I just noticed this:
My ckb-next didn’t start up anymore. So I tried via the command-line. Which revealed it was because:
ckb-next: error while loading shared libraries: libquazip1-qt5.so.1.0.0: cannot open shared object file: No such file or directory
Since it is an AUR package, I checked its page, which had a workaround:
I get this error when starting:
% ckb-next ckb-next: error while loading shared libraries: libquazip1-qt5.so.1.0.0: cannot open shared object file: No such file or directory
I solved it by this workaround:
sudo ln -s /usr/lib/libquazip1-qt5.so.1.3 /usr/lib/libquazip1-qt5.so.1.0.0
It works for now but I guess ckb-next need to target the updated lib instead.
So, I tried that:
And it works! So, for any ckb-next users, there you be having it.
