0.557 blue: x: 0.153 y: 0.110 white:
    x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
    device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
    drv: nouveau surfaceless: drv: nouveau x11: drv: iris inactive: wayland
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
    GT2) device-ID: 8086:5917 memory: 30.33 GiB unified: yes
  API: Vulkan v: 1.4.350 layers: 2 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 620 (KBL GT2) driver: mesa intel v: 26.1.4-arch1.1
    device-ID: 8086:5917 surfaces: N/A device: 1 type: discrete-gpu
    name: Quadro P500 (NVK GP108) driver: mesa nvk v: 26.1.4-arch1.1
    device-ID: 10de:1d33 surfaces: N/A
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:9d71 class-ID: 0403
  Device-2: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-4.1.1.2:78 chip-ID: 17ef:30cf class-ID: 0300
    serial: <filter>
  API: ALSA v: k7.1.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.7 status: n/a (root, process) with:
  Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-3: Lenovo ThinkPad TBT 3 Dock driver: r8152 type: USB rev: 3.0
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.1.2:39
    chip-ID: 17ef:3082 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u4u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
    class-ID: e001
  Device-1: luks-c0bc1b51-913d-4c05-a55d-3185f4bf3aa1 maj-min: 253:0
    type: LUKS dm: dm-0 size: 1.81 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.81 TiB
  Device-2: luks-a65ea0da-0084-4678-82cd-41bf057ca2c9 maj-min: 253:1
    type: LUKS dm: dm-1 size: 8.8 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
  Local Storage: total: 1.82 TiB used: 561.72 GiB (30.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 31.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 2y 133d 9h cycles: 513
    read-units: 53,108,355 [27.1 TB] written-units: 41,008,296 [20.9 TB]
  ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 561.71 GiB (30.3%)
    fs: f2fs block-size: 4096 B dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-c0bc1b51-913d-4c05-a55d-3185f4bf3aa1 label: N/A
    uuid: 9f94d19d-88bd-4953-b15d-9fc1bb635da7
    used: 696 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 2C20-FED2
  ID-3: /mnt/Scan-upload raw-size: N/A size: 343.94 GiB
    used: 30.81 GiB (9.0%) fs: cifs dev: /dev/scanned-docs-upload
  ID-4: /mnt/Torrents raw-size: N/A size: 1.92 TiB used: 1.77 TiB (91.9%)
    fs: cifs dev: /dev/torrents
  ID-5: /mnt/Vera2 raw-size: N/A size: 1.25 TiB used: 731.37 GiB (57.2%)
    fs: cifs dev: /dev/vera2
  ID-6: /mnt/Vid2 raw-size: N/A size: 9.69 TiB used: 8.92 TiB (92.1%)
    fs: nfs4 remote: 192.168.10.22:/mnt/Videos2
  ID-1: swap-1 type: partition size: 8.8 GiB used: 4 KiB (0.0%) priority: -1
    dev: /dev/dm-1 maj-min: 253:1
    mapped: luks-a65ea0da-0084-4678-82cd-41bf057ca2c9 label: swap
    uuid: 1dbf36e3-306f-4b6e-b4ed-cb785a8c23e4
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-4:70 info: Lenovo USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:3080
  Hub-3: 1-4.1:71 info: VIA Labs VL820 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2820
  Hub-4: 1-4.1.1:74 info: Lenovo USB2.0 HUB ports: 2 rev: 2.0
    chip-ID: 17ef:3081 class-ID: 0900
  Device-1: 1-4.1.1.2:78 info: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 17ef:30cf class-ID: 0300 serial: <filter>
  Hub-5: 1-4.1.4:79 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-4.1.4.1:82 info: Ducky One 3 RGB type: HID,keyboard,mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1311 class-ID: 0300
    serial: <filter>
  Device-2: 1-4.1.4.2:85 info: Logitech C920 HD Pro Webcam type: video,audio
  Hub-6: 1-4.2:72 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Hub-7: 1-4.2.3:75 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
  Hub-8: 1-4.2.4:77 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
  Device-1: 1-4.5:73 info: VIA Labs 40AN type: billboard driver: N/A
    power: 100mA chip-ID: 2109:8887 class-ID: 1100 serial: <filter>
  Device-2: 1-7:2 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  Device-3: 1-8:3 info: Chicony Integrated Camera (1280x720@30) type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b604 class-ID: 0e02
    serial: <filter>
  Device-4: 1-9:4 info: Synaptics Metallica MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:009a class-ID: ff00 serial: <filter>
  Hub-9: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  Device-1: 2-3:2 info: Realtek Card Reader type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0316 class-ID: 0806
    serial: <filter>
  Hub-10: 2-4:33 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 17ef:307f
  Hub-11: 2-4.1:34 info: VIA Labs VL820 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0820
  Device-1: 2-4.1.2:39 info: Lenovo ThinkPad TBT 3 Dock type: Network
    driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 288mA chip-ID: 17ef:3082 class-ID: 0000
    serial: <filter>
  Hub-12: 2-4.1.4:36 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Hub-13: 2-4.2:35 info: Realtek Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-14: 2-4.2.3:37 info: Realtek Hub ports: 4 rev: 3.1
  Hub-15: 2-4.2.4:38 info: Realtek Hub ports: 4 rev: 3.1
  System Temperatures: cpu: 53.0 C mobo: N/A gpu: nouveau temp: 52.0 C
  Fan Speeds (rpm): fan-1: 3128
  Packages: pm: pacman pkgs: 1592 libs: 376 tools: pamac pm: flatpak pkgs: 0
    1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    3: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    4: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    5: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    6: https://mirrors2.manjaro.org/stable/$repo/$arch
    7: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 297
  1: cpu: 5.4% command: syncthing pid: 2087 mem: 133.7 MiB (0.4%)
  2: cpu: 4.0% command: firefox pid: 2925 mem: 869.1 MiB (2.7%)
  3: cpu: 1.5% command: kwin_wayland pid: 1525 mem: 260.0 MiB (0.8%)
  4: cpu: 1.3% command: firefox pid: 3156 mem: 726.5 MiB (2.2%)
  5: cpu: 0.8% command: thunderbird pid: 2574 mem: 814.6 MiB (2.5%)
  Memory top: 5 of 297
  1: mem: 869.1 MiB (2.7%) command: firefox pid: 2925 cpu: 4.0%
  2: mem: 814.6 MiB (2.5%) command: thunderbird pid: 2574 cpu: 0.8%
  3: mem: 726.5 MiB (2.2%) command: firefox pid: 3156 cpu: 1.3%
  4: mem: 565.0 MiB (1.7%) command: plasmashell pid: 1682 cpu: 0.2%
  5: mem: 381.5 MiB (1.1%) command: firefox pid: 49367 cpu: 0.8%
  Processes: 297 Power: uptime: 10h 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.34 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Sudo (sudo) v: 1.9.17p2
    default: Bash v: 5.3.15 running-in: yakuake inxi: 3.3.41
According to Nvidia’s driver search tool - the 580xx driver is the recommended driver to support your GPU.
To get the hybrid driver synced to your system
sudo mhwd -i pci video-hybrid-intel-nvidia-580xx-prime
Or you may install the driver manually by using either the kernel specific driver or the nvidia dkms driver (the latter requires kernel headers for the active kernel)
Nvidia 580xx packages in official repository
To get your current kernel run the mhwd-kernel command
mhwd-kernel -li
Install headers for your kernel linux<kernel>-headers and nvidia-580xx-dkms or install linux<kernel>-nvidia-580xx[-open] the [-open] is an option.
 $ pamac search nvidia-580xx --no-aur
opencl-nvidia-580xx  580.173.02-3                                   extra
    OpenCL implemention for NVIDIA 580xx
linux-nvidia-580xx-open-meta  7.1-1                                 extra
    Recommended stable nvidia-580xx-open kernel module
linux-nvidia-580xx-meta  7.1-1                                      extra
    Recommended stable nvidia-580xx kernel module
linux-lts-nvidia-580xx-open-meta  6.1-2                             extra
    Manjaro LTS nvidia-580xx-open kernel module
linux-lts-nvidia-580xx-meta  6.1-2                                  extra
    Manjaro LTS nvidia-580xx kernel module
linux72-nvidia-580xx-open  580.173.02-0.4                           extra
    NVIDIA open kernel modules for linux72
linux72-nvidia-580xx  580.173.02-0.4                                extra
    NVIDIA kernel modules for linux72
linux71-nvidia-580xx-open  580.173.02-7                             extra
    NVIDIA open kernel modules for linux71
linux71-nvidia-580xx  580.173.02-6                                  extra
    NVIDIA kernel modules for linux71
linux66-rt-nvidia-580xx-open  580.173.02-2                          extra
    NVIDIA open kernel modules for linux66-rt
linux66-rt-nvidia-580xx  580.173.02-2                               extra
    NVIDIA kernel modules for linux66-rt
linux66-nvidia-580xx-open  580.173.02-5                             extra
linux66-nvidia-580xx  580.173.02-5                                  extra
linux61-rt-nvidia-580xx-open  580.173.02-2                          extra
    NVIDIA open kernel modules for linux61-rt
linux61-rt-nvidia-580xx  580.173.02-2                               extra
    NVIDIA kernel modules for linux61-rt
linux61-nvidia-580xx-open  580.173.02-5                             extra
linux61-nvidia-580xx  580.173.02-5                                  extra
linux618-nvidia-580xx-open  580.173.02-6                            extra
    NVIDIA open kernel modules for linux618
linux618-nvidia-580xx  580.173.02-6                                 extra
    NVIDIA kernel modules for linux618
linux612-rt-nvidia-580xx-open  580.173.02-3                         extra
    NVIDIA open kernel modules for linux612-rt
linux612-rt-nvidia-580xx  580.173.02-3                              extra
    NVIDIA kernel modules for linux612-rt
linux612-nvidia-580xx-open  580.173.02-5                            extra
linux612-nvidia-580xx  580.173.02-5                                 extra
lib32-opencl-nvidia-580xx  580.173.02-2                          multilib
    OpenCL implemention for NVIDIA 580 (32-bit)
lib32-nvidia-580xx-utils  580.173.02-2                           multilib
    NVIDIA 580 drivers utilities (32-bit)
mhwd-nvidia-580xx  580.173.02-3 [Installed]                         extra
    MHWD module-ids for nvidia 580.173.02
nvidia-580xx-utils  580.173.02-3                                    extra
nvidia-580xx-settings  580.173.02-2                                 extra
    Tool for configuring the NVIDIA graphics driver (580xx)
nvidia-580xx-open-dkms  580.173.02-3                                extra
    NVIDIA 580 open kernel modules - module sources
nvidia-580xx-dkms  580.173.02-3                                     extra
    NVIDIA 580 kernel modules - module sources
Thank you. I installed the Nvidia driver (first set of instructions, not the manual method). No change - it’s still behaving the same way.
  Device-2: NVIDIA GP108GLM [Quadro P500 Mobile] driver: nvidia
    v: 580.173.02
    type: USB
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    unloaded: nouveau dri: iris gpu: i915 resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: iris,kms_swrast,nvidia,swrast
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 26.1.4-arch1.1
  API: Vulkan v: 1.4.350 drivers: intel,nvidia surfaces: N/A
I forget, but is there something else I need to do to prioritize one graphics card over another?
