Hey guys, new to Manjaro - trying to remote into my work account via Citrix - basically install the Citrix client to handle .ica files. I can’t find a package for Arch anywhere, was wondering if anyone has successfully done this.
Thank you for your time.
Hello & Welcome,
please read this:
https://wiki.manjaro.org/index.php?title=Arch_User_Repository
Did you understand everything?
Open Pamac - the name in menu is Add/Remove Software and navigate to the Preferences page. You will be required to enter your password to access it.
At Preferences page → select the AUR tab → and move the slider to enable AUR.
pamac build icaclient
https://aur.archlinux.org/packages/icaclient/
greetings
Thank you! This makes sense and things are coming together now.
Installed successfully.
