Hello,
Since a recent upgrade (probably in the current version 118), the Chromium downloaded from the official Manjaro repository gives an error specifically on the globo [dot] g1 [ dot] com website (brazilian news website). I’ve tried deleting the installation and configurations, opening it in an incognito tab, and so on. The site opens without any issues in Brave or Firefox.
The error code is: “Error code: SIGILL.”
I’ve researched this, and it seems like it could be a programming error on the website itself. However, I noticed that Chromium works fine on other operating systems (I tested it on Mac). It’s the same error on my son’s laptop, which also runs an updated Manjaro.
Since this error is limited to this particular website, I wanted to check here before reporting a possible bug to see if anyone else is experiencing this issue and has any ideas about what it might be.
Not sure it it is helpfull, but here is the Chromium console log when I try to open the page in a private tab. The site briefly opens and then gives the error (which leads me to believe it may be some JavaScript script causing the problem).
GET https://recomendacao.globo.com/rec/v2/user/g1/FEED?type=bastian&page=1&limit=10&photo_size=540x304/top/smart,810x456/top/smart,1080x608/top/smart&callback=bstn.cb.recommendationFirstFetch net::ERR_ABORTED 404 (Not Found)
(anonymous) @ (index):600
j @ (index):600
n @ (index):600
(index):600 [bastian] Recommendation failed to load at initialization. Need to fall back... Error: Network error
at Object.f [as recommendationFetchError] ((index):600:39028)
at HTMLScriptElement.onerror ((index):600:521963)
j @ (index):600
await in j (async)
n @ (index):600
45b99712fff76a76376f2040a22ace64.js:27 [TrendingVideos][AB] Failed to load GloboAB client
error @ 45b99712fff76a76376f2040a22ace64.js:27
(anonymous) @ 45b99712fff76a76376f2040a22ace64.js:27
u @ 45b99712fff76a76376f2040a22ace64.js:27
n @ 45b99712fff76a76376f2040a22ace64.js:27
c @ 45b99712fff76a76376f2040a22ace64.js:27
z @ 45b99712fff76a76376f2040a22ace64.js:27
45b99712fff76a76376f2040a22ace64.js:27 [TrendingVideos][AB] Trying again in 2 seconds...
lib-pub-core-g1-latest.js:2 ⚠️ document.browsingTopics() not supported.
api.min.js?loading-agent=global-webdeps:1 Player API loaded twice! Aborting.
(anonymous) @ api.min.js?loading-agent=global-webdeps:1
n @ api.min.js?loading-agent=global-webdeps:1
api.min.js?loading-agent=global-webdeps:1 Uncaught Error: Player API loaded twice! Aborting.
at Object.<anonymous> (api.min.js?loading-agent=global-webdeps:1:35052)
at n (api.min.js?loading-agent=global-webdeps:1:119)
at Object.<anonymous> (api.min.js?loading-agent=global-webdeps:1:34280)
at api.min.js?loading-agent=global-webdeps:1:925
at api.min.js?loading-agent=global-webdeps:1:935
api.min.js:1 [Player API] //s3.glbimg.com/v1/AUTH_e1b09a2d222b4900a437a46914be81e5/web/settings/stable/settings.min.js embedded!
lib-topics-0.0.3.js:2 topics not supported
pubads_impl.js:10 [GPT] Using deprecated googletag.encryptedSignalProviders. Please use googletag.secureSignalProviders instead.
OJ.log @ pubads_impl.js:10
Q @ pubads_impl.js:10
(anonymous) @ pubads_impl.js:10
Oj.push @ pubads_impl.js:10
Pj.push @ pubads_impl.js:10
(anonymous) @ esp.js:7
i @ esp.js:7
(anonymous) @ index.js:46
(anonymous) @ pubcid.min.js:1
(anonymous) @ esp.js:1
r @ esp.js:1
api.min.js:1 [Player API] player experiments alternatives: {player-isolated-experiment-02: {…}}
cadun.js:10 Uncaught (in promise) unauthorized
t.default @ cadun.js:10
t.GlbLocal @ glb.local.js:59
(anonymous) @ browser.js:10
o @ bootstrap:19
(anonymous) @ bootstrap:68
api.min.js:1 [Player API] version: stable
api.min.js:1 [Player API] bundle: player
api.min.js:1 [Player API] embedding: //s3.glbimg.com/v1/AUTH_e1b09a2d222b4900a437a46914be81e5/web/player/stable/player.min.js
send_signal @ encrypted-tag-g.js:6
(anonymous) @ encrypted-tag-g.js:6
player.min.js:1 [warn][Loader] unsupported plugin seek_time: Clappr version 0.6.1 does not match required range [0.4.20,0.5.20)
player.min.js:1 [warn][Loader] unsupported plugin clappr_stats: Clappr version 0.6.1 does not match required range [0.4.2,0.5.2)
player.min.js:1 [warn][Loader] unsupported plugin click_to_pause: Clappr version 0.6.1 does not match required range [0.4.20,0.5.20)
player.min.js:1 [warn][Loader] unsupported plugin hls: Clappr version 0.6.1 does not match required range [0.4.27,0.5.27)
