docker images -q hthiemann/chromium-armhf:latest | head -n 1
Because the other error is this:
Searching for Docker image …
Found and using
“docker run” requires at least 1 argument.
Where there should be an image listed after “Found and using” … and it fails afterwards, as that variable was used in the rest of the run command.
So if the above returns nothing, as I suppose it will … then please attempt listing docker images or similar to expand on the situation.
Expand further? I know nothing about docker. I googled chromium docker won’t start Manjaro and found a couple web pages from the forums and tried to do what it says.
Sudo pacman -S chromium-docker is almost all I know other than adding user to docker group and flowing the picture of paprefs on the forum page
First off I do not maintain this package but I do know it works. It is increasingly looking like with out standing behind you and looking over your shoulder to see what you have or have not done it is going to be hard to diagnose your issue. Especially me since it is not my package and I never use it.
I have used it before and for whatever reason it isn’t. Its a fresh install. I followed all the steps to adjust groups and paprefs. I don’t know why it isn’t working I just know it doesn’t. Can’t get a browser window. But hey, if it works for everybody and not me so I just be full of crap huh? That seems to be the implied message.
@spikerguy just said it may need a new widevine. I never tested that part as I do not have any paid subscriptions. So looking like in the end it may not be useful at this time…
