Chromium: Abort (core dumped)
Chromium is not working. The output is Abort (core dumped). The version I have is 87.0.4280.88-2. But when I reboot my computer, this issue is resolved. About my rig:-
  Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  Desktop: GNOME 3.38.2 Distro: Manjaro Linux
  Type: Laptop System: Acer product: Swift SF314-42 v: V1.08
  serial: <filter>
  Mobo: RO model: Kona_RN v: V1.08 serial: <filter> UEFI: Insyde v: 1.08
  date: 10/14/2020
  ID-1: BAT1 charge: 19.8 Wh condition: 40.0/47.9 Wh (84%)
  model: Murata AP18C4K status: Charging
  Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64
  type: MCP arch: Zen 2 rev: 1 L2 cache: 3 MiB
  bogomips: 28462
  Speed: 1925 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz):
  1: 1925 2: 3521 3: 1574 4: 3500 5: 3471 6: 3557
  Device-1: AMD Renoir vendor: Acer Incorporated ALI driver: amdgpu
  v: kernel bus ID: 03:00.0
  Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus ID: 1-3:2
  Display: x11 server: X.org 1.20.10 driver: amdgpu
  OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.2-2-MANJARO LLVM 11.0.0)
  v: 4.6 Mesa 20.3.1 direct render: Yes
  Device-1: AMD vendor: Acer Incorporated ALI driver: snd_hda_intel
  v: kernel bus ID: 03:00.1
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Acer Incorporated ALI driver: snd_rn_pci_acp3x v: kernel
  bus ID: 03:00.5
  Device-3: AMD Family 17h HD Audio vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel bus ID: 03:00.6
  Sound Server: ALSA v: k5.10.2-2-MANJARO
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 01:00.0
  Local Storage: total: 476.94 GiB used: 153.32 GiB (32.1%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM512GDJTNI-82A0A
  size: 476.94 GiB temp: 47.9 C
  ID-1: / size: 169.01 GiB used: 106.56 GiB (63.1%) fs: ext4
  dev: /dev/nvme0n1p6
  ID-2: /boot/efi size: 511 MiB used: 352 KiB (0.1%) fs: vfat
  dev: /dev/nvme0n1p4
  ID-1: swap-1 type: partition size: 15.87 GiB used: 5.43 GiB (34.2%)
  dev: /dev/nvme0n1p5
  System Temperatures: cpu: 88.8 C mobo: N/A gpu: amdgpu temp: 78.0 C
  Processes: 329 Uptime: 5h 25m Memory: 7.21 GiB used: 5.31 GiB (73.6%)
  Init: systemd Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1752
  Shell: Zsh v: 5.8 inxi: 3.2.01
I have many chromium-based browsers on my pc. I have chromium, chrome, edge(dev), brave, opera, vivaldi and ferdi. I’m not crazy. I’m testing different browsers to find one as a backup for firefox.
