I just installed Manjaro XFCE (the latest version from today). The installation of Chromium browser (from the official repository) went smoothly, but, when I try to open it nothing happens. When I try to run Chromium from the terminal, it gives this error:
/usr/lib/chromium/chromium: /usr/lib/libc.so.6: version `GLIBC_2.32' not found (required by /usr/lib/chromium/chromium)
If I try to install (build) any other version of Chromium from the AUR repository, I get this error message:
conflicting files:
- libxcrypt: /usr/include/crypt.h already exists in filesystem (owned by glibc)
- libxcrypt: /usr/lib/libcrypt.so already exists in filesystem (owned by glibc)
- libxcrypt: /usr/share/man/man3/crypt.3.gz already exists in filesystem (owned by man-pages)
- libxcrypt: /usr/share/man/man3/crypt_r.3.gz already exists in filesystem (owned by man-pages)
So, in effect, I am unable to install Chromium on this newly installed Manjaro. Could someone please help?
You were right - after updating the system, Chromium now opens normally. Thanks.
This update was rather big (over 1,5 gb), and my connection isn’t the fastest, so I thought I could elegantly skip this system update… well, obviously not.
It is a rolling release. 1.5 GB are , but you get a lot of brand new stuff. I would say 10 Gigs a month is normal. If you have more software installed then it becomes bigger. So better update as soon as possible.
