I am using an RPI 5, 8GB, with the MATE desktop, running on the unstable branch. I just updated chromium to Version 122.0.6261.111.
chrome://gpu now gives:
* Canvas: Software only, hardware acceleration unavailable
* Canvas out-of-process rasterization: Disabled
* Direct Rendering Display Compositor: Disabled
* Compositing: Software only. Hardware acceleration disabled
* Multiple Raster Threads: Enabled
* OpenGL: Disabled
* Rasterization: Software only. Hardware acceleration disabled
* Raw Draw: Disabled
* Skia Graphite: Disabled
* Video Decode: Software only. Hardware acceleration disabled
* Video Encode: Software only. Hardware acceleration disabled
* Vulkan: Disabled
* WebGL: Software only, hardware acceleration unavailable
* WebGL2: Software only, hardware acceleration unavailable
* WebGPU: Disabled
Appropriate flags are enabled.
I ran webgl aquarium, which works at about 10% of normal speed, so hardware acceleration is definitely not working.
When I run chromium from the command line, I get very many errors like this:
ERR: Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: GLX is not present.
[50851:50851:0314/121617.671494:ERROR:gl_display.cc(515)] EGL Driver message (Critical) eglInitialize: GLX is not present.
[50851:50851:0314/121617.671544:ERROR:gl_display.cc(786)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[50851:50851:0314/121617.671766:ERROR:angle_platform_impl.cc(44)] Display.cpp:1052 (initialize): ANGLE Display::initialize error 12289: GLX is not present.
Thanks for your help.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
