Chromium, Brave crash in Wayland mode on GNOME
Hello,
I normally use Brave and there is an issue that’s been going on for at least 6 months.
When I try to run Brave in Wayland mode - either with brave --ozone-platform=wayland or just default launcher - it cannot start, crashing like this:
[2846:2846:1112/194218.246972:ERROR:content/browser/gpu/gpu_process_host.cc:999] GPU process exited unexpectedly: exit_code=139
[2846:2846:1112/194218.391945:ERROR:content/browser/gpu/gpu_process_host.cc:999] GPU process exited unexpectedly: exit_code=139
[2846:2846:1112/194218.530838:ERROR:content/browser/gpu/gpu_process_host.cc:999] GPU process exited unexpectedly: exit_code=139
[2846:2846:1112/194218.530855:FATAL:content/browser/gpu/gpu_data_manager_impl_private.cc:415] GPU process isn't usable. Goodbye.
I just installed Chromum with pamac and this command chromium --ozone-platform=wayland crashes the same way:
[4733:4733:1112/194319.777914:ERROR:content/browser/gpu/gpu_process_host.cc:999] GPU process exited unexpectedly: exit_code=139
[4733:4733:1112/194319.953534:ERROR:content/browser/gpu/gpu_process_host.cc:999] GPU process exited unexpectedly: exit_code=139
[4733:4733:1112/194320.117131:ERROR:content/browser/gpu/gpu_process_host.cc:999] GPU process exited unexpectedly: exit_code=139
[4733:4733:1112/194320.117178:FATAL:content/browser/gpu/gpu_data_manager_impl_private.cc:415] GPU process isn't usable. Goodbye.
Brave version:
Brave 1.84.139 (Official Build) (64-bit)
Chromium: 142.0.7444.163
Chromium version:
Version 142.0.7444.134 (Official Build) Arch Linux (64-bit)
But as mentioned above, I’ve been seeing it with Brave for at least a few months. It’s pretty annoying :slight_smile:
Both Brave and Chrome work just fine for me in Ubuntu on the same hardware (and also GNOME and same NVIDIA driver).
My computer is a “desktop” (tower) with an Intel Ultra 265 and an NVIDIA 4080 graphics card. I use NVIDIA’s “open” driver version 580 but it happened with the previous driver too. I have two 4K 27” displays scaled at 150%.
And here is inxi:
inxi -GADMC
  Type: Desktop Mobo: Micro-Star model: PRO Z890-A WIFI (MS-7E32) v: 2.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: 2.A20
    date: 08/22/2024
  Info: 20-core model: Intel Core Ultra 7 265 bits: 64 type: MCP cache:
    L2: 36 MiB
  Speed (MHz): avg: 800 min/max: 800/5300:5400:4600 cores: 1: 800 2: 800
    3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
    13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
  Device-1: Intel Arrow Lake-S [Intel Graphics] driver: i915 v: kernel
  Device-2: NVIDIA AD103 [GeForce RTX 4080] driver: nvidia v: 580.82.09
  Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB
    compositor: gnome-shell v: 48.5 driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch resolution: 1: 5120x2880~60Hz
    2: 5120x2880~120Hz
  API: EGL v: 1.5 drivers: iris,nvidia,swrast
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
    renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop,xrandr
  Device-1: NVIDIA driver: snd_hda_intel
  Device-2: Intel driver: snd_hda_intel
    type: USB
  Device-4: Thesycon System & Consulting GmbH DX1 driver: snd-usb-audio
    type: USB
  API: ALSA v: k6.17.1-0-MANJARO status: kernel-api
  Server-1: PulseAudio v: 17.0-43-g3e2bb status: active
  Local Storage: total: 6.37 TiB used: 272.99 GiB (4.2%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN850X 1000GB
  ID-2: /dev/nvme1n1 vendor: Crucial model: CT1000P5PSSD8 size: 931.51 GiB
  ID-3: /dev/nvme2n1 vendor: Crucial model: CT1000P5PSSD8 size: 931.51 GiB
  ID-4: /dev/sda vendor: Western Digital model: WD40EFZX-68AWUN0
I’m not aware of the current status of experimental features in Chromium based browsers, however, maybe you need both of these:
  • --enable-features=UseOzonePlatform
  • --ozone-platform=wayland
Please provide your full system information as described (below).
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
Be prepared to provide output from commands when asked. It is equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Simply waiting for others to ask you questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – instead, please help others to make informed suggestions based on information you provide.
System Information
short-form: inxi -zv8
long-form: inxi --filter --verbosity=8
Running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
I don’t think Wayland is experimental anymore. And yes I’m running Brave / Chromium in Wayland mode.
And here is inxi -zv8
  Kernel: 6.17.1-0-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    clocksource: tsc avail: hpet,acpi_pm parameters: ro
    root=UUID=a24ea5cd-76ad-4bf7-9b7b-45b2b4a10704
    initrd=boot\initramfs-6.17-x86_64.img
  Desktop: GNOME v: 48.5 tk: GTK v: 3.24.50 wm: gnome-shell
    base: Arch Linux
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 2.A20 date: 08/22/2024
  System RAM: total: 48 GiB available: 46.42 GiB used: 2.68 GiB (5.8%)
  Device-1: DIMMA1 type: no module installed
  Device-2: DIMMA2 type: DDR5 detail: synchronous size: 24 GiB
    speed: 4800 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Corsair part-no: CMH48GX5M2B6800C34
    serial: N/A
  Device-3: DIMMB1 type: no module installed
  Device-4: DIMMB2 type: DDR5 detail: synchronous size: 24 GiB
    serial: N/A
  Info: model: Intel Core Ultra 7 265 bits: 64 type: MCP arch: Arrow Lake
    level: v3 note: check built: 2024+ process: Intel 20a (2nm) family: 6
    model-id: 0xC6 (198) stepping: 2 microcode: 0x110
  Topology: cpus: 1x dies: 1 clusters: 11 cores: 20 smt: <unsupported>
    cache: L1: 2 MiB desc: d-12x32 KiB, 8x48 KiB; i-20x64 KiB L2: 36 MiB
    desc: 8x3 MiB, 3x4 MiB L3: 30 MiB desc: 1x30 MiB
  Speed (MHz): avg: 800 min/max: 800/5300:5400:4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 95232
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
    flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lam lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep
    smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg wbnoinvd x2apic
    conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Arrow Lake-S [Intel Graphics] vendor: Micro-Star MSI
    driver: i915 v: kernel alternate: xe arch: Xe2-LPG process: TSMC n3 (3nm)
    built: 2025+ ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2,
    HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:7d67 class-ID: 0300
  Device-2: NVIDIA AD103 [GeForce RTX 4080] vendor: Micro-Star MSI
    driver: nvidia v: 580.82.09 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-08) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-3,HDMI-A-1
    empty: DP-1,DP-2 bus-ID: 02:00.0 chip-ID: 10de:2704 class-ID: 0300
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6.1.3:10
    chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
    compositor: gnome-shell driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: DP-3 model: Dell U2723QE serial: <filter> built: 2024
    res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.678 y: 0.314 green:
    x: 0.267 y: 0.678 blue: x: 0.145 y: 0.059 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 3840x2160, 2560x1440, 2048x1280, 2048x1152, 1920x1200, 2048x1080,
    1920x1080, 1600x1200, 1680x1050, 1280x1024, 1280x800, 1152x864, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480
  Monitor-2: HDMI-A-1 model: MSI MAG 274UPF E2 serial: <filter> built: 2024
    res: 3840x2160 dpi: 165 gamma: 1.2 chroma: red: x: 0.698 y: 0.294 green:
    x: 0.251 y: 0.702 blue: x: 0.153 y: 0.043 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 681mm (26.8") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024, 1440x900,
    1280x960, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 96 2: parse_edid:
    unhandled CEA mode 97 3: parse_edid: unhandled CEA mode 118 4: parse_edid:
    unknown tag 112
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
    inactive: device-2
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4080/PCIe/SSE2
    memory: 15.62 GiB display-ID: :0.0
    x11: xprop,xrandr
  Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
    alternate: nova_core pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 02:00.1
    chip-ID: 10de:22bb class-ID: 0403
  Device-2: Intel vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_mtl bus-ID: 80:1f.3 chip-ID: 8086:7f50
    class-ID: 0403
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6.1.4:11
    chip-ID: 152a:8750 class-ID: fe01
  API: ALSA v: k6.17.1-0-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.8 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 port: 3000 bus-ID: 82:00.0
    chip-ID: 10ec:8126 class-ID: 0200
  IF: enp130s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 7 AX1775 /AX1790 /BE20 /BE401/BE1750 2x2
    driver: iwlwifi v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 1
    bus-ID: 83:00.0 chip-ID: 8086:272b class-ID: 0280
  IF: wlan0 state: down mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Info: services: iwd, NetworkManager, systemd-timesyncd, wpa_supplicant
  Device-1: Intel BE200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:7 chip-ID: 8087:0036
    class-ID: e001
  Local Storage: total: 6.37 TiB used: 271.95 GiB (4.2%)
    model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 620281WD temp: 36.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Crucial model: CT1000P5PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 34.9 C
    scheme: GPT
  ID-3: /dev/nvme2n1 maj-min: 259:12 vendor: Crucial model: CT1000P5PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 38.9 C
    scheme: GPT
  ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD40EFZX-68AWUN0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0B81 scheme: GPT
  ID-1: / raw-size: 64 GiB size: 62.44 GiB (97.57%) used: 19.31 GiB (30.9%)
    fs: ext4 dev: /dev/nvme2n1p3 maj-min: 259:15 label: Manjaro root
    uuid: a24ea5cd-76ad-4bf7-9b7b-45b2b4a10704
  ID-2: /boot/efi raw-size: 1.1 GiB size: 1.1 GiB (99.80%)
    used: 49.1 MiB (4.4%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3 label: N/A
    uuid: 6AC0-6EF2
  ID-3: /home raw-size: 300.86 GiB size: 295.07 GiB (98.08%)
    used: 69.67 GiB (23.6%) fs: ext4 dev: /dev/nvme2n1p4 maj-min: 259:16
    label: Manjaro home uuid: 90d1e93c-b065-4dc2-91ee-fe0acbcfce24
  ID-4: /mnt/android raw-size: 256 GiB size: 250.93 GiB (98.02%)
    used: 63.08 GiB (25.1%) fs: ext4 dev: /dev/nvme2n1p2 maj-min: 259:14
    label: Android uuid: c2e8d099-ca44-464c-a448-2286637f2a84
  ID-5: /mnt/archive raw-size: 200 GiB size: 195.8 GiB (97.90%)
    used: 114.52 GiB (58.5%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: Archive
    uuid: 4a02bc65-eb45-4885-9bde-1b976d22ba25
  ID-6: /mnt/shared raw-size: 200 GiB size: 199.99 GiB (100.00%)
    used: 5.32 GiB (2.7%) fs: exfat dev: /dev/sda2 maj-min: 8:2 label: Shared
    uuid: 3683-F290
  ID-1: swap-1 type: partition size: 30 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p7 maj-min: 259:9 label: N/A
    uuid: c35889f2-0153-4504-ba21-1bc48d7fcaf7
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 931.51 GiB fs: ntfs label: Games
    uuid: FCBCD20EBCD1C2F6
  ID-2: /dev/nvme1n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:5 size: 300 GiB fs: ntfs label: N/A
    uuid: 641EC13C1EC107CE
  ID-4: /dev/nvme1n1p4 maj-min: 259:6 size: 1022 MiB fs: ntfs label: N/A
    uuid: 1878CBF478CBCEA6
  ID-5: /dev/nvme1n1p5 maj-min: 259:7 size: 200 GiB fs: ntfs label: Data
    uuid: 7C70C19370C15514
  ID-6: /dev/nvme1n1p6 maj-min: 259:8 size: 64 GiB fs: ext4
    label: Ubuntu system uuid: b04d8e88-3ee5-4fba-946b-4a5d1f4ee4b2
  ID-7: /dev/nvme1n1p8 maj-min: 259:10 size: 334.81 GiB fs: ext4
    label: Ubuntu home uuid: 775bf132-112b-4ba4-af05-d4d6aa5a7174
  ID-8: /dev/nvme1n1p9 maj-min: 259:11 size: 604 MiB fs: ntfs label: N/A
    uuid: 88E6B47EE6B46E56
  ID-9: /dev/nvme2n1p1 maj-min: 259:13 size: 16 MiB fs: <superuser required>
  ID-10: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Hub-4: 3-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-5:3 info: ACRUX Receiver Update type: HID
    lanes: 1 mode: 1.1 power: 200mA chip-ID: 1a34:f517 class-ID: 0300
  Hub-5: 3-6:4 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Hub-6: 3-6.1:6 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 3-6.1.1:8 info: Shenzhen Rapoo Gaming Device type: mouse,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 400mA
    chip-ID: 24ae:1244 class-ID: 0300 serial: <filter>
  Device-2: 3-6.1.2:9 info: Razer USA DSV2Pro TKL type: keyboard,mouse,HID
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0298 class-ID: 0300
  Device-3: 3-6.1.3:10 info: Logitech C920 PRO HD Webcam type: video,audio
  Device-4: 3-6.1.4:11 info: Thesycon System & Consulting GmbH DX1
    type: audio driver: snd-usb-audio interfaces: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 152a:8750
    class-ID: fe01
  Device-5: 3-13:5 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0db0:0076 class-ID: 0300
    serial: <filter>
  Device-6: 3-14:7 info: Intel BE200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0036 class-ID: e001
  Hub-7: 4-0:1 info: super-speed hub ports: 9 rev: 3.1
  Hub-8: 4-3:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Hub-9: 4-3.1:3 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  System Temperatures: cpu: 30.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1175 libs: 349 tools: gnome-software,pamac,yay
  Active pacman repo servers in: /etc/pacman.conf
    1: https://download.sublimetext.com/arch/stable/x86_64
    1: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 421
  1: cpu: 10.0% command: zsh pid: 4361 mem: 10.7 MiB (0.0%)
  2: cpu: 8.6% command: gnome-shell pid: 1950 mem: 300.8 MiB (0.6%)
  3: cpu: 8.2% command: brave pid: 3120 mem: 265.9 MiB (0.5%)
  4: cpu: 6.7% command: brave pid: 3081 mem: 377.3 MiB (0.7%)
  5: cpu: 2.5% command: brave pid: 3288 mem: 253.4 MiB (0.5%)
  Memory top: 5 of 421
  1: mem: 377.3 MiB (0.7%) command: brave pid: 3081 cpu: 6.7%
  2: mem: 300.8 MiB (0.6%) command: gnome-shell pid: 1950 cpu: 8.6%
  3: mem: 265.9 MiB (0.5%) command: brave pid: 3120 cpu: 8.2%
  4: mem: 253.4 MiB (0.5%) command: brave pid: 3288 cpu: 2.5%
  5: mem: 183.6 MiB (0.3%) command: brave pid: 3220 cpu: 0.2%
  Processes: 421 Power: uptime: 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 18.45 GiB services: gsd-power,upowerd
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9
    running-in: ptyxis-agent inxi: 3.3.39
I didn’t remotely suggest it was.
My comment clearly addressed experimental features in Chromium, which I haven’t been monitoring:
Unless you meant to infer that Wayland support is no longer experimental in Chromium based browsers, which is probably true. I haven’t been focused on browsers for some time. :wink:
Thank you for the inxi output. This may help others to identify other factors that might be contributing to your issue.
This has done this for me for at least 2 months with the google-chrome AUR, on the testing branch. I normally use Firefox, so it could have been 6 months. (I rarely loaded it.)
I knew it was GPU/Vulkan related then. I bought an older AMD chipset PCIe card, but newer as in on a smaller die, fanless, with a quad output. Perfect for my needs, my VM guests get my bigger GPU.
When loaded, it quickly changes random colors, then slows, and crashes. It doesn’t just crash Wayland, I have to hard reset.
inxi
  Kernel: 6.17.7-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.17-x86_64
    root=UUID=f33ea810-355f-4662-b046-6d8f72bae82b rw rootflags=subvol=@
    quiet nosplash apparmor=1 security=apparmor
    resume=UUID=9f5a3a86-21ad-4bcc-9db7-2377aee3d05c udev.log_priority=3
    amd_iommu=on vfio-pci.ids=10de:2216,10de:1aef video=efifb:off
    isolcpus=6-11,18-23 fbcon=rotate:1
  Desktop: GNOME v: 49.1 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.1 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Gigabyte product: X570S AERO G v: -CF
  Mobo: Gigabyte model: X570S AERO G serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F7d
    date: 09/02/2024
  System RAM: total: 48 GiB available: 46.93 GiB used: 2.86 GiB (6.1%)
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK16GX4M2D3600C18 serial: N/A
    (unregistered) size: 16 GiB speed: 2133 MT/s volts: note: check curr: 1
    part-no: CMK32GX4M2D3600C18 serial: N/A
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 1731 min/max: 567/4955 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1731 2: 1731 3: 1731
    4: 1731 5: 1731 6: 1731 7: 1731 8: 1731 9: 1731 10: 1731 11: 1731 12: 1731
    13: 1731 14: 1731 15: 1731 16: 1731 17: 1731 18: 1731 19: 1731 20: 1731
    21: 1731 22: 1731 23: 1731 24: 1731 bogomips: 177587
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cedar [Radeon HD
    5000/6000/7350/8350 Series] vendor: VISIONTEK driver: radeon v: kernel
    alternate: amdgpu arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
    built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 1
    speed: 2.5 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DVI-D-1,VGA-1
    bus-ID: 04:00.0 chip-ID: 1002:68f9 class-ID: 0300
  Device-2: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Gigabyte
    driver: vfio-pci v: N/A alternate: nouveau,nova_core non-free: 550-580.xx+
    status: current (as of 2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.0 chip-ID: 10de:2216 class-ID: 0300
  Device-3: Microsoft Modern Webcam driver: hid-generic,usbhid,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-2.3:6
    chip-ID: 045e:0840 class-ID: 0300 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.20 with: Xwayland v: 24.1.9
    compositor: gnome-shell driver: X: loaded: modesetting,radeon
    alternate: fbdev,vesa dri: nouveau,r600 gpu: radeon display-ID: 0
  Monitor-1: HDMI-A-1 model: Acer XB241YU serial: <filter> built: 2017
    res: 2560x1440 dpi: 123 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
    x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600 wayland: drv: r600
    x11: drv: r600
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.2.6-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD CEDAR (DRM 2.51.0 / 6.17.7-2-MANJARO LLVM
    21.1.4) device-ID: 1002:68f9 memory: 1.95 GiB unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Cedar HDMI Audio [Radeon HD
    5400/6300/7300 Series] vendor: VISIONTEK driver: snd_hda_intel v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 1 speed: 2.5 GT/s
    lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:aa68 class-ID: 0403
  Device-2: NVIDIA GA102 High Definition Audio vendor: Gigabyte
    driver: vfio-pci alternate: nova_core,snd_hda_intel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 10de:1aef class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: DSEA A/S Sennheiser Main Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 7-4:3 chip-ID: 1395:005d class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.17.7-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active
    tools: pactl,pw-cat,pw-cli
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp8s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
  IF-ID-1: br0 state: up speed: 2500 Mbps duplex: unknown mac: <filter>
  IF-ID-2: virbr0 state: down mac: <filter>
  Info: services: NetworkManager, nfsd, sshd, systemd-timesyncd,
    wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5:3 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.2 lmp-v: 11
    status: discoverable: no pairing: no
  Supported mdraid levels: raid0
  Device-1: md0 maj-min: 9:0 type: mdraid level: raid-0 status: active
  Info: report: N/A blocks: 3094091776 chunk-size: 512k super-blocks: 1.2
  Components: Online:
  0: sda2 maj-min: 8:2 size: 1.44 TiB
  1: sdb2 maj-min: 8:18 size: 1.44 TiB
  Local Storage: total: 13.65 TiB used: 3.22 TiB (23.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 3B2QEXM7 temp: 45.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QJXD7 temp: 53.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD60EZRZ-00GZ5B1 size: 5.46 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5700 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD60EZRZ-00RWYB1 size: 5.46 TiB block-size: physical: 4096 B
  ID-1: / raw-size: 896.78 GiB size: 896.78 GiB (100.00%)
    used: 643.35 GiB (71.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
    label: N/A uuid: f33ea810-355f-4662-b046-6d8f72bae82b
    used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
    label: NO_LABEL uuid: 22BD-3A90
  ID-3: /home raw-size: 896.78 GiB size: 896.78 GiB (100.00%)
  ID-4: /mnt/hdd raw-size: 4.02 TiB size: 4.02 TiB (100.00%)
    used: 2.5 TiB (62.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 79d7cd2a-98ea-4866-a9a9-e1a84e2e6ae1
  ID-5: /var/cache raw-size: 896.78 GiB size: 896.78 GiB (100.00%)
  ID-6: /var/lib/libvirt/images/r0 raw-size: 2.88 TiB
    size: 2.84 TiB (98.39%) used: 89.59 GiB (3.1%) fs: ext4 dev: /dev/md0p1
    maj-min: 259:9 label: vm-raid0 uuid: e7907293-87f5-4ee0-a0e6-c2c87f8ba1f7
  ID-7: /var/log raw-size: 896.78 GiB size: 896.78 GiB (100.00%)
  ID-1: swap-1 type: partition size: 34.44 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8 label: swap
    uuid: 9f5a3a86-21ad-4bcc-9db7-2377aee3d05c
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: DE9D-ABC8
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 1.82 TiB fs: ntfs label: N/A
    uuid: DC2EA3A22EA37464
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 522 MiB fs: ntfs label: N/A
    uuid: 02CA3BD4CA3BC2A9
  ID-5: /dev/sdb1 maj-min: 8:17 size: 4.02 TiB fs: btrfs label: N/A
  Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-1:2 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-2: 3-3:3 info: Apple Aluminium Keyboard (ANSI) type: keyboard,mouse
    driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 250mA chip-ID: 05ac:024f class-ID: 0301
  Hub-4: 3-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 5-1:2 info: Logitech G303 Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c080 class-ID: 0300
    serial: <filter>
  Device-2: 5-5:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-7: 5-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-10: 7-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 7-2.1:4 info: Logitech LogiG MKeyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 046d:c349 class-ID: 0300
  Device-2: 7-2.2:5 info: Logitech G502 X type: mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 046d:c099 class-ID: 0300
    serial: <filter>
  Device-3: 7-2.3:6 info: Microsoft Modern Webcam type: video,HID
    driver: hid-generic,usbhid,uvcvideo interfaces: 3 rev: 2.0
  Device-4: 7-4:3 info: DSEA A/S Sennheiser Main Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
    chip-ID: 1395:005d class-ID: 0300 serial: <filter>
  Hub-11: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-12: 8-2:2 info: Genesys Logic Hub ports: 4 rev: 3.2
  System Temperatures: cpu: 51.2 C mobo: N/A gpu: radeon temp: 47.5 C
  Packages: 1770 pm: pacman pkgs: 1759 libs: 460
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 11
    1: https://mnvoip.mm.fcix.net/manjaro/testing/$repo/$arch
    2: https://mirror.fcix.net/manjaro/testing/$repo/$arch
    3: https://irltoolkit.mm.fcix.net/manjaro/testing/$repo/$arch
    4: https://southfront.mm.fcix.net/manjaro/testing/$repo/$arch
    5: https://ziply.mm.fcix.net/manjaro/testing/$repo/$arch
    6: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    7: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
    8: https://cofractal-ewr.mm.fcix.net/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 501
  1: cpu: 11.6% command: firefox pid: 4563 mem: 602.2 MiB (1.2%)
  2: cpu: 10.5% command: localsearch-extractor-3 pid: 8119
    mem: 46.1 MiB (0.0%)
  3: cpu: 4.0% command: firefox pid: 6412 mem: 331.1 MiB (0.6%)
  4: cpu: 3.3% command: gnome-shell pid: 2739 mem: 250.8 MiB (0.5%)
  5: cpu: 3.0% command: firefox pid: 6108 mem: 305.3 MiB (0.6%)
  Memory top: 5 of 501
  1: mem: 602.2 MiB (1.2%) command: firefox pid: 4563 cpu: 11.6%
  2: mem: 362.6 MiB (0.7%) command: firefox pid: 5822 cpu: 1.1%
  3: mem: 345.1 MiB (0.7%) command: firefox pid: 5793 cpu: 1.1%
  4: mem: 331.1 MiB (0.6%) command: firefox pid: 6412 cpu: 4.0%
  5: mem: 318.7 MiB (0.6%) command: firefox pid: 5808 cpu: 1.0%
  Processes: 501 Power: uptime: 7m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 18.71 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.5 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: tmux:
    inxi: 3.3.39
Logs (in reverse from system crash)
Nov 13 16:33:59 mbox google-chrome.desktop[246894]: [246889:247744:1113/163359.800410:ERROR:google_apis/gcm/engine/reg
istration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Nov 13 16:33:53 mbox gnome-shell[2826]: Received error from D-Bus search provider org.gnome.Calendar.desktop: Gio.IOEr
rorEnum: Timeout was reached
Nov 13 16:33:44 mbox google-chrome.desktop[246894]: Created TensorFlow Lite XNNPACK delegate for CPU.
Nov 13 16:33:40 mbox org.gnome.Nautilus[246598]: GSConnect: [Errno 2] No translation file found for domain: 'org.gnome
.Shell.Extensions.GSConnect'
Nov 13 16:33:38 mbox org.gnome.Characters[246606]: JS LOG: Characters Application exiting
Nov 13 16:33:33 mbox google-chrome.desktop[246894]: [246889:247744:1113/163333.864249:ERROR:google_apis/gcm/engine/reg
Nov 13 16:33:32 mbox google-chrome.desktop[246894]: [246889:246889:1113/163332.465013:ERROR:components/signin/internal
/identity_manager/account_info_fetcher.cc:65] OnGetTokenFailure: Invalid credentials (credentials rejected by server).
Nov 13 16:33:31 mbox gnome-shell[2826]: Buggy client (google-chrome) committed initial non-empty content without ackno
wledging configuration, working around.
Nov 13 16:33:31 mbox gnome-shell[2826]: Client provided invalid window geometry for xdg_surface#47 (google-chrome - W3
4 (New tab - Google Chrome)). Working around.
Nov 13 16:33:31 mbox systemd[2611]: Started app-com.google.Chrome-246889.scope.
Nov 13 16:33:31 mbox gnome-keyring-daemon[2622]: asked to register item /org/freedesktop/secrets/collection/login/1, b
ut it's already registered
Nov 13 16:33:29 mbox systemd[2611]: Started Application launched by gnome-shell.
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Successfully activated service 'org.gnome.
NautilusPreviewer'
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Successfully activated service 'org.manjar
o.pamac.manager'
Nov 13 16:33:28 mbox org.gnome.Characters[246606]: vkEnumeratePhysicalDevices(): Initialization of an object could not
 be completed for implementation-specific reasons. (VK_ERROR_INITIALIZATION_FAILED) (-3)
Nov 13 16:33:28 mbox org.gnome.Characters[246606]: Vulkan: Loader Message: setup_loader_term_phys_devs:  Failed to det
ect any valid GPUs in the current config
Nov 13 16:33:28 mbox org.gnome.Characters[246606]: Vulkan: ../mesa-25.2.6/src/amd/vulkan/radv_physical_device.c:2182:
Device '/dev/dri/renderD128' is not using the AMDGPU kernel driver: Invalid argument (VK_ERROR_INCOMPATIBLE_DRIVER)
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Activating service name='org.gnome.Nautilu
sPreviewer' requested by ':1.135' (uid=1000 pid=246598 comm="/usr/bin/nautilus --gapplication-service" label="nautilus
 (unconfined)")
Nov 13 16:33:28 mbox org.gnome.Nautilus[246598]: Localsearch search engine has no connection
Nov 13 16:33:28 mbox org.gnome.Characters[246606]: JS LOG: Characters Application started
Nov 13 16:33:28 mbox gnome-shell[2826]: Received error from D-Bus search provider firefox.desktop: Gio.DBusError: GDBu
s.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.mozilla.firefox.SearchProvider was not provided by any
 .service files
Lollypop.SearchProvider'
Nov 13 16:33:28 mbox org.gnome.Lollypop.SearchProvider[246610]:   con.register_object(object_path=path,
Nov 13 16:33:28 mbox org.gnome.Lollypop.SearchProvider[246610]: /usr/lib/lollypop/lollypop-sp:71: DeprecationWarning:
Gio.DBusConnection.register_object is deprecated
Characters'
Nautilus'
Nov 13 16:33:28 mbox org.gnome.Nautilus[246598]: Connecting to org.freedesktop.Tracker3.Miner.Files
Contacts.SearchProvider'
clocks'
Calculator.SearchProvider'
Settings.SearchProvider'
seahorse.Application'
 .service files
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Activating service name='org.gnome.Contact
s.SearchProvider' requested by ':1.7' (uid=1000 pid=2826 comm="/usr/bin/gnome-shell" label="unconfined")
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Activating service name='org.gnome.seahors
e.Application' requested by ':1.7' (uid=1000 pid=2826 comm="/usr/bin/gnome-shell" label="unconfined")
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Activating service name='org.gnome.Lollypo
p.SearchProvider' requested by ':1.7' (uid=1000 pid=2826 comm="/usr/bin/gnome-shell" label="unconfined")
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Activating service name='org.gnome.clocks'
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Activating service name='org.gnome.Charact
ers' requested by ':1.7' (uid=1000 pid=2826 comm="/usr/bin/gnome-shell" label="unconfined")
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Activating service name='org.gnome.Calcula
tor.SearchProvider' requested by ':1.7' (uid=1000 pid=2826 comm="/usr/bin/gnome-shell" label="unconfined")
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Activating service name='org.manjaro.pamac
.manager' requested by ':1.7' (uid=1000 pid=2826 comm="/usr/bin/gnome-shell" label="unconfined")
Nov 13 16:33:28 mbox dbus-daemon[2629]: [session uid=1000 pid=2629 pidfd=5] Activating service name='org.gnome.Setting
Nov 13 16:33:15 mbox systemd[2611]: app-gnome-virt\x2dmanager-10405.scope: Consumed 2min 43.148s CPU time, 380.8M memo
ry peak.
chromium clearly had issues detecting ozone-platform right, last time i checked few months ago, and often erroneously detect wayland as X11. i think using atleast –-ozone-platform-hint=auto is mandatory.
refer detected Ozone platform in “driver information” section in chrome://gpu/
What makes you think that?
For me it’s detecting Wayland just fine (and crashes) and also I am running with –ozone-platform=wayland. I don’t think --enable-features=UseOzonePlatformis necessary anymore.
In both Chromium and Brave, there is no way to select the Ozone platform in chrome://flags or brave://flags since maybe a month ago. This makes me think that Ozone is now considered stable.
And I’ll reiterate - it works on Ubuntu.
Being realistic, I don’t think reporting this bug to Chrome developers is going to do much good - because Manjaro has much lower usage than Ubuntu.
And so, it’s going to be up to Arch / Majaro developers to fix this. Is there a Manjaro bug tracker?
if arch had to fix bugs on its own for every package where it worked on ubuntu but not on arch, they would have nothing else to do.
the way it usually works is, you report it to the actual project first, and if you are lucky they fix it upstream, and arch maintainer back-port the fix into the current release.
a more pragmatic way would be research more, like giving Chromium - ArchWiki a bit of read. there are several pitfalls for nVdia users with workarounds there. on failure you can take it up on arch-forums where in case there are multitude of users of sa having a same cause, then you can convince arch mainitainers to look into the issue.
Every now and then I have situations chromium based browsers crash and burn.
Not very often, but often enough to have noted it.
The crashes usually causes Vivaldi to loose profile information and I have to restore sync to Vivaldi cloud.
Ah the year of Linux on the desktop. Good luck mate.
luck is indeed short, because its mostly a influx of self-entitled people
