It’s like the browser settles into the display for a moment. This happens on Chromium, Brave and Vivaldi. Doesn’t happen on Firefox, Midori and Konqueror. I’m on XFCE.
I want to stress that it’s not a serious problem, I’m mostly just being curious. Perhaps someone’s encountered this issue before. Otherwise - no need to go out of your way to help me.
System: Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=cd849d35-c8c4-4f26-bdc4-002e98527dcd rw quiet apparmor=1
security=apparmor resume=UUID=7a219f56-7b22-4c13-95b0-edfcebd9ed3d
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B360-PLUS v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 1601 date: 07/30/2019
Battery: Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: 6-Core model: Intel Core i5-9400F bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache:
L2: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 34814
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Graphics: Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d01
class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb8
class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: 3000
bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 1-11:3 chip-ID: 0bda:8179 class-ID: 0000
serial: <filter>
IF: wlp0s20f0u11 state: up mac: <filter>
Drives: Local Storage: total: 1.84 TiB used: 1.1 TiB (59.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 953.87 GiB block-size: physical: 512 B
rev: ECFM22.5 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
type: HDD rpm: 7200 serial: <filter> rev: 1A02 scheme: GPT
Partition: ID-1: / raw-size: 50 GiB size: 48.97 GiB (97.93%) used: 25.76 GiB (52.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 296 KiB (0.1%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 887.37 GiB size: 872.44 GiB (98.32%)
used: 339.51 GiB (38.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
Swap: Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
Sensors: System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Info: Processes: 281 Uptime: 11h 38m wakeups: 22 Memory: 15.55 GiB
used: 4.26 GiB (27.4%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1408 pacman: 1402 lib: 397 flatpak: 0
snap: 6 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.07
