I tried to find a solution to failed clamAV update on the web and on Manjaro site and forum, without success.
The 2023_11-4 update included clamav.
They updated successfully, but clamav gave an error due
to missing dependency Electron17.
The uploaded pamac update log file:
“1st attempt - clamav missing dependencies 2023_11-3 @ 10-10am”.
is the 1st attempt at yesterday’s update.
I tried to install “Electron17” by itself,
it failed to install as well.
“2nd attempt - clamav update failed 2023_11-3-4”
(which has 23,663 lines of text)
is the 2nd attempt to update clamav after electron17 failure.
The uploaded picture “Clamav update info 2023_11-4.png”
is the pamac available updates listing of clamav.
I was able to install the other available updates by unchecking clamav.
So, is there a fix for the clamav error, or do I install an clamav alternative or something else?
Here is my system info:
[sudo] password for ultra:
Kernel: 6.5.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=121a5a27-095d-4c7a-8853-3a2b6e097b5c rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7B86 v: 3.0 serial: N/A
Mobo: Micro-Star model: B450 GAMING PLUS MAX (MS-7B86) v: 3.0
serial: <filter> UEFI: American Megatrends LLC. v: H.D3 date: 09/28/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 15.54 GiB used: 2.17 GiB (14.0%)
Device-1: DIMM 0 type: no module installed
Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2933 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: G.Skill part-no: F4-3200C16-8GVKB
serial: N/A
Device-3: DIMM 0 type: no module installed
Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
serial: N/A
Info: model: AMD Ryzen 5 2600 socket: AM4 bits: 64 type: MT MCP arch: Zen+
gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 1962 high: 3400 min/max: 1550/3400 boost: enabled
base/boost: 3400/3900 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3400 2: 1550 3: 1550 4: 1550
5: 1550 6: 2800 7: 1550 8: 1550 9: 1550 10: 3400 11: 1550 12: 1550
bogomips: 81643
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nouveau
v: kernel non-free: 545.xx+ status: current (as of 2023-11; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 26:00.0 chip-ID: 10de:1c82
class-ID: 0300 temp: 49.0 C
Display: x11 server: X.org v: 1.21.1.9 compositor: xfwm v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: HDMI-A-1 model: HP w2207 serial: <filter> built: 2007
res: 1680x1050 dpi: 90 gamma: 1.2 size: 473x296mm (18.62x11.65")
diag: 558mm (22") ratio: 16:10 modes: max: 1680x1050 min: 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NV137 device-ID: 10de:1c82
memory: 3.9 GiB unified: no
Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 26:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.5.9-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.83 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.5 TiB used: 617.94 GiB (24.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 043 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HUA723020ALA641
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A840 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSC0 rev: LI00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 108.64 GiB (47.7%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 121a5a27-095d-4c7a-8853-3a2b6e097b5c
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: 2C95-A40A
ID-3: /run/media/ultra/Ht1 raw-size: 550 GiB size: 540.3 GiB (98.24%)
used: 509.3 GiB (94.3%) fs: ext4 block-size: 4096 B dev: /dev/sdc2
maj-min: 8:34 label: Ht1 uuid: 48d40e11-d416-4079-9abd-c3115f9bdfc3
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 232.88 GiB fs: ext4 label: DDrive1
uuid: 6e4c97b7-826e-445e-8796-72d0e38f7e36
ID-2: /dev/sdb2 maj-min: 8:18 size: 232.88 GiB fs: ext4 label: DDrive2
uuid: 353601dc-0eb6-45f9-9475-50f8fb8def2c
ID-3: /dev/sdc3 maj-min: 8:35 size: 640 GiB fs: ext4 label: Ht2
uuid: db9f7c41-b09a-462e-a202-e0cd136c5ee7
ID-4: /dev/sdc4 maj-min: 8:36 size: 673.02 GiB fs: ext4 label: Ht3
uuid: dc1ff585-f270-4de5-ae19-45a09aa1bbb7
Device-1: 1-8:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 41.2 C mobo: N/A gpu: nouveau temp: 49.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 0
Processes: 445 Uptime: 59m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1441
pm: pacman pkgs: 1411 libs: 364 tools: pamac pm: flatpak pkgs: 30
Shell: Sudo (sudo) v: 1.9.14p3 default: Bash v: 5.2.15
running-in: xfce4-terminal inxi: 3.3.31
[ultra@ultra-ms7b86 ~]$ ```
1st update attempt:
```Preparing...
Refreshing extra.db...
Refreshing AUR...
Checking clamav-desktop-bin dependencies...
Cloning freecad-linkstage3-bin build files...
Generating freecad-linkstage3-bin information...
Checking freecad-linkstage3-bin dependencies...
Resolving dependencies...
Checking inter-conflicts...
Cloning clamav-desktop-bin build files...
Generating clamav-desktop-bin information...
Download of c-ares (1.20.1-1) started
Download of nodejs (20.8.0-1) started
Download of c-ares (1.20.1-1) finished
Download of asar (3.2.4-1) started
Download of asar (3.2.4-1) finished
Download of nodejs (20.8.0-1) finished
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Installing c-ares (1.20.1-1)...
Installing nodejs (20.8.0-1)...
Installing asar (3.2.4-1)...
Arming ConditionNeedsUpdate...
Building clamav-desktop-bin...
==> Making package: clamav-desktop-bin 0.3.24-2 (Fri 03 Nov 2023 10:05:55 AM EDT)
==> Missing dependencies:
-> electron17
==> ERROR: Could not resolve all dependencies.```
I could not import the 2nd update attempt after electron17 install failed, because the update process log is too long, (23,663 lines of text).
I thank you guys for any help concerning this problem.
