For those of you who own this laptop model and have problem with internal audio speakers - No Dummy Audio issue for a year. Finally, the latest kernel 6.0.2 fixes this missing internal audio.
Experience i got in 6.0.2 thought you may need to know before installing:
- Slight random crackling sound will be present
- If you see Jasper Lake audio is shown but can’t hear a thing still despite highest volume was set,
then it’s time to check into Terminal and type alsamixer. press F6-> select the soundcard-> turn up all possible settings to max(DAC and headphone are the must). - touchpad is not working somehow in this version, if you use usb mouse, it’s ok.
Hope that helps
