Chromium Based Browsers are Slow (Hardware Acceleration)?
The chromium based browsers on my system seem to have slowed down a lot after the 2022-11-02 update. On my system, this is Brave and chromium, both display almost the exact same rather serious UI latency when opening and closing tabs, and general internet navigation, especially Youtube videos which lag like crazy.
Speed test from the CLI comes in strong at ~180MB/s Down / 7 MB/s Up. Ditto when run from the browser. I suspect some kind of cache issue or some other bug, but have no confirmation.
Why have the browsers slowed down so much? Firefox is uneffected on my system.
Issue is not Kernel related, I restarted on a seperate LTS kernel and still have the same issue.
EDIT 0:
Running with --no-gpu increases speed by a lot on Chrome, manually disabling hardware acceleration in the Brave settings menu similarly improved performance by a large margin.
  Kernel: 5.15.76-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=f11386cf-342d-47ac-84e6-484b7b2f377d rw rootflags=subvol=@
    radeon.modeset=1 nvdia-drm.modeset=1 quiet
    cryptdevice=UUID=059df4b4-5be4-44d6-a23a-de81135eb5b4:luks-disk
    root=/dev/mapper/luks-disk apparmor=1 security=apparmor
    resume=/dev/mapper/luks-swap udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4403
    date: 04/27/2022
  RAM: total: 62.71 GiB used: 20.17 GiB (32.2%)
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3999 high: 4000 min/max: 2200/6203 boost: disabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3999 2: 4000
    3: 4000 4: 4000 5: 4000 6: 3999 7: 4000 8: 3999 9: 4000 10: 3999 11: 4000
    12: 4000 13: 3999 14: 4000 15: 3999 16: 3999 17: 4000 18: 4000 19: 4000
    20: 3999 21: 4000 22: 3999 23: 4000 24: 4000 25: 4000 26: 3999 27: 4000
    28: 3999 29: 4000 30: 3999 31: 4000 32: 3999 bogomips: 256110
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    prctl and seccomp
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
    v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 0b:00.0 chip-ID: 10de:2484 class-ID: 0300
  Device-2: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
    vendor: VISIONTEK driver: radeon v: kernel alternate: amdgpu arch: GCN-1
    code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-3,DP-4
    empty: DP-1, DP-2, DP-5, DP-6 bus-ID: 0c:00.0 chip-ID: 1002:683f
    class-ID: 0300 temp: 49.0 C
  Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 9-2:3 chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: radeonsi
    gpu: radeon display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x2160 s-dpi: 80 s-size: 1829x686mm (72.01x27.01")
    s-diag: 1953mm (76.91")
  Monitor-1: DP-1 pos: 1-2 res: 1920x1080 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: DP-1-3 pos: 2-1 res: 1920x1080 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  Monitor-3: DP-1-4 pos: 1-1 res: 1920x1080 dpi: 93
  Monitor-4: DP-3 pos: primary,2-2 res: 1920x1080 dpi: 82
  Monitor-5: DP-4 pos: 2-4 res: 1920x1080 dpi: 82
  Monitor-6: HDMI-0 pos: 1-3 res: 1920x1080 dpi: 93
  API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce RTX
    3070/PCIe/SSE2 direct render: Yes
  Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 5-1:2 pcie: chip-ID: 30be:1019
    class-ID: 0102 gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
    bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
    Series] vendor: VISIONTEK driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 0c:00.1
    chip-ID: 1002:aab0 class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: Schiit Audio Unison Universal Dac type: USB driver: snd-usb-audio
  Device-5: JMTek LLC. Plugable USB Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:3 chip-ID: 0c76:120b
    class-ID: 0300 serial: <filter>
  Device-6: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:4 chip-ID: 0b05:194e
  Device-7: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
  Sound API: ALSA v: k5.15.76-1-MANJARO running: yes
  Sound Interface: sndio v: N/A running: no
  Sound Server-3: PipeWire v: 0.3.59 running: no
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    driver: btusb v: 0.8 bus-ID: 5-5.3:7 chip-ID: 0a12:0001 class-ID: e001
  Device-1: luks-c847cf9f-c6b5-4624-a25e-4531e318851a maj-min: 254:2
    type: LUKS dm: dm-2 size: 3.64 TiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 3.64 TiB
  Device-2: luks-swap maj-min: 254:1 type: LUKS dm: dm-1 size: 12 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 12 GiB
  Device-3: luks-disk maj-min: 254:0 type: LUKS dm: dm-0 size: 919.01 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 919.01 GiB
  Local Storage: total: 9.1 TiB used: 2.61 TiB (28.7%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    rev: 111110WD temp: 57.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
    model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
    rev: 211070WD temp: 47.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
  ID-1: / raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
    used: 721.67 GiB (78.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-disk label: N/A uuid: N/A
    used: 39.5 MiB (7.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
    uuid: 8922-E04D
  ID-3: /home raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
  ID-4: /run/media/sarah/ConvergentRefuge raw-size: 3.64 TiB
    size: 3.64 TiB (100.00%) used: 1.87 TiB (51.4%) fs: btrfs dev: /dev/dm-2
    maj-min: 254:2 mapped: luks-c847cf9f-c6b5-4624-a25e-4531e318851a
    label: ConvergentRefuge uuid: 7d295e73-4143-4eb1-9d22-75a06b1d2984
  ID-5: /run/media/sarah/MSS_EXtended raw-size: 731.51 GiB
    size: 731.16 GiB (99.95%) used: 33.69 GiB (4.6%) fs: xfs dev: /dev/nvme1n1p1
    maj-min: 259:5 label: MSS EXtended
    uuid: 20339e0b-8343-433e-9209-ac67e31d9d73
  ID-6: /run/user/1000/keybase/kbfs raw-size: N/A size: 250 GiB
    used: 0 KiB (0.0%) fs: fuse dev: /dev/fuse label: N/A uuid: N/A
  ID-1: swap-1 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/dm-1 maj-min: 254:1 mapped: luks-swap label: SWAP
    uuid: c8991364-85a7-4e6c-8380-49cd5bd7a873
  ID-1: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
  ID-2: /dev/nvme1n1p3 maj-min: 259:7 size: 199.98 GiB fs: ntfs label: N/A
    uuid: E658FD3258FD025B
  ID-3: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs
    label: JerichoVariance uuid: 1AB22D5664889CBD
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 045b:0209 class-ID: 0900
  Device-1: 1-2.4:3 info: Microsoft Xbox One Controller (Firmware 2015)
    type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-4: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 045b:0210 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 2109:3431 class-ID: 0900
  Hub-7: 3-1.2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2813 class-ID: 0900
  Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-9: 4-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 2109:0813 class-ID: 0900
  Hub-10: 5-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 5-1:2 info: Schiit Audio Unison Universal Dac type: Audio
    driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
    chip-ID: 30be:1019 class-ID: 0102
  Device-2: 5-2:3 info: JMTek LLC. Plugable USB Audio Device type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 0c76:120b class-ID: 0300
    serial: <filter>
  Device-3: 5-4:4 info: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
    type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0b05:194e class-ID: 0300
    serial: <filter>
  Hub-11: 5-5:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 5-5.3:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 0a12:0001 class-ID: e001
  Hub-12: 5-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-13: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-14: 7-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 7-4:2 info: ASUSTek AURA LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
    chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
  Hub-15: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-16: 9-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-17: 9-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 1a40:0201 class-ID: 0900
  Device-1: 9-1.1:4 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
    type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
    power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
  Device-2: 9-1.5:5 info: Microdia Backlit Gaming Keyboard
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 400mA chip-ID: 0c45:652f class-ID: 0301
  Device-3: 9-1.6:6 info: HUION H420 type: Mouse,HID driver: uclogic,usbhid
    interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006e
    class-ID: 0300
  Hub-18: 9-1.7:7 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 9-1.7.4:8 info: Texas Instruments TI-Nspire Calculator
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 0451:e012 class-ID: 0000
  Device-2: 9-2:3 info: Microdia USB 2.0 Camera type: Video,Audio
    power: 500mA chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
  Hub-19: 10-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 44.4 C mobo: N/A
  GPU: device: nvidia screen: :0.0 temp: 54 C fan: 0% device: radeon
    temp: 49.0 C
  Processes: 805 Uptime: 21m wakeups: 0 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 alt: 10 clang: 14.0.6 Packages: 2629
  pm: pacman pkgs: 2593 libs: 521 tools: pamac,yay pm: flatpak pkgs: 19
  pm: snap pkgs: 17 Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.23
You are running two Graphics devices (and maybe an USB camera), six monitors and maybe six audio devices at the same time, if you want to find the reason for the performance loss you should start with a minimal configuration and add a device at a time to see when the lagging starts.
One graphics card is just for the displays, as far as I know if really doesn’t do any computations.
Only one audio device runs at a time, the rest are just for “If I need it” use.
I can’t really schedule removing the graphics cards and restarting with my current time schedule to see what works. :slight_smile:
Did you mean 2022-11-02? :wink:
Please see:
This is it touching nothing:
Is hardware acceleration already enabled, but is in a buggy state?
Kind of strange, before the update it worked just fine. I wonder what changed behind the scenes :woman_shrugging:
Mostly no. Why else would I have created the tutorial? :wink:
See also (which is linked in the footnotes): Chromium - ArchWiki
