Cinnamon-screensaver freezes when monitors switch off
I am a long-time linux user, but a manjaro newbie.
I am running Manjaro pre-installed on a minisforum um700 desktop.
I switched from Plasma to Cinnamon (and am generally extremely happy with Cinnamon).
However I am experiencing an annoying issue with cinnamon-screensaver lockscreen.
If I lock the screen (or the screen locks itself) and the monitors turn off while locked, the screensaver seems to freeze, eg
  • The top half of one of my monitors is black/blank
  • The rest of the monitors shows the open applications as if the sccreen was unlocked
  • I don’t see a field to enter my password
  • The mouse cursor can move, but everything else is locked
I can unfreeze the system by switching to a tty and typing
$ cinnamon-unlock-desktop
However, I’ve had to disable faillock since I was getting 3 failed password attempts (even though I hadn’t typed anything).
I can reproduce this reliably by locking the screen and then manually switching off my screens, but it also happens when powersaving switches them off for me.
I don’t know if it’s relevant, but I run 2 monitors (one on HDMI one on DisplayPort), with different resolutions and one monitor is in portrait mode.
$ inxi --full --verbosity=7 --filter --no-host
  Kernel: 5.19.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    Desktop: Cinnamon v: 5.4.12 tk: GTK v: 3.24.34 wm: Notion vt: 7 dm: LightDM
    v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: BESSTAR TECH product: UM700 v: N/A
    serial: <superuser required>
  Mobo: BESSTAR TECH model: UM700 serial: <superuser required>
    UEFI: American Megatrends v: 5.14 date: 03/24/2022
  Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Device-2: hidpp_battery_1 model: Logitech MX Ergo Multi-Device Trackball
    status: discharging
  RAM: total: 13.61 GiB used: 4.62 GiB (34.0%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: quad core model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx
    bits: 64 type: MT MCP smt: enabled arch: Zen/Zen+ note: check level: v3
    rev: 1 cache: L1: 384 KiB L2: 2 MiB L3: 4 MiB
  Speed (MHz): avg: 1338 high: 1400 min/max: 1400/2300 boost: enabled
    cores: 1: 1400 2: 1222 3: 1400 4: 1349 5: 1400 6: 1400 7: 1295 8: 1239
    bogomips: 36747
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves
  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports:
    active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 04:00.0 chip-ID: 1002:15d8
    class-ID: 0300
  Device-2: Razer USA Gaming Webcam [Kiyo] type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 1-1.2:5 chip-ID: 1532:0e03
    class-ID: 0102
  Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3120x1920 s-dpi: 96 s-size: 826x508mm (32.52x20.00")
    s-diag: 970mm (38.18")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: top-right model: Dell U2412M
    serial: <filter> res: 1200x1920 hz: 60 dpi: 94
    size: 324x518mm (12.76x20.39") diag: 611mm (24.1") modes: max: 1920x1200
    min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,bottom-l
    model: HP E243i serial: <filter> res: 1920x1200 hz: 60 dpi: 94
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") modes: max: 1920x1200
    min: 720x400
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
    v: kernel bus-ID: 1-1.2:5 pcie: chip-ID: 1532:0e03 speed: 8 GT/s
    class-ID: 0102 lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
    v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Realtek
    driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
    bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Razer USA Gaming Webcam [Kiyo] type: USB
  Device-5: Bang Olufsen Beosound A1 2nd Gen type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.3.1:7
    chip-ID: 0cd4:102e class-ID: 0300 serial: <filter>
  Device-6: C-Media Audio Adapter (Unitek Y-247A) type: USB
    driver: cmedia_hs100b,snd-usb-audio,usbhid bus-ID: 3-2.1:3
    chip-ID: 0d8c:0014 class-ID: 0300
  Sound Server-1: ALSA v: k5.19.13-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.58 running: yes
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie:
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
  Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie:
    speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
    driver: r8152 bus-ID: 2-1.4:3 chip-ID: 0bda:8153 class-ID: 0000
    serial: <filter>
  IF: enp4s0f3u1u4 state: down mac: <filter>
  IF-ID-1: br-039004d07514 state: down mac: <filter>
  IF-ID-2: br-8f60eca9344e state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
    all]
  IF-ID-3: docker0 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
    all]
  IF-ID-4: veth320ac61 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-5: veth45328af state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-6: veth63b9f0a state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    bus-ID: 3-2.2:4 chip-ID: 8087:0a2a class-ID: e001
  Local Storage: total: 942.7 GiB used: 509.26 GiB (54.0%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PDP3512B-A01
    size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: EDFK0S03 temp: 44.9 C scheme: GPT
  ID-2: /dev/sda vendor: Hitachi model: HTS545050A7E380 size: 465.76 GiB
    speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: A6C0 scheme: GPT
  ID-1: / size: 468.09 GiB used: 95.77 GiB (20.5%) fs: ext4
    dev: /dev/nvme0n1p2 label: N/A uuid: 6df714e4-3531-4c3a-b021-525f88beda09
  ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1 label: NO_LABEL uuid: A65F-015B
  ID-3: /data/files size: 456.18 GiB used: 413.49 GiB (90.6%) fs: ext4
    dev: /dev/sda3 label: N/A uuid: 467768e5-ef14-4a11-b0ae-47f4a2990149
  ID-1: /dev/sda1 size: 512 MiB fs: vfat label: N/A uuid: EB26-D0E9
  ID-2: /dev/sda2 size: 732 MiB fs: swap label: N/A
    uuid: 4fad51c5-1de3-4749-804b-303673cd8dc1
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-2: 1-1:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2817 class-ID: 0900
  Device-1: 1-1.2:5 info: Razer USA Gaming Webcam [Kiyo] type: Video,Audio
    power: 500mA chip-ID: 1532:0e03 class-ID: 0102
  Hub-3: 1-1.3:6 info: Cambridge Silicon Radio ports: 4 rev: 2.0
    speed: 12 Mb/s power: 500mA chip-ID: 0a12:4010 class-ID: 0900
  Device-1: 1-1.3.1:7 info: Bang Olufsen Beosound A1 2nd Gen
    type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 5
    rev: 2.0 speed: 12 Mb/s chip-ID: 0cd4:102e class-ID: 0300
    serial: <filter>
  Device-2: 1-2:3 info: Yubicom Yubikey (v1 or v2) type: Keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 30mA chip-ID: 1050:0010 class-ID: 0301 serial: <filter>
  Device-3: 1-4:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 2-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
    chip-ID: 2109:0817 class-ID: 0900
  Device-1: 2-1.4:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.2 speed: 5 Gb/s
    power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-7: 3-2:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 3-2.1:3 info: C-Media Audio Adapter (Unitek Y-247A)
    type: Audio,HID driver: cmedia_hs100b,snd-usb-audio,usbhid interfaces: 4
    rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0014 class-ID: 0300
  Device-2: 3-2.2:4 info: Intel Bluetooth wireless interface
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0a2a class-ID: e001
  Hub-8: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
  Processes: 323 Uptime: 16m wakeups: 4 Init: systemd v: 251
  default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1620
  pm: pacman pkgs: 1612 pm: snap pkgs: 8 Shell: Bash v: 5.1.16
  running-in: guake inxi: 3.3.21
Output of journalctl after the crash and the subsequent unlocking:
Oct 07 10:16:40 tak-um700 dbus-daemon[1574]: [session uid=1001 pid=1574] Activating service name='org.cinnamon.ScreenSaver' requested by ':1.133' (uid=1001 pid=5584 comm="/usr/bin/python3 /usr/bin/cinnamon-screensaver-com")
Oct 07 10:16:40 tak-um700 dbus-daemon[1574]: [session uid=1001 pid=1574] Successfully activated service 'org.cinnamon.ScreenSaver'
Oct 07 10:16:40 tak-um700 cinnamon-session[1575]: WARNING: t+1217,84966s: Detected that screensaver has appeared on the bus
Oct 07 10:16:45 tak-um700 rtkit-daemon[1675]: Supervising 13 threads of 7 processes of 1 users.
Oct 07 10:16:47 tak-um700 dbus-daemon[534]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.168' (uid=1001 pid=5651 comm="/usr/lib/cinnamon-screensaver/cinnamon-screensaver")
Oct 07 10:16:47 tak-um700 dbus-daemon[534]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 07 10:16:47 tak-um700 cinnamon-screensaver-pam-helper[5651]: pam_systemd_home(cinnamon-screensaver:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 07 10:16:47 tak-um700 dbus-daemon[534]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.169' (uid=1001 pid=5666 comm="/usr/lib/cinnamon-screensaver/cinnamon-screensaver")
Oct 07 10:16:47 tak-um700 cinnamon-screensaver-pam-helper[5666]: pam_systemd_home(cinnamon-screensaver:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 07 10:16:48 tak-um700 cinnamon-screensaver-pam-helper[5651]: pam_unix(cinnamon-screensaver:auth): conversation failed
Oct 07 10:16:48 tak-um700 cinnamon-screensaver-pam-helper[5651]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [tak]
Oct 07 10:16:48 tak-um700 dbus-daemon[534]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.170' (uid=1001 pid=5675 comm="/usr/lib/cinnamon-screensaver/cinnamon-screensaver")
Oct 07 10:16:48 tak-um700 dbus-daemon[534]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 07 10:16:48 tak-um700 cinnamon-screensaver-pam-helper[5675]: pam_systemd_home(cinnamon-screensaver:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 07 10:16:48 tak-um700 cinnamon-screensaver-pam-helper[5666]: pam_unix(cinnamon-screensaver:auth): conversation failed
Oct 07 10:16:48 tak-um700 cinnamon-screensaver-pam-helper[5666]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [tak]
Oct 07 10:16:48 tak-um700 cinnamon-screensaver-pam-helper[5675]: pam_unix(cinnamon-screensaver:auth): conversation failed
Oct 07 10:16:48 tak-um700 cinnamon-screensaver-pam-helper[5675]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [tak]
Oct 07 10:16:48 tak-um700 dbus-daemon[534]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.171' (uid=1001 pid=5695 comm="/usr/lib/cinnamon-screensaver/cinnamon-screensaver")
Oct 07 10:16:48 tak-um700 cinnamon-screensaver-pam-helper[5695]: pam_systemd_home(cinnamon-screensaver:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 07 10:16:57 tak-um700 pulseaudio[1656]: Failed to find a working profile.
Oct 07 10:16:57 tak-um700 pulseaudio[1656]: Failed to load module "module-alsa-card" (argument: "device_id="2" name="pci-0000_04_00.6" card_name="alsa_card.pci-0000_04_00.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
Oct 07 10:16:58 tak-um700 cinnamon-session[1575]: WARNING: t+1236,01872s: Detected that screensaver has left the bus
Oct 07 10:16:59 tak-um700 pulseaudio[1656]: Failed to find a working profile.
Oct 07 10:16:59 tak-um700 pulseaudio[1656]: Failed to load module "module-alsa-card" (argument: "device_id="2" name="pci-0000_04_00.6" card_name="alsa_card.pci-0000_04_00.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
As a quick follow-up I did some more testing and this seems to be specifically happening due to the portrait orientation of my 2nd monitor.
If I orient it landscape the crashes (at least on some quick tests) don’t occur.
Cinnamon is GTK based - KDE/Plasma is Qt based and the UM700 computer is possibly setup to use Wayland.
It is a configuration issue - especially if the monitors is not set to use the same refresh rate.
I had to tinker quite a bit with my monitors to get Plasma to use my monitors correct - even then I have occational issues when monitors goes to sleep - issues which only goes away on logout and relogin.
