ezro
25 September 2023 14:35
1
Hi everyone,
Recently just purchased a chuwi minibook x to just have a play on linux, im really enjoying manjaro so far, definitely my favorited distro ive come across, especially with gnome!
I apologise for my lingo upfront im still coming to terms with the terminology!
Ok so i have no bluetooth essentially, i try turning the radio button on and it flicks right off and does nothing.
Ive tried a couple of things from forums but nothing. (rfkill unblock bluetooth) and tried restarting the service but nothing.
Wondering if it could be a limitation of my minibook hardware?
Cheers,
Craig
Probably check this:
sudo dmesg | grep -i bluetooth
So that leads me directly to this old bug: https://bugzilla.kernel.org/show_bug.cgi?id=215167
$ errno 110
ETIMEDOUT 110 Connection timed out
Basically, it means that the device is not fully initialized when the driver connects to it and the driver doesn’t wait long enough.
Maybe reloading the driver:
sudo systemctl stop bluetooth.service
sudo modprobe -rv btusb && sleep 10 && sudo modprobe -v btusb
sudo systemctl start bluetooth.service
Let a second terminal open and monitor dmesg:
sudo d…
ezro
25 September 2023 15:04
3
Thanks for the reply, so i followed what was mentioned in that post, im getting this on the dmesg
[ 2444.663788] usbcore: deregistering interface driver btusb
[ 2455.038361] usbcore: registered new interface driver btusb
[ 2455.039811] Bluetooth: hci0: Device revision is 2
[ 2455.039817] Bluetooth: hci0: Secure boot is enabled
[ 2455.039818] Bluetooth: hci0: OTP lock is enabled
[ 2455.039819] Bluetooth: hci0: API lock is enabled
[ 2455.039820] Bluetooth: hci0: Debug lock is disabled
[ 2455.039820] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 2455.039822] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[ 2455.039848] Bluetooth: hci0: Failed to load Intel firmware file intel/ibt-0040-1050.sfi (-2)
[ 2455.040823] Bluetooth: hci0: Reading supported features failed (-56)
[ 2455.040827] Bluetooth: hci0: Error reading debug features
[ 2455.041794] Bluetooth: hci0: Failed to read MSFT supported features (-56)
Looks like the requested firmware for your device is not there.
When I read this: https://community.intel.com/t5/Wireless/AX101-Linux-driver/td-p/1465559 It seems that a symlink of
ibt-1040-4150.ddc → ibt-0040-1050.ddc
ibt-1040-4150.sfi → ibt-0040-1050.sfi
cd /usr/lib/firmware/intel
sudo ln -s ibt-1040-4150.ddc ibt-0040-1050.ddc
sudo ln -s ibt-1040-4150.sfi ibt-0040-1050.sfi
Make it work.
Or an upgrade to the kernel 6.5 could have a fix for that, as one mentioned that an upgrade to 6.4-rc7 fixed it.
ezro
25 September 2023 18:06
5
Wow thank you, those commands fixed it, this might be naive of me but as a new guy would you mind explaining what that is actually doing?
It simply creates a symbolic link of each file. So when the module searches for ibt-0040-1050.sfi
it will find it, but open ibt-1040-4150.sfi
system
Closed
28 September 2023 14:42
7
