I have installed CITRIX WORKSPACE APP and after entering my credentials for log in the app fires up. The citrix logo fires up in my work bar then disappears without launching into my virtual workspace.
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
In your specific case, the output of the app when it’s being started from a terminal and the commands you used to install it would be beneficial as well.
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
