dsaa
1
Hello,
I need to use Citrix Secure Access client for Linux ( amd64 / x86_64 )
so I got 2 .deb files. ( Download Link see below )
So I tryed to build the Install Package with debtap
debtap -u nsepa.deb
got the Package: nsepa-24.10.1-1-x86_64.pkg.tar.zst
But Package: nsginstaller64.deb did not build to .zst
Is there a howto how to get the Client
run/work on Manjaro Linux ?
Using the Version 24.10.1 for Ubuntu 22
Because I can not find the AUR Packages
tryed to build the PKGBUILD with debtap -p nsginstaller64.deb
but had no success to vpn tunnel
cd /opt/Citrix/NSGClient/bin
./NSGClient -c %u
***********Enter gateway address************
Gateway-Url : xxxxxx
ERROR: Proxy cannot be resolved
The only suggestion I have is that you take a look at the Citrix - ArchWiki page.
Citrix Secure Access client is available for Arch/Manjaro from the Arch User Repository (AUR):
Build* it using the following command:
pamac build icaclient
* Assumes AUR is properly configured in pamac.
DON’T.
That said, if there’s no other way, look at
