Sorry for my english, writing from phone.
Some context, i’ve bought a new laptop and trying to install manjaro cinnamon there.
First sturtup, everything fine, but there are glitches with bottom bar(i dont know how to call it properly): when you enter edit mode, icons will have wrong size, even out of bar, changing “screen scaling” caouses very similar glith. Last time( i reinstalled cinnamon twice cuz of it ) i even killed DE by draging the applets ( bottom bar collapsed and everithing just freezed ).
Now, i’ve made some minor changing, reloaded the laptop and get error masage, that DE has died.
But… it still working somehow…
X11 is downed as i thing, just black screen with cursor and some times pieces of former interface…
What should i do? Gpu is amd vega if it’s important.
What have you done?
gamer_girl_2007_nah:
reloaded the laptop
Do you mean reboot? Or restart the display-manager?
Anyway…cinnamon is developed by the linuxmint devs:
Maybe you are better off using linux mint if you prefer the cinnamon desktop. At least because you have zero knowledge when it comes to such minor problems and you need a reliable and predictable environment.
Since that are user customizations, create a new account and login there. That would be a fast solution.
I downloaded vs code, firefox and add layot applet to the panel.
Yes, reboot.
I want to use manjaro for several reasons, at least AUR. As i find out, this problem appiars only in cinnamon (plasma and mate are working).
And, about minor problem… Dude i just have DE falling down every time i install it, and logs which says that x is down. Also some graphic gliches. And i want to solve this problem, googling it gave me zero result and thats why i’m here:)
Good, but without sharing any logs, me and any other out here will just guess. Have no glass globe sorry.
Switch to another TTY (I hope you know how to do that), login and run this:
journalctl --boot 0 --no-hostname --no-pager | curl -s -F'file=@-' https://0x0.st
That should get the current system log and upload it. Share the link here.
This a script which collects way more information:
https://notabug.org/megavolt/random-scripts/raw/master/lognconf-report.sh
bash <(https://notabug.org/megavolt/random-scripts/raw/master/lognconf-report.sh)
But maybe more than less. At the end you get 2 questions about
View
Save to disk or upload.
Ok, here’s the link: https://0x0.st/okei.txt
I reinstalled the DE, failed again… with no reason
Okay… so, it is not a minor problem. Cinnamon just crash:
дек 03 11:57:17 audit[1235]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 subj==unconfined pid=1235 comm="cinnamon" exe="/usr/bin/cinnamon" sig=11 res=1
дек 03 11:57:17 systemd[1]: Created slice Slice /system/systemd-coredump.
дек 03 11:57:17 audit: BPF prog-id=23 op=LOAD
дек 03 11:57:17 audit: BPF prog-id=24 op=LOAD
дек 03 11:57:17 audit: BPF prog-id=25 op=LOAD
дек 03 11:57:17 systemd[1]: Started Process Core Dump (PID 1268/UID 0).
дек 03 11:57:17 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1268-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
дек 03 11:57:18 systemd-coredump[1269]: Process 1235 (cinnamon) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 15c48e8c72ad1b981d55e5c548007224f45150b1
Module libcanberra-gtk3.so.0 with build-id 2e99c78f79bea4bc67ccd9a9f8fed562f89599ee
Module libcanberra-gtk-module.so with build-id cc626937222c6ce3f7bb45dbe6e862d0b1efba01
Module libxapp-gtk3-module.so with build-id 52f3ac7cccb19903e4c8eedd9054273f622333f5
Module libspa-journal.so with build-id d2d6013bfa1b9deaae18ce450cd049d171b317ce
Module libspa-support.so with build-id ac45ac61b6e9900c8a54ba6e179d75e8bd55b5f5
Module libgvfscommon.so with build-id 2cfa9a05d5e376857a2dacaf4893238a88eefb9e
Module libgvfsdbus.so with build-id f6f918ab413a1eaaa77134863653c4382b7cf8de
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libvulkan.so.1 with build-id dd97393da4f886994c9dfc153b35ea6d906f57ff
Module libdrm_nouveau.so.2 with build-id 78e99e753be2b598acf02a6f30bc6615a6a3067f
Module libdrm_amdgpu.so.1 with build-id e03ead624f04700b1fd00df43863fecfb1ff8b72
Module libdrm_radeon.so.1 with build-id 5c9c31961c5f0dd9b40cb3e134b8d9189ee59fbb
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module libLLVM-14.so with build-id 16d23f3ab6fb7269b2f13a9932a2a7ec4b1d5104
Module radeonsi_dri.so with build-id 247f930d52c9b9e6d6e140462136d983b0b617da
Module libXxf86vm.so.1 with build-id b8b37b0c66be0a760a8491e3c86a00c4efdc825d
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module libGLX_mesa.so.0 with build-id 6721ac15576bf0a0a4d5a29429915cb88cdf5426
Module libxshmfence.so.1 with build-id d9b3ce4edb0b6a0818bcc57dda020d2da5e3c895
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-present.so.0 with build-id 8ed389d9cd6ad7110fbb00c93b32e0efaa71a6b1
Module libxcb-dri3.so.0 with build-id 088c750254cc139e7d62b8a3fc7795a138447ccf
Module libwayland-server.so.0 with build-id 4c54fc8a7c0d4eb8adf2a69e44ebf12d16969c74
Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-dri2.so.0 with build-id 7bde0abc84135ae6258a8d1d130864071c2cc327
Module libglapi.so.0 with build-id a5ca7bec18ce3ff85c63b88bd43a7884ea95a1f7
Module libgbm.so.1 with build-id 2241661ad5ff576b6421b34e6a38737a3a5122b3
Module libEGL_mesa.so.0 with build-id b2fb9bd7e5dcd7b04a4d0a95fdc6c0b23671d25c
Module libdconfsettings.so with build-id 7a4ba7af122c4d11168004a9ea6def330f02089f
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id f4e086347f6c1a66eb73cfe13974a29bd39aabca
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libelf.so.1 with build-id 5ba0792747dce7480d031794ed90c620da72dbff
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libxklavier.so.16 with build-id cefd678b3d270e389f50a9686ad2db83a8c67494
Module libgnomekbd.so.8 with build-id 7a75c84337b94141ae6bdf56da86a5a6f72343bf
Module libsqlite3.so.0 with build-id e35d23d9eef4b99c931412b3a1355e333fcb10a5
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libuuid.so.1 with build-id 9057a530e6b3b0e71f24602a0039c490c9a0b5a1
Module libxcb-xkb.so.1 with build-id bad7e1eb65df04a6b2d676a08f68844856edaace
Module libxcb-util.so.1 with build-id b1e4c01b388a3bd7a0a9ad384865b61f5f1d4a24
Module libudev.so.1 with build-id 1c5c93f27f6b1fcbf2af1d56079e945779b8c097
Module libltdl.so.7 with build-id d05fc2173e22a4b5374a1f80b548ae5c0926e079
Module libtdb.so.1 with build-id f2bdb5ac97b6addf2026d93b08c8d15defcd9bb8
Module libvorbisfile.so.3 with build-id 45d2551167a616d448beb033ba49394831992887
Module libtiff.so.5 with build-id 5f020a8eb30e12c2e4012d0cb50da9480c7b5d34
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libGLX.so.0 with build-id 1d664a1f03d6c5c9ac997c4b73f3e8a11424cc74
Module libGLdispatch.so.0 with build-id 9901dca23d6ccd49929b5f44c81cd671f1ec6757
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libpthread.so.0 with build-id b966d4b239433c89ca36c0938381e2d92cd47639
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libsystemd.so.0 with build-id f53e01cd7b3e5ff8757530ed7a65324ae12df5c8
Module libdw.so.1 with build-id 35e7f9b41a957c7463f7ef9f977dabda3deae241
Module libunwind.so.8 with build-id e7f3b22127b00d8b14b2560df707cbbeb0134861
Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libgnomekbdui.so.8 with build-id eeb3039b3aa71b38849fb1b3d2e97acb9edab6d4
Module libtracker-sparql-3.0.so.0 with build-id 75ab4f2e3b5c479b5c4fc62793bf398ee28f4ab7
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libstdc++.so.6 with build-id e0dd3ec5b0a62b122b4141c956c0b33a4d719144
Module libreadline.so.8 with build-id 03c124180216a8077784ca035346856bd16060b9
Module libmozjs-78.so with build-id 81ec830735a7014397eea4ad31dbb170f773eb79
Module ld-linux-x86-64.so.2 with build-id 5492655bffbf172ed8a07f285f760ead38f09404
Module libSM.so.6 with build-id 66cef8ae9a7848679be78dd26fd47e05110d03b5
Module libxcb-res.so.0 with build-id cd3dbd6dd9e412a002d1be5ae0ec0d85650542ba
Module libxcb-randr.so.0 with build-id c914473ab7592ed5cf5c191200faaac1089c12ad
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libxkbcommon-x11.so.0 with build-id 90654f41d9fe91c74bef6672a8b57ab34418b27a
Module libxkbfile.so.1 with build-id dc74ddc73cb1178f037cdc608f7029a0bc9f69a1
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libICE.so.6 with build-id a78252e65631a98d7935f1bca668c2fe1d6bbb53
Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
Module libpipewire-0.3.so.0 with build-id b91e7a1d107726d205723f63f1671760c3aaaf19
Module libstartup-notification-1.so.0 with build-id c31cad1791f13615a8f6c9ec025e1a3c3eef7736
Module libgudev-1.0.so.0 with build-id 460465b63a086d945124662363191903c0002793
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libcanberra.so.0 with build-id 8ddef69c9b84a86062c88a59510639cd908fc6d3
Module libcinnamon-desktop.so.4 with build-id 16a763d2d61ef88a771855e0efe40d383d8f2e3b
Module libwacom.so.9 with build-id 52b5a9bb54e19f46a2d54b8a8ee3c859ba23170b
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libXtst.so.6 with build-id 35c7f3daf454834acb724e6bd1664b0a2e9a6494
Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libgdk_pixbuf-2.0.so.0 with build-id b2822dc16bd1470683ce421978ad142c4f3c3f89
Module libGL.so.1 with build-id a3025d7d2cce51ecb2d47c076bfddefbf7e081f0
Module libEGL.so.1 with build-id d4e8037e21617b4005fd99bf9464b3d3f4c3dd35
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libm.so.6 with build-id efeea58692a42176201df89f034aa4295a77ce74
Module libgraphene-1.0.so.0 with build-id 146fd1d0593533b7842d16bc96e114e80c183ec3
Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpangoft2-1.0.so.0 with build-id 4a5a975bc9e397294c88738430515901a51c304c
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libpango-1.0.so.0 with build-id a971a5fed3b8b9cf076fe5edb9a9f04ced3da211
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libmuffin-cogl-path-0.so.0 with build-id d69fccbaf53869c0ae77009f3307fc431e9810fd
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libdbus-1.so.3 with build-id 130b4008893289a2628546d8f98f6977d61270cd
Module libgcc_s.so.1 with build-id 308aed8b7d7e38f5efa23f75c25601668c1fc009
Module libgstbase-1.0.so.0 with build-id c4590b02fb88ac12206d4b43be1b2b1b163e7bce
Module libgstreamer-1.0.so.0 with build-id 2ee55886823bebf80a7c02e9b4942303eede3c42
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libxapp.so.1 with build-id 37ec2cd0a10b801e46a990db9b6ec04a9e8b1f8b
Module libmuffin-cogl-pango-0.so.0 with build-id 44eedc140379f923d50e9bb9adec06214aa5f9e0
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libgtk-3.so.0 with build-id 48baf44dfd4d51f8c2b81d852eb44de692c16b19
Module libpangocairo-1.0.so.0 with build-id 37f75358f8778498bcc26a1658107953d9495255
Module libgdk-3.so.0 with build-id 4a9a6d5ddd18f22c56c05773208f8808cefacab6
Module libcinnamon-menu-3.so.0 with build-id d7069c6e95ff6463e8218ce1e62041fd26e24714
Module libmuffin-cogl-0.so.0 with build-id 5861d5c820a110474e5dc3db8e247a6611749bd7
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libcjs.so.0 with build-id eed06642c62e36f98fb076329860ce48a6f303ee
Module libst.so with build-id 90b1986465ec1a66289a7fb7fb6f643c8889c126
Module libc.so.6 with build-id 7d4293a9bbe1f068ab7ae807c2d9377395eb5b41
Module libmuffin.so.0 with build-id 608cca303810a8ed83d91534dda1223d6a0e5466
Module libgirepository-1.0.so.1 with build-id b5497fd1bc90cd83e17834ddc6a5a0b54df984bb
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libmuffin-clutter-0.so.0 with build-id 87653ff6968f58c329547d37219d5369f4969364
Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libcinnamon.so with build-id fe86b71a8506a783cd9a15563ec410bbb5e2d14a
Module cinnamon with build-id a281617cdd48689af40dbbd3c005320419f68de1
Stack trace of thread 1235:
#0 0x00007f15b48d78d4 n/a (libmozjs-78.so + 0x42d8d4)
#1 0x00007f15b76c89f4 n/a (libcjs.so.0 + 0x5f9f4)
#2 0x00007f15b48ada7e n/a (libmozjs-78.so + 0x403a7e)
#3 0x00007f15b49924b4 n/a (libmozjs-78.so + 0x4e84b4)
#4 0x00007f15b4c0ece7 n/a (libmozjs-78.so + 0x764ce7)
#5 0x00007f15b4c14d41 n/a (libmozjs-78.so + 0x76ad41)
#6 0x00007f15b4e05606 n/a (libmozjs-78.so + 0x95b606)
#7 0x00007f15b4e05794 _ZN2JS8EvaluateEP9JSContextNS_6HandleINS_13StackGCVectorIP8JSObjectN2js15TempAllocPolicyEEEEERKNS_22ReadOnlyCompileOptionsERNS_10SourceTextIDsEENS_13MutableHandleINS_5ValueEEE (libmozjs-78.so + 0x95b794)
#8 0x00007f15b76e50bf n/a (libcjs.so.0 + 0x7c0bf)
#9 0x00007f15b48ada7e n/a (libmozjs-78.so + 0x403a7e)
#10 0x00007f15b49924b4 n/a (libmozjs-78.so + 0x4e84b4)
#11 0x00007f15b4c0ece7 n/a (libmozjs-78.so + 0x764ce7)
#12 0x00007f15b4c14d41 n/a (libmozjs-78.so + 0x76ad41)
#13 0x00007f15b4e05606 n/a (libmozjs-78.so + 0x95b606)
#14 0x00007f15b4e05794 _ZN2JS8EvaluateEP9JSContextNS_6HandleINS_13StackGCVectorIP8JSObjectN2js15TempAllocPolicyEEEEERKNS_22ReadOnlyCompileOptionsERNS_10SourceTextIDsEENS_13MutableHandleINS_5ValueEEE (libmozjs-78.so + 0x95b794)
#15 0x00007f15b76d815b n/a (libcjs.so.0 + 0x6f15b)
#16 0x00007f15b76de14a gjs_context_eval (libcjs.so.0 + 0x7514a)
#17 0x00007f15b81c2694 n/a (libcinnamon.so + 0x21694)
#18 0x00007f15b7a82ac3 meta_compositor_manage (libmuffin.so.0 + 0x73ac3)
#19 0x00007f15b7aa5b3e meta_run (libmuffin.so.0 + 0x96b3e)
#20 0x00005598b946d506 n/a (cinnamon + 0x2506)
#21 0x00007f15b784b2d0 n/a (libc.so.6 + 0x232d0)
#22 0x00007f15b784b38a __libc_start_main (libc.so.6 + 0x2338a)
#23 0x00005598b946d635 n/a (cinnamon + 0x2635)
Stack trace of thread 1266:
#0 0x00007f15b78ab346 n/a (libc.so.6 + 0x83346)
#1 0x00007f15b78adb60 pthread_cond_wait (libc.so.6 + 0x85b60)
#2 0x00007f15b4c29860 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-78.so + 0x77f860)
#3 0x00007f15b4c29361 n/a (libmozjs-78.so + 0x77f361)
#4 0x00007f15b4e1f0bf n/a (libmozjs-78.so + 0x9750bf)
#5 0x00007f15b78ae78d n/a (libc.so.6 + 0x8678d)
#6 0x00007f15b792f8e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 1242:
#0 0x00007f15b7922e9f __poll (libc.so.6 + 0xfae9f)
#1 0x00007f15b7e8cf68 n/a (libglib-2.0.so.0 + 0xaaf68)
#2 0x00007f15b7e361cf g_main_loop_run (libglib-2.0.so.0 + 0x541cf)
#3 0x00007f15b8086acc n/a (libgio-2.0.so.0 + 0x108acc)
#4 0x00007f15b7e66405 n/a (libglib-2.0.so.0 + 0x84405)
Stack trace of thread 1247:
#2 0x00007f15a86b7c7c n/a (radeonsi_dri.so + 0xb2c7c)
#3 0x00007f15a86b137c n/a (radeonsi_dri.so + 0xac37c)
#4 0x00007f15b78ae78d n/a (libc.so.6 + 0x8678d)
#5 0x00007f15b792f8e4 __clone (libc.so.6 + 0x1078e4)
Stack trace of thread 1245:
Stack trace of thread 1246:
Stack trace of thread 1250:
Stack trace of thread 1261:
Stack trace of thread 1240:
#2 0x00007f15b7e34392 g_main_context_iteration (libglib-2.0.so.0 + 0x52392)
#3 0x00007f15b7e343e2 n/a (libglib-2.0.so.0 + 0x523e2)
Stack trace of thread 1249:
Stack trace of thread 1255:
Stack trace of thread 1258:
Stack trace of thread 1265:
Stack trace of thread 1251:
Stack trace of thread 1264:
Stack trace of thread 1243:
#3 0x00007f15b8197ebe n/a (libdconfsettings.so + 0x5ebe)
Stack trace of thread 1252:
Stack trace of thread 1253:
Stack trace of thread 1254:
Stack trace of thread 1248:
Stack trace of thread 1241:
#0 0x00007f15b792856d syscall (libc.so.6 + 0x10056d)
#1 0x00007f15b7e87063 g_cond_wait_until (libglib-2.0.so.0 + 0xa5063)
#2 0x00007f15b7e058d3 n/a (libglib-2.0.so.0 + 0x238d3)
#3 0x00007f15b7e6963b n/a (libglib-2.0.so.0 + 0x8763b)
Stack trace of thread 1259:
Stack trace of thread 1256:
Stack trace of thread 1260:
Stack trace of thread 1263:
Stack trace of thread 1244:
Stack trace of thread 1262:
дек 03 11:57:18 systemd[1]: systemd-coredump@0-1268-0.service: Deactivated successfully.
If I compare:
~ > mbn info cinnamon -q INT 1m 45s
Branch : archlinux
Version : 5.6.4-1
Repository : community
Build Date : Tue 29 Nov 2022 19:39:19
Packager : Antonio Rojas <arojas@archlinux.org>
Branch : unstable
Version : 5.6.4-1
Build Date : Tue 29 Nov 2022 20:33:24
Packager : Mark Wagie <mark@manjaro.org>
Branch : testing
Version : 5.6.4-1
Branch : stable
Version : 5.4.12-1
Build Date : Sat 10 Sep 2022 17:24:22
Then on stable there is still version 5.4, maybe version 5.6 has a fix for this?
Switch to testing:
sudo pacman-mirrors --api --set-branch testing
sudo pacman-mirrors --geoip
sudo pacman-mirrors --fasttrack
sudo pacman -Syyuu
Upd: got a new trouble, cinnamon don’t let me in. I type my password at login screen, black screen for few seconds, login screen again…
Perhaps problem can be on drivers but im not sure, and now i can’t even open a terminal:(
First, let me say that I am no expert but I feel that you might want to try installing Linux Mint (Cinn) to see if it acts the same way. I suspect that your problems may be hardware or driver issues and this should tell you. I’m guessing that you will have the same problems with Mint. I’m running Manjaro Cinnamon (Cinn 5.4) and it is rock steady.
I don’t think so. It could also just that newer libs has been placed, which are not well tested with cinnamon. Note that cinnamon exists as Communiy Edition, but it is not popular on Manjaro and maybe not well tested. Guess there is only a handful users who actually use the cinnamon desktop here.
BTW, after installing, did you actually a System Update?
From the first vew, there is no issues with mint cin. I’m much more considered now that it is drivers fault.
But the fact is, whatever it be, how to goddamit fix it? At least make cin start.
There is no info obut fixing that broblem in the internet at all, the only thing i find out is that many people say it can be cuz of nvidea drivers. No use, i have amd GPU.
Why is this SO hard…
I’m running cinnamon on testing branch and it’s pretty stable. There was/might still be an issue with some extensions /plugins not being updated /compatible with the latest cinnamon.
I’m only on phone atm so haven’t had a chance to look at his logs
I would advice looking at this page: Cinnamon - ArchWiki
For example, you can, like on gnome, restart it: ALT + F2 and then enter restart
or just r
to restart cinnamon.
You can also, just for testing, set multi-user as default target:
sudo systemctl set-default mulit-user.target
Reboot, login and run cinnamon like that:
startx /usr/bin/cinnamon-session --debug
Maybe there you get more information about the actual problem.
