at start chromium browser always show keyring try multiple close help i can remove keyring?
There are already many entries on this topic here in the forum. You should familiarize yourself with the search function. You can learn a lot in the process. I speak from my own experience.
Chromium uses a password store to store your passwords and the Chromium Safe Storage key, which is used to encrypt cookie values. Under Xfce the GNOME Keyring is used for this. So you should think twice if you really want to remove it.
