I am actually only with Cinnamon because I really like how the key-shortcuts work for tiling and moving windows. It’s so easy and intuitive …
Press [WIndow-key] + user cursor keys to move up/down , left-right … and i.e. you move a window to the left half, you can put it in the top or bottom corner just with another cursor-up/-down keypress.
The default keyboard shortcuts for tiling are mapped to the keypad (with Num Lock turned off) and do not work on my 88-key keyboard
User can edit shortcuts in Window Manager (xfwm4-settings) or Settings Editor (xfce4-settings-editor) to use the arrow keys and Home, End, Page Up, Page Down
Custom shortcuts using the Super key do not work for me so I use the Alt key instead
