This is my first post, kindly be polite with me …
I have tried installing flutter from the Add/Remove app, but there was no success…
so i decided to use this command [ sudo pamac build flutter
]to install it and from the first code that came it says:
Here is the output after everything
➜ ~ sudo pamac build flutter
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
Checking flutter dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
flutter 3.3.4-3 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Cloning flutter build files...
Running as unit: run-u82.service
Finished with result: success
Main processes terminated with: code=exited/status=0
Service runtime: 4.388s
CPU time consumed: 72ms
Generating flutter information...
Running as unit: run-u83.service
Service runtime: 2.328s
CPU time consumed: 2.587s
Building flutter...
Running as unit: run-u84.service
Press ^] three times within 1s to disconnect TTY.
==> Making package: flutter 3.3.4-3 (Wed 19 Oct 2022 05:01:12 PM GMT)
==> Retrieving sources...
-> Downloading flutter-3.3.4.tar.xz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 604M 100 604M 0 0 944k 0 0:10:55 0:10:55 --:--:-- 1458k
-> Found flutter.sh
-> Found flutter.csh
flutter-3.3.4.tar.xz ... Passed
flutter.sh ... Passed
flutter.csh ... Passed
==> Extracting sources...
-> Extracting flutter-3.3.4.tar.xz with bsdtar
==> Starting build()...
Downloading Linux x64 Dart SDK from Flutter engine c08d7d5efc9aa6eb3c30cfb3be6dc09bca5e7631...
100 204M 100 204M 0 0 2106k 0 0:01:39 0:01:39 --:--:-- 2108k
Building flutter tool...
║ Welcome to Flutter! - https://flutter.dev ║
║ The Flutter tool uses Google Analytics to anonymously report feature usage ║
║ statistics and basic crash reports. This data is used to help improve ║
║ Flutter tools over time. ║
║ Flutter tool analytics are not sent on the very first run. To disable ║
║ reporting, type 'flutter config --no-analytics'. To display the current ║
║ setting, type 'flutter config'. If you opt out of analytics, an opt-out ║
║ event will be sent, and then no further information will be sent by the ║
║ Flutter tool. ║
║ By downloading the Flutter SDK, you agree to the Google Terms of Service. ║
║ Note: The Google Privacy Policy describes how data is handled in this ║
║ service. ║
║ Moreover, Flutter includes the Dart SDK, which may send usage metrics and ║
║ crash reports to Google. ║
║ Read about data we send with crash reports: ║
║ https://flutter.dev/docs/reference/crash-reporting ║
║ See Google's privacy policy: ║
║ https://policies.google.com/privacy ║
Downloading Material fonts... 2,146ms
Downloading Gradle Wrapper... 183ms
Downloading android-arm-profile/linux-x64 tools... 1,118ms
Downloading android-arm-release/linux-x64 tools... 801ms
Downloading android-arm64-profile/linux-x64 tools... 1,377ms
Downloading android-arm64-release/linux-x64 tools... 900ms
Downloading android-x64-profile/linux-x64 tools... 3.2s
Downloading android-x64-release/linux-x64 tools... 972ms
Downloading android-x86 tools... 9.4s
Downloading android-x64 tools... 20.8s
Downloading android-arm tools... 10.8s
Downloading android-arm-profile tools... 5.5s
Downloading android-arm-release tools... 3.4s
Downloading android-arm64 tools... 8.1s
Downloading android-arm64-profile tools... 5.6s
Downloading android-arm64-release tools... 2,401ms
Downloading android-x64-profile tools... 6.6s
Downloading android-x64-release tools... 3.9s
Downloading android-x86-jit-release tools... 5.5s
Downloading Web SDK... 42.7s
Downloading CanvasKit... 4.9s
Downloading package sky_engine... 889ms
Downloading flutter_patched_sdk tools... 2,095ms
Downloading flutter_patched_sdk_product tools... 1,932ms
Downloading linux-x64 tools... 17.0s
Downloading linux-x64/linux-x64-flutter-gtk tools... 10.2s
Downloading linux-x64-profile/linux-x64-flutter-gtk tools... 4.6s
Downloading linux-x64-release/linux-x64-flutter-gtk tools... 6.1s
Downloading linux-x64/font-subset tools... 1,304ms
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing empty directories...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> WARNING: Package contains reference to $srcdir
opt/flutter/bin/cache/flutter_tools.snapshot
==> Creating package "flutter"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Adding install file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: flutter 3.3.4-3 (Wed 19 Oct 2022 05:23:43 PM GMT)
==> Cleaning up...
Service runtime: 22min 35.891s
CPU time consumed: 4min 30.532s
Running as unit: run-u90.service
Service runtime: 1.639s
CPU time consumed: 1.814s
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Installing flutter (3.3.4-3)... [1/1]
Flutter was installed on /opt/flutter
In case you encounter problems using Flutter as regular user, add your user into the group flutterusers:
gpasswd -a ${USER} flutterusers
Re-login your terminal in to the group flutterusers:
newgrp flutterusers
Run the following command to see if there are any dependencies you need to install to complete the setup (for verbose output, add the -v flag):
flutter doctor
Arming ConditionNeedsUpdate... [1/2]
Refreshing PackageKit... [2/2]
After running Flutter doctor
i got this feedback
fatal: detected dubious ownership in repository at '/opt/flutter'
To add an exception for this directory, call:
git config --global --add safe.directory /opt/flutter
rm: cannot remove '/opt/flutter/version': Permission denied
Even when i added the $USER to the grp
So now i want to know if those warnings can cause any issues on my system
thank you
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
