Chromium/Chrome on Plasma on Wayland with GPU acceleration
Hello,
I recently moved to Wayland with Plasma. I tried to run Chromium (and Chrome) as native wayland clients with these params:
--enable-features=UseOzonePlatform --ozone-platform=wayland
and this is what I get:
[23837:23837:0102/013356.784308:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[23837:23837:0102/013356.791753:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[23803:23803:0102/013356.886822:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[23837:23837:0102/013357.054348:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[23837:23837:0102/013357.054857:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[23837:23837:0102/013357.055294:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[23837:23837:0102/013357.055440:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[23837:23837:0102/013357.055579:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[23837:23837:0102/013357.055714:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[23837:23837:0102/013357.055959:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[23837:23837:0102/013357.056279:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[23837:23837:0102/013357.057902:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[23837:23837:0102/013357.058239:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[23837:23837:0102/013357.076924:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[23837:23837:0102/013357.077124:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[23837:23837:0102/013357.120252:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[23837:23837:0102/013357.121625:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[23837:23837:0102/013357.121742:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[23837:23837:0102/013357.121806:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[23837:23837:0102/013357.121887:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[23837:23837:0102/013357.121952:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[23803:23803:0102/013358.223590:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[23882:1:0102/013358.242005:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[23971:23971:0102/013358.294504:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[23971:23971:0102/013358.298291:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[23971:23971:0102/013358.324097:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[23971:23971:0102/013358.324192:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[23971:23971:0102/013358.324248:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[23971:23971:0102/013358.324293:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[23971:23971:0102/013358.324339:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[23971:23971:0102/013358.324377:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[23971:23971:0102/013358.324482:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[23971:23971:0102/013358.324593:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[23882:1:0102/013358.324761:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[23971:23971:0102/013358.325578:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[23971:23971:0102/013358.325689:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[23971:23971:0102/013358.325783:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[23971:23971:0102/013358.325920:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[23971:23971:0102/013358.326579:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[23971:23971:0102/013358.349597:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[23971:23971:0102/013358.349712:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[23971:23971:0102/013358.349788:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[23971:23971:0102/013358.349846:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[23971:23971:0102/013358.349892:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[23971:23971:0102/013358.349942:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[23882:1:0102/013359.164092:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[23803:23803:0102/013359.231593:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[23803:23818:0102/013359.349432:ERROR:chrome_browser_main_extra_parts_metrics.cc(226)] crbug.com/1216328: Checking Bluetooth availability started. Please report if there is no report that this ends.
[23803:23818:0102/013359.349520:ERROR:chrome_browser_main_extra_parts_metrics.cc(229)] crbug.com/1216328: Checking Bluetooth availability ended.
[23803:23818:0102/013359.349563:ERROR:chrome_browser_main_extra_parts_metrics.cc(232)] crbug.com/1216328: Checking default browser status started. Please report if there is no report that this ends.
[23999:23999:0102/013359.410292:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[23999:23999:0102/013359.417533:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[23803:23818:0102/013359.448650:ERROR:chrome_browser_main_extra_parts_metrics.cc(236)] crbug.com/1216328: Checking default browser status ended.
[23999:23999:0102/013359.459394:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[23999:23999:0102/013359.459532:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[23999:23999:0102/013359.459618:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[23999:23999:0102/013359.459668:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[23999:23999:0102/013359.459725:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[23999:23999:0102/013359.459769:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[23999:23999:0102/013359.459931:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[23999:23999:0102/013359.460049:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[23999:23999:0102/013359.460135:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[23999:23999:0102/013359.461440:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[23999:23999:0102/013359.500649:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[23999:23999:0102/013359.501223:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[23999:23999:0102/013359.512545:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[23999:23999:0102/013359.512705:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[23999:23999:0102/013359.513064:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[23999:23999:0102/013359.513178:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[23999:23999:0102/013359.513307:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[23999:23999:0102/013359.513491:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[23882:1:0102/013400.238568:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[23803:23803:0102/013400.294170:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[24054:24054:0102/013400.329559:ERROR:angle_platform_impl.cc(44)] Display.cpp:894 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1048.
[24054:24054:0102/013400.329805:ERROR:gl_surface_egl.cc(782)] EGL Driver message (Critical) eglInitialize: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1048.
[24054:24054:0102/013400.329925:ERROR:gl_surface_egl.cc(1382)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[24054:24054:0102/013400.330035:ERROR:gl_ozone_egl.cc(20)] GLSurfaceEGL::InitializeOneOff failed.
[24054:24054:0102/013400.332029:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
the result is that the window is not even visible, or, if it is visible (sometimes I got it), I have no Intel HD graphics acceleration. I see that the log is talking about Vulkan: is that the proper configuration? Anyone able to run Chromium (or Chrome) on Wayland with hardware graphics acceleration?
Thanks!
Oh yes we are mind readers, so we know exactly what your hardware is without being told.
Hardware: Intel Xeon E3-1505M v6, GPU is Intel HD Graphics P630. The system includes a nVidia GPU, but I blacklisted it cause it was making a mess on Wayland.
If you need more info, it is sufficient to ask. If you have other rude answers, please provide your knowledge to someone else.
Apparently, your CPU/GPU is a Kaby Lake, which mine also is. It works for me on Chrome with Wayland, but there will often be graphical glitches, like disappearing images and text. I have no glitches with the x11 ozone backend.
According to the logs, it seems like it is trying to use Vulkan instead of OGL. So maybe there is something wrong with the setup. Would it be possible for you to kindly post the params you are passing to Chromium and the logs that are printed, so that I can compare and see if I can find the difference? Maybe I installed something related to Vulkan that Chromium is trying to use…
Thank you.
here comes the archwiki :point_down:
https://wiki.archlinux.org/title/chromium#Running_on_XWayland
https://wiki.archlinux.org/title/chromium#Forcing_specific_GPU
Yes, I already read that. The first link seems to be off topic, I’m referring to wayland native clients. XWayland is not usable in my case cause I’m on highdpi.
For the second link, I don’t see a different result between the two:
chromium --enable-features=UseOzonePlatform --ozone-platform=wayland --gpu-testing-vendor-id=0x0x10de --gpu-testing-device-id=0x13b6
[6423:6423:0102/121441.420201:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[6423:6423:0102/121441.423942:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[6387:6387:0102/121441.448055:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[6387:6387:0102/121441.528083:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[6387:6387:0102/121441.530268:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[6423:6423:0102/121441.640375:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6423:6423:0102/121441.640487:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage SCANOUT
[6423:6423:0102/121441.640551:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6423:6423:0102/121441.640597:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage GPU_READ
[6423:6423:0102/121441.640639:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6423:6423:0102/121441.640677:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6423:6423:0102/121441.640813:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6423:6423:0102/121441.641123:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6423:6423:0102/121441.641226:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6423:6423:0102/121441.644073:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6423:6423:0102/121441.645560:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6423:6423:0102/121441.645818:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6423:6423:0102/121441.645941:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6423:6423:0102/121441.646533:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6423:6423:0102/121441.647211:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6423:6423:0102/121441.736423:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6423:6423:0102/121441.736567:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage SCANOUT
[6423:6423:0102/121441.736634:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6423:6423:0102/121441.736685:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage GPU_READ
[6423:6423:0102/121441.736750:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6423:6423:0102/121441.736804:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6387:6387:0102/121442.434568:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[6456:1:0102/121442.434492:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[6457:1:0102/121442.434508:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[6566:6566:0102/121442.487885:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[6566:6566:0102/121442.491353:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[6566:6566:0102/121442.588826:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6566:6566:0102/121442.588905:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage SCANOUT
[6566:6566:0102/121442.588957:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6566:6566:0102/121442.589007:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage GPU_READ
[6566:6566:0102/121442.589049:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6566:6566:0102/121442.589090:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6566:6566:0102/121442.589209:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6566:6566:0102/121442.589700:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6566:6566:0102/121442.589806:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6566:6566:0102/121442.589901:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6566:6566:0102/121442.589994:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6566:6566:0102/121442.590932:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6566:6566:0102/121442.591911:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6566:6566:0102/121442.612396:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6566:6566:0102/121442.616717:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6566:6566:0102/121442.617257:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6566:6566:0102/121442.678746:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6566:6566:0102/121442.678953:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage SCANOUT
[6566:6566:0102/121442.679005:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6566:6566:0102/121442.679043:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage GPU_READ
[6566:6566:0102/121442.679085:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6566:6566:0102/121442.679144:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6457:1:0102/121443.369975:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[6387:6387:0102/121443.376438:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[6602:6602:0102/121443.441962:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[6602:6602:0102/121443.445530:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[6602:6602:0102/121443.539592:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6602:6602:0102/121443.539702:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage SCANOUT
[6602:6602:0102/121443.539765:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6602:6602:0102/121443.539828:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage GPU_READ
[6602:6602:0102/121443.539878:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6602:6602:0102/121443.539921:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6602:6602:0102/121443.540036:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6602:6602:0102/121443.540133:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6602:6602:0102/121443.541691:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6602:6602:0102/121443.541999:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6602:6602:0102/121443.542132:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6602:6602:0102/121443.542264:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6602:6602:0102/121443.542340:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6602:6602:0102/121443.542450:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6602:6602:0102/121443.542947:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6602:6602:0102/121443.543010:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6602:6602:0102/121443.543060:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6602:6602:0102/121443.543108:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6602:6602:0102/121443.545548:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6602:6602:0102/121443.546261:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6602:6602:0102/121443.546698:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6456:1:0102/121443.546821:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[6387:6387:0102/121443.547256:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[6602:6602:0102/121443.547251:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6602:6602:0102/121443.618815:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6602:6602:0102/121443.618969:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage SCANOUT
[6602:6602:0102/121443.619026:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6602:6602:0102/121443.619069:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 4096x2560, RGBA_8888, usage GPU_READ
[6602:6602:0102/121443.619110:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6602:6602:0102/121443.619150:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6387:6387:0102/121444.299760:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[6632:6632:0102/121444.310784:ERROR:angle_platform_impl.cc(44)] Display.cpp:894 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1048.
[6632:6632:0102/121444.310981:ERROR:gl_surface_egl.cc(782)] EGL Driver message (Critical) eglInitialize: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1048.
[6632:6632:0102/121444.311028:ERROR:gl_surface_egl.cc(1382)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[6632:6632:0102/121444.311071:ERROR:gl_ozone_egl.cc(20)] GLSurfaceEGL::InitializeOneOff failed.
[6632:6632:0102/121444.313222:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
[6639:6639:0102/121444.324616:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is disabled, ANGLE is
[6639:6646:0102/121444.329236:ERROR:wayland_buffer_manager_gpu.cc(107)] WaylandBufferManagerGpu is not initialized. Can't register a surface.
[6387:6387:0102/121444.403676:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[6387:6418:0102/121444.606431:ERROR:chrome_browser_main_extra_parts_metrics.cc(226)] crbug.com/1216328: Checking Bluetooth availability started. Please report if there is no report that this ends.
[6387:6418:0102/121444.606463:ERROR:chrome_browser_main_extra_parts_metrics.cc(229)] crbug.com/1216328: Checking Bluetooth availability ended.
[6387:6418:0102/121444.606470:ERROR:chrome_browser_main_extra_parts_metrics.cc(232)] crbug.com/1216328: Checking default browser status started. Please report if there is no report that this ends.
[6387:6418:0102/121444.654157:ERROR:chrome_browser_main_extra_parts_metrics.cc(236)] crbug.com/1216328: Checking default browser status ended.
[6387:6387:0102/121449.142339:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[6387:6387:0102/121449.561933:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[6387:6387:0102/121506.099403:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
and
chromium --enable-features=UseOzonePlatform --ozone-platform=wayland --gpu-testing-vendor-id=0x8086 --gpu-testing-device-id=0x591d
[6860:6860:0102/121523.461953:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[6860:6860:0102/121523.465296:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[6823:6823:0102/121523.488644:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[6823:6823:0102/121523.608193:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[6823:6823:0102/121523.614543:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[6860:6860:0102/121523.684258:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6860:6860:0102/121523.684344:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[6860:6860:0102/121523.684411:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6860:6860:0102/121523.684476:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[6860:6860:0102/121523.684535:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6860:6860:0102/121523.684590:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6860:6860:0102/121523.684727:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6860:6860:0102/121523.685034:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6860:6860:0102/121523.685104:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6860:6860:0102/121523.685292:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6860:6860:0102/121523.688256:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6860:6860:0102/121523.688781:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6823:6823:0102/121523.689198:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[6860:6860:0102/121523.726989:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6860:6860:0102/121523.727144:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[6860:6860:0102/121523.727245:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6860:6860:0102/121523.727311:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[6860:6860:0102/121523.727357:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6860:6860:0102/121523.727433:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6823:6823:0102/121524.367151:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[6892:1:0102/121524.390028:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[6980:6980:0102/121524.454056:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[6980:6980:0102/121524.457656:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[6980:6980:0102/121524.484729:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6980:6980:0102/121524.484826:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[6980:6980:0102/121524.484882:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6980:6980:0102/121524.484936:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[6980:6980:0102/121524.484987:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6980:6980:0102/121524.485034:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6980:6980:0102/121524.485175:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6980:6980:0102/121524.485684:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6892:1:0102/121524.485854:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[6980:6980:0102/121524.486644:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6980:6980:0102/121524.486738:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6980:6980:0102/121524.486861:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[6980:6980:0102/121524.486996:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6980:6980:0102/121524.487528:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6980:6980:0102/121524.504709:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[6980:6980:0102/121524.504796:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[6980:6980:0102/121524.504856:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[6980:6980:0102/121524.504897:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[6980:6980:0102/121524.504930:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[6980:6980:0102/121524.504963:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6892:1:0102/121525.111108:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[6823:6823:0102/121525.114046:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[7026:7026:0102/121525.184982:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[7026:7026:0102/121525.188525:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[7026:7026:0102/121525.213740:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[7026:7026:0102/121525.213880:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[7026:7026:0102/121525.213988:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[7026:7026:0102/121525.214031:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[7026:7026:0102/121525.214070:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[7026:7026:0102/121525.214107:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[7026:7026:0102/121525.214220:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7026:7026:0102/121525.214291:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[7026:7026:0102/121525.215092:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[7026:7026:0102/121525.215466:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[6823:6823:0102/121525.215521:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[7026:7026:0102/121525.215522:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7026:7026:0102/121525.215617:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[6892:1:0102/121525.215741:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[7026:7026:0102/121525.215994:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7026:7026:0102/121525.216056:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7026:7026:0102/121525.231229:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[7026:7026:0102/121525.231408:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[7026:7026:0102/121525.231475:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[7026:7026:0102/121525.231523:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[7026:7026:0102/121525.231597:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[7026:7026:0102/121525.231637:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[6892:1:0102/121525.817047:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[6823:6823:0102/121525.817495:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[7056:7056:0102/121525.830219:ERROR:angle_platform_impl.cc(44)] Display.cpp:894 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1048.
[7056:7056:0102/121525.830626:ERROR:gl_surface_egl.cc(782)] EGL Driver message (Critical) eglInitialize: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1048.
[7056:7056:0102/121525.830790:ERROR:gl_surface_egl.cc(1382)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[7056:7056:0102/121525.830908:ERROR:gl_ozone_egl.cc(20)] GLSurfaceEGL::InitializeOneOff failed.
[7056:7056:0102/121525.832519:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
[7063:7063:0102/121525.842251:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is disabled, ANGLE is
[7063:7070:0102/121525.846582:ERROR:wayland_buffer_manager_gpu.cc(107)] WaylandBufferManagerGpu is not initialized. Can't register a surface.
[6823:6871:0102/121526.178234:ERROR:chrome_browser_main_extra_parts_metrics.cc(226)] crbug.com/1216328: Checking Bluetooth availability started. Please report if there is no report that this ends.
[6823:6871:0102/121526.178255:ERROR:chrome_browser_main_extra_parts_metrics.cc(229)] crbug.com/1216328: Checking Bluetooth availability ended.
[6823:6871:0102/121526.178265:ERROR:chrome_browser_main_extra_parts_metrics.cc(232)] crbug.com/1216328: Checking default browser status started. Please report if there is no report that this ends.
[6823:6871:0102/121526.225924:ERROR:chrome_browser_main_extra_parts_metrics.cc(236)] crbug.com/1216328: Checking default browser status ended.
❯ chromium --enable-features=UseOzonePlatform --ozone-platform=wayland --gpu-testing-vendor-id=0x0x10de --gpu-testing-device-id=0x13b6
[7198:7198:0102/121534.374672:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[7198:7198:0102/121534.379857:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[7162:7162:0102/121534.393513:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[7162:7162:0102/121534.484824:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[7162:7162:0102/121534.489214:ERROR:cursor_loader.cc(114)] Failed to load a platform cursor of type kNull
[7198:7198:0102/121534.548819:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[7198:7198:0102/121534.548946:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[7198:7198:0102/121534.549027:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[7198:7198:0102/121534.549091:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[7198:7198:0102/121534.549155:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[7198:7198:0102/121534.549213:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[7198:7198:0102/121534.549340:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7198:7198:0102/121534.549612:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7198:7198:0102/121534.549761:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7198:7198:0102/121534.549851:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[7198:7198:0102/121534.550487:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[7198:7198:0102/121534.551644:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[7198:7198:0102/121534.579931:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[7198:7198:0102/121534.580140:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[7198:7198:0102/121534.580191:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[7198:7198:0102/121534.580233:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[7198:7198:0102/121534.580272:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[7198:7198:0102/121534.580335:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[7162:7162:0102/121535.276541:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[7238:1:0102/121535.276509:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[7345:7345:0102/121535.329064:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[7345:7345:0102/121535.332618:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[7345:7345:0102/121535.366144:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[7345:7345:0102/121535.366237:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[7345:7345:0102/121535.366300:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[7345:7345:0102/121535.366359:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[7345:7345:0102/121535.366435:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[7345:7345:0102/121535.366480:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[7345:7345:0102/121535.366596:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7345:7345:0102/121535.368945:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7345:7345:0102/121535.369080:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7345:7345:0102/121535.369169:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[7345:7345:0102/121535.369253:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[7345:7345:0102/121535.369595:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[7345:7345:0102/121535.386542:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[7345:7345:0102/121535.386685:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[7345:7345:0102/121535.386756:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[7345:7345:0102/121535.386827:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[7345:7345:0102/121535.386901:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[7345:7345:0102/121535.386975:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[7238:1:0102/121536.012259:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[7162:7162:0102/121536.014423:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[7375:7375:0102/121536.078275:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is egl, ANGLE is
[7375:7375:0102/121536.082091:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
[7375:7375:0102/121536.097993:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[7375:7375:0102/121536.098091:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[7375:7375:0102/121536.098141:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[7375:7375:0102/121536.098181:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[7375:7375:0102/121536.098224:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[7375:7375:0102/121536.098263:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[7375:7375:0102/121536.098370:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7375:7375:0102/121536.098594:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7375:7375:0102/121536.098657:ERROR:skia_output_surface_impl_on_gpu.cc(1319)] Failed to make current.
[7375:7375:0102/121536.098777:ERROR:raster_decoder.cc(1233)]   RasterDecoderImpl: Context lost during MakeCurrent.
[7375:7375:0102/121536.102075:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[7375:7375:0102/121536.102952:ERROR:shared_image_stub.cc(534)] SharedImageStub: context already lost
[7162:7162:0102/121536.103242:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
[7375:7375:0102/121536.116261:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=SCANOUT
[7375:7375:0102/121536.116432:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage SCANOUT
[7375:7375:0102/121536.116551:ERROR:gbm_pixmap_wayland.cc(76)] Cannot create bo with format= RGBA_8888 and usage=GPU_READ
[7375:7375:0102/121536.116638:ERROR:gpu_memory_buffer_factory_native_pixmap.cc(260)] Failed to create pixmap 1280x512, RGBA_8888, usage GPU_READ
[7375:7375:0102/121536.116721:ERROR:shared_image_backing_factory_gl_image.cc(351)] CreateSharedImage: Failed to create bindable image
[7375:7375:0102/121536.116797:ERROR:shared_image_factory.cc(584)] CreateSharedImage: could not create backing.
[7162:7162:0102/121536.768667:ERROR:gpu_process_host.cc(967)] GPU process exited unexpectedly: exit_code=133
[7398:7398:0102/121536.778446:ERROR:angle_platform_impl.cc(44)] Display.cpp:894 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1048.
[7398:7398:0102/121536.778633:ERROR:gl_surface_egl.cc(782)] EGL Driver message (Critical) eglInitialize: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1048.
[7398:7398:0102/121536.778778:ERROR:gl_surface_egl.cc(1382)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[7398:7398:0102/121536.778965:ERROR:gl_ozone_egl.cc(20)] GLSurfaceEGL::InitializeOneOff failed.
[7398:7398:0102/121536.780397:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
[7405:7405:0102/121536.788443:ERROR:gpu_init.cc(457)] Passthrough is not supported, GL is disabled, ANGLE is
[7405:7412:0102/121536.792217:ERROR:wayland_buffer_manager_gpu.cc(107)] WaylandBufferManagerGpu is not initialized. Can't register a surface.
[7162:7212:0102/121537.606697:ERROR:chrome_browser_main_extra_parts_metrics.cc(226)] crbug.com/1216328: Checking Bluetooth availability started. Please report if there is no report that this ends.
[7162:7212:0102/121537.606897:ERROR:chrome_browser_main_extra_parts_metrics.cc(229)] crbug.com/1216328: Checking Bluetooth availability ended.
[7162:7212:0102/121537.606905:ERROR:chrome_browser_main_extra_parts_metrics.cc(232)] crbug.com/1216328: Checking default browser status started. Please report if there is no report that this ends.
[7162:7212:0102/121537.655728:ERROR:chrome_browser_main_extra_parts_metrics.cc(236)] crbug.com/1216328: Checking default browser status ended.
Thank you for your answer.
This one works on my laptop with intel HD.
Just tested it, thanks for the advice. Here, it does start but it does not seem to work well. Many bugs and it is frequently broken right after it is starts. Also no webgl support. I thought Chromium was almost ready for Wayland, but I see they are not near.
