Hello,
i installed recently manjaro these days ( i migrated from linux mint )
it’s a begginer friendly distro and everything goes smoothly at this moment except one thing…
as you can imagine i have the same problem than the others users with the famous driver of nvidia
i’m using the desktop environment cinnamon based on Lightdm so in this case what optimus program i have to use?
this one ? → GitHub - Askannz/optimus-manager: A Linux program to handle GPU switching on Optimus laptops.
mhwd -li > Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI``
``glxinfo | grep -i vendor
server glx vendor string: SGI
client glx vendor string: Mesa Project and SGI
Vendor: Intel (0x8086)
OpenGL vendor string: Intel``
i have an optimus laptop with this characteristics
``System:
Host: willpow4-hp Kernel: 5.12.2-1-MANJARO x86_64 bits: 64
Desktop: Cinnamon 4.8.6 Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Notebook v: N/A
serial: 5CD8475263
Mobo: HP model: 84F8 v: 08.10 serial: PHNEF018JBK089 UEFI: AMI v: F.18
date: 06/20/2018
ID-1: BAT0 charge: 40.1 Wh (76.1%) condition: 52.7/52.7 Wh (100.0%)
volts: 11.5 min: 11.6
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP cache:
L2: 8 MiB
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 799
Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: nvidia v: 460.80
Device-3: Chicony HP Wide Vision HD type: USB driver: uvcvideo
Display: server: X.org 1.20.11 driver: loaded: modesetting,nvidia
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.3
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Sound Server-1: ALSA v: k5.12.2-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
driver: r8169
IF: eno1 state: down mac: 84:a9:3e:16:76:93
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
driver: rtw_8822be
IF: wlo1 state: up
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
Local Storage: total: 1.03 TiB used: 86.99 GiB (8.3%)
ID-1: /dev/sda vendor: SanDisk model: SD9SN8W-128G-1006 size: 119.24 GiB
ID-2: /dev/sdb vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
ID-1: / size: 74.35 GiB used: 25.06 GiB (33.7%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 514 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sda2
ID-3: /home size: 876.01 GiB used: 61.93 GiB (7.1%) fs: ext4
dev: /dev/sdb1
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 277 Uptime: 55m Memory: 7.62 GiB used: 2.27 GiB (29.8%)
Shell: Bash inxi: 3.3.04
btw about the problem resolution: <missing: xdpyinfo> how i can fix it?
thank you so much
