Cinnamon 5 crashes when starting applications in full screen
Hello,
I am on the stable branch.
Since updating to Cinnamon 5, the desktop environment crashes when trying to open applications that start in full screen (e.g. games - I have tested multiple different ones). The mouse cursor starts to twitch and the Taskbar, Alt+Tab, Menu etc. become unresponsive. Depending on the application, it either crashes or freezes. If it freezes, the only way I have found to close it is switching to TTY and killing the process. In either case, I get a message dialogue that informs me that I am in fallback mode and prompts me to restart Cinnamon after the application is closed. Cinnamon continues to work normally after restarting it using that dialogue.
Opening applications in windowed mode and then switching to full screen works in most cases. Starting them in full screen mode in a different DE also works without any problems.
When starting the applications using the terminal, I get the following error message:
Error Message
X Error of failed request:  BadWindow (invalid Window parameter)
Major opcode of failed request:  40 (X_TranslateCoords)
Resource id in failed request:  0x340062f
Serial number of failed request:  3424
Current serial number in output stream:  3424
The values of the serial numbers and resource id vary, the rest does not
My Cinnamon version is 5.0.4, I am using Kernel 5.13.1-3-Manjaro and Nvidia driver version 470.42.01, but I also had these errors occur on Kernel 5.10 and using Nvidia driver version 465.xx
inxi Output
  Kernel: 5.13.1-3-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=18fac743-1dab-49a3-b2d7-732afbc6f77b rw quiet loglevel=0 splash
  Desktop: Cinnamon 5.0.4 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
  Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING EDGE WIFI (MS-7C91)
  v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.30 date: 08/31/2020
  RAM: total: 31.28 GiB used: 2.66 GiB (8.5%)
  Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
  family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
  L2: 4 MiB bogomips: 115253
  Speed: 3598 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 3598 2: 2054 3: 2057 4: 2054 5: 2056 6: 3600 7: 2057 8: 2057 9: 2056
  10: 2054 11: 2059 12: 3594 13: 2057 14: 2056 15: 3601 16: 2054
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
  mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
  nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
  pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
  pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
  skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
  succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
  v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  conditional, RSB filling
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ZOTAC driver: nvidia
  v: 470.42.01 alternate: nouveau,nvidia_drm bus-ID: 2b:00.0
  chip-ID: 10de:2484 class-ID: 0300
  Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
  s-diag: 777mm (30.6")
  Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
  diag: 685mm (27")
  OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.42.01 direct render: Yes
  Device-1: NVIDIA GA104 High Definition Audio vendor: ZOTAC
  driver: snd_hda_intel v: kernel bus-ID: 2b:00.1 chip-ID: 10de:228b
  class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 2d:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Device-3: C-Media Anua Mic CM 900 type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:3 chip-ID: 0d8c:0134
  class-ID: 0300
  Sound Server-1: ALSA v: k5.13.1-3-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.31 running: yes
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 29:00.0
  chip-ID: 8086:2723 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
  v: kernel port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:5
  Report: bt-adapter ID: hci0 rfk-id: 1 state: down
  bt-service: enabled,running rfk-block: hardware: no software: yes
  address: <filter>
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 1.82 TiB used: 546.77 GiB (29.3%)
  model: WDS200T3X0C-00SJG0 size: 1.82 TiB block-size: physical: 512 B
  logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
  rev: 102430WD scheme: GPT
  ID-1: / raw-size: 1.27 TiB size: 1.25 TiB (98.35%) used: 546.77 GiB (42.6%)
  fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
  uuid: 18fac743-1dab-49a3-b2d7-732afbc6f77b
  ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
  used: 301 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
  uuid: A450-5576
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: <superuser required>
  label: N/A uuid: 186A-6DE1
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 558.18 GiB
  fs: <superuser required> label: N/A uuid: 7A607ADD607AA015
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 515 MiB fs: <superuser required>
  label: N/A uuid: D6FEE641FEE61A0F
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-5:3 info: C-Media Anua Mic CM 900 type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300
  Device-2: 1-8:4 info: Micro Star MYSTIC LIGHT type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 500mA chip-ID: 1462:7c91 class-ID: 0300 serial: <filter>
  Device-3: 1-9:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Logitech G513 RGB MECHANICAL GAMING KEYBOARD
  type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 500mA chip-ID: 046d:c33c class-ID: 0300
  serial: <filter>
  Device-2: 3-3:3 info: Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse
  type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b74 class-ID: 0300
  serial: <filter>
  Hub-5: 3-4:4 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-7: 4-4:2 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
  chip-ID: 05e3:0620 class-ID: 0900
  System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 54 C
  Processes: 352 Uptime: 4h 19m wakeups: 0 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: 1520
  pacman: 1507 lib: 471 flatpak: 10 snap: 3 Shell: Bash v: 5.1.8
  running-in: gnome-terminal inxi: 3.3.05
Thanks in advance for your help!
:+1: Welcome to Manjaro! :+1:
Please read this:
Then file a bug upstream…
:crossed_fingers:
ME4595 filed the bug report upstream this morning. He was able to pinpoint which commit to muffin is associated with the issue. As such, he does not sound as much as a N00b to me.
:clap: :+1:
I think this is a first because normally people come back with:
Where should I file that?
if I don’t provide a direct link…
:innocent:
