As mentioned in an earlier message, my icpu is Ryzen 3 3200G (not Intel). The AMD graphics driver is included in the Ryzen cpu.
Also I do not have a file named /etc/mkinitcpio.conf. If I have to create one for the AMD graphics, how do I go about creating it?
Thanks for your assistance.
If you don’t have that file, then there’s something seriously wrong with your installation. /etc/mkinitcpio.conf
is essential for rebuilding the initramfs
whenever the kernel gets updated, and without an initramfs
you cannot boot ─ it contains all your needed driver modules.
Try reinstalling mkinitcpio
sudo pacman -S mkinitcpio
I’m afraid I can’t help you with the lightdm
problem, though.
Thanks to those whose shared their knowledge. I was able to edit the mkinitcpio.conf file and the issue is now solved. Much appreciated.
Rather than editing the thread title, please mark the post solving your problem as solution via Solution button below that post next time.
